Question about Moen & One Handle Tub & Shower Faucet
There isn't much pressure, and was wondering how to take the faucet off, can't seem to find it how to do it.
  • 122 Answers
To remove- Make sure the main house water valve is off.
To remove handle it will either be by prying off the center plastic cap and revealing a retainer screw or there will be a set screw hiding just out of view on the underside of the handle.
Most pressure problems are due to debris getting caught in the shower head. I would remove that first and try to blow it out with compressed air and/or cleaning it with some CLR. You can get CLR at any hardware store.
Hope this helps
Posted on Feb 02, 2010
How do I get more water pressure from a Tuscany model 673-6070 kitchen faucet?
Remove the spray head and clean the filter screen it may have particles of mineral from the plumbing clogging it.
Nov 26, 2016 | Plumbing
Put the faucet in, all seemed ok but did wonder about the faucet , when it was shoved down in place, what would hold it , so sometimes it blows off
there should be a small screw --probably in the back that goes into a groove after the unit is assembled
could even have a small plastic plug covering it
Oct 26, 2015 | Moen Banbury Collection 2 handle Kitchen...
Kitchen delta faucet doesn't get hot enough
Was it hot enough before the Delta? If so open and close the hot water valve (under the sink) several times as there maybe mineral deposits. I know you said the flow is the same on hot and cold but unless your version is a single handle model the problem should lie with the valve. If this is a cartridge model (cold & Hot together) then the cartridge may be out of align allowing the cold and hot water to mix.
Jan 18, 2018 | Delta & Single Handle Shower Faucet
WATER PRESSURE
Seems like you have a hard water problem that has clogged up your faucet with sediment. You will need to replace the faucet, or take it off and try soaking it in vinegar water for a few hours, then boiling it. This may remove the sediment within the faucet.
Apr 14, 2012 | Home
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also I am wondering what size hex head I need to remove the lever so I can...
i dont know the exact size just get the little set that has a bunch connected when you take handle off make sure water is shut down to pipes then take the inner part out of the center there should be two black screens in the ports where water comes in clean those and should be good to shower
May 08, 2010 | Delta & Single Handle Shower Faucet
I believe I have a delta monitor shower faucet. I am wondering why the hot water pressure is less than the cold water pressure. Also, I am wondering what size hex head I need to remove the lever so I can...
It takes a 1/8" allen wrench to remove handle. To increase hot water flow remove plastic dial that sets temperature. It is right behind handle and slides off stem for easy adjustment.
Remove indicator and replace about 1/8 to 1/4 turn counter clock wise to increase to hotter temperature.
Apr 26, 2010 | Delta & Single Handle Shower Faucet
Low pressure,cleaned screen in tip,checked incoming supply,seems strong,yet pressure is low??
Has pressure always been low? If faucet is new than there will be a flow restricter in the aerator. Most flow restricters can be removed easily. Some are a pain. Have you tried checking the pressure with the aerator off. That would tell you if the problem is there or in the valve.
Apr 20, 2010 | Moen 7310 Legend Single-Handle Kitchen...
No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Oct 07, 2009 | Kohler K-T10335-4-CP Lyntier Rite-temp...
Not enough hot water in one of my showers.
Turn the temperature down on your hot water tank to prevent scalding from all faucets.
Sep 10, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Loss of pressure in kitchen faucet - Price Pfister
Your problem is a simple one.
  1. Turn off water to faucet.
  2. Place a towel(s) in the base of the sink(s) to prevent any parts from going down drain.
  3. Remove the handle to the faucet. (single handle only)
  4. If not a single handle then remove spout from faucet.
  5. If a single handle remove cap carefully and any loose parts.
  6. Gently turn spout side to side while lifting to remove.
  7. You will see a hole with a very small valve where the water comes out to the spout on the base of the faucet.
  1. Remove this valve (which is a backflow preventer) and replace.
  2. Reassemble and test.
Problem solved.
Dec 04, 2008 | Price Pfister Marielle Kitchen Faucet with...
Moen & One Handle Tub & Shower Faucet  Logo
82 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
