Washing Machines Logo
Posted on Jan 30, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
No agitator or spin cycle. Makes a loud funny sound.
Anonymous
Level 3:
  • Master 714 Answers
  • Posted on Jan 30, 2010
Anonymous
Master
Level 3:
Answers
714
Questions
Helped
188882
Points
2163
Could have a broken motor coupling
Kenmore 20802990 makes loud sound when spinning
Could be the clutch slipping if sound is like brakes if it's a rumble the hub that holds basket may have broke describe sound better
My washer is making a loud nosie when agitation starts
That is a normal sound when the transmission shifts from the last spin cycle to go into the agitate cycle. It should make a loud click sound that does not last longer than a second. There is nothing wrong with your washing machine.
1helpful
Kenmore 90 plus series washer won't spin, barely agitates, will drain - but makes loud noise
It sounds like the transmission is done. Can't pinpoint what it is exactly, but I would start there.
Doesn't agitate or spin but makes loud motor sound
check your motor coupling, it is between the motor and tranny
2helpful
Spinning cycle
When it is spinning, there is no agitation. Why? there is 1 motor with 2 directions to provide sinning and agitation by 2 different mechanisms. The sound from spinning, and rinsing could be some worn out parts from the mechanism need to be inspected and replaced accordingly such as the pulley, the clutch, the brake and 8 springs from bottom tube hung to the chassis to keep the tube balance under the load. Hope this can help.
Washer agitates off balance and makes a loud banging sound until movement stops at the beginning of rinse cycle, advice?
If it makes this noise in the agitate mode and not during the spin cycle, I would suspect that the transmission is going.
Will not spin and smells funny
Does the washer agitate while in wash cycle? Does it move at all? It may be that the motor that drives the spin and wash cycle is not working. If it smells funny, it usually means that you have bearings gone bad or a belt, if it is belt drive, broken. You can replace these parts. All the parts involved with spinning can be replaced. The parts are available from the maker. It may be a spin clutch, agitator gear, pulley, or a transfer case..
Please leave good ratings, email me if you have more questions
Load squeal when it in the agitation cycle.
Most noises from a washing machine occur during the spin cycle. If you hear loud thumping during the spin, the load of clothes may have become unbalanced. Stop the washer and redistribute the clothes, then re-start it. Repeat these steps if necessary.
for detailed help with diagrams and step by step instructions click the link http://www.applianceaid.com/washerspinnoise.html
5helpful
2answers
My Capacity Plus Admiral Washer will spin and agitate, but it makes a loud grinding noise.
Well, Sounds to me like the Bearings are going out, but it could make that noise a good while, before it goes completely out.. Replacement would possably be more cost effective, Kinda hard to beleive !!!!!!
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
