Question about Samsung SyncMaster 17" TFT LCD Monitor
Where is the power socket - Samsung SyncMaster 17" TFT LCD Monitor
  • 11,361 Answers
Power socket dead
When you connect the power adapter into the laptop, does the power LED light up? If not then - The battery adapter or the adapter's power lead or the laptop's power socket could be faulty. Check power adapter's DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK then connect it to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard. This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. If you cannot DIY then I suggest you get a quote first.
Apr 01, 2013 | Computers & Internet
HP Compaq 6730S laptop i scompletely dead. Any Help?
Jan 25, 2013 | HP Compaq 6730s Notebook
Power outlet dont work
check for power to the socket as often the link wire on the bottom of the socket packs up so remove the socket then check for power and if it has power then look for a link wire on the bottom of the socket and test for continuety
Mar 18, 2011 | 2004 Dodge Stratus
Power socket sony vaio
Look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
Feb 04, 2010 | Sony VAIO VGN-NR430E/S NoteBook
The battery saying dischargeing why when the laptop plug in it say charging then about five mins later it say dischargeing why
The power adapter lead/plug that connects into the laptop's power socket maybe be faulty or the laptop's power socket could be faulty.
Connect the power adapter to the laptop and power it up, then look at the power/battery charging LED light and wriggle the power plug in the laptop's power socket. If the power/battery LED light flashes and in a certain position this LED light stays firm, then the power socket is either faulty or it has a dry solder joint where it is connected to the motherboard.
Dec 25, 2009 | Fujitsu Siemens AMILO Pro V1000 Notebook
Need to know how to wire the power socket at back of v25
Have you determined the problem correctly?
The fault maybe the power adapter or the power plug that connects into the laptop's power socket rather than the power socket on the laptop.
Check power adapter’s DC plug that connects into the laptop power socket with a multi-meter, the voltage should be slightly higher than the voltage that is printed on the label on the bottom of the adapter. If the voltage is zero or way below the voltage that is printed on the label then the power adapter is faulty and needs to be replaced.
This can be repaired but it requires the laptop to be completely dismantled to get at this power socket and repair. The power socket is soldered directly onto the motherboard, there is no wiring required.
Dec 02, 2009 | Samsung V25 XVC 2800 Notebook
No power to cigarette lighter. have checked and
there are 3 fuses that operate that. #42 (15 amp) power socket, #18 (10 amp) power socket relay (power socket only operates with key on) and #23 (15 amp ) Cig lighter, key on.... have you checked all 3 fuses??
Sep 28, 2009 | 2000 Nissan Altima
Dc power socket
CHECK FOR POWER IN REVERSE OF THE SOCKET WITH A TEST LIGHT, A TEST LIGHT IS YOUR BEST SOLUTION IT WILL TELL U WHERE THERE IS POWER AT IN THE CIRCUIT. CHECK UR LOCAL HARDWARE FOR A TEST LIGHT USUALLY ABOUT $5 AT MENARDS
Aug 04, 2008 | 2002 Dodge Stratus
Cigarette lighter sockets no power
Cell phone chargers commonly blow the fuses at the power points. It seems that our charger adaptors do not match the socket properly, and the positive part of the charger hits the negative of the socket, resulting in a blown fuse. If you have a charger, and it works, leave it in the socket. Don't take it with you. Repeated insertions of the adaptor to the socket magnifies this issue.
Jul 16, 2008 | 2002 Toyota Camry
Replace the plug socket on gateway m520
plug socket? power socket? you must have alot of experience to replace the power supplies socket or you can just replace the power supply itself... as opening the power supply and touching one of the capacitors can give you a hell of a shock.
Jul 02, 2008 | Computers & Internet
Computers & Internet Logo
203 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
