Question about Timex Watches
The indiglo light doesn't work in my Timex pocket watch. No matter how I put the new batteries in it still doesn't work. Whar's the correct position for the batteries?
  • 3 Answers
SOURCE: Timex Expedition Indiglo light no longer works?
Replace the back cover with the arrow pointing directly at the stem. Everything should work correctly with the cover in that position.
Posted on Aug 18, 2008
SOURCE: How to change battery for Timex Indiglo WR 30M
I ended up putting the watch between two layers of a shop rag and tightened it in my garage vise. First try didn't work so the second try I turned the vise another /14 turn. Voilla! Stupid watch!!
Posted on Sep 23, 2008
SOURCE: setting day and date on timex watch
How do I set the day and date on my WR-30 M wrist watch
Posted on Jan 01, 2009
escapement
  • 2334 Answers
SOURCE: Link removal on ladies indiglo timex
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Aug 10, 2009
cmcduncand
  • 714 Answers
SOURCE: I have a Timex indiglo wr 30m wrist watch and I can't set the day
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 10, 2010
Replaced battery on Timex Indiglo WR30, now it loses time. Second hand hangs uo when it reaches area between 11 and 12, then continues on seemingly ok
need to put in fresh battery I know you may have just bought new one but it is old check for date on back package
May 13, 2017 | Timex Watches
I have a Timex Expedition watch which I have had for two years. I have been wearing Timex watches for 30 years and this one just doesn't live up to my previous experiences and expectatoins. The "indiglo"...
mcdevito75 here, Sorry to hear of your disappointment with your Timex watch, thru the years quality of workmanship and parts may have fallen a bit, try a new battery in your timex, a high quality Battery. Anyway here is Timex Customer service number, 800-448-4639 Regards, Mike D
Oct 20, 2010 | Timex Expedition Perpetual Calendar...
The light was fading on my Indiglo Timex watch but it was still keeping good time, so I had a new battery installed by a Walmart employee. The light now works on the watch but the watch stopped keeping...
mcdevito75 here, Your Timex watch is most likely an Indiglo meaning light, The battery supplies power to to Quatz mechanism for time keeping and for the light. There is a very good possibility that 1 or 2 of the contacts between the battery and the Quatrz mechanism were lost during the new battery installation. While you can"t rule out that the Quartz mechanism and or the light may be wearing down, you still have to suspect the battery even a new battery, look for a small watch repair shop in your area and try another battery, let the jewler know of your watches problem so he / she can properly install the battery and ensure the contacts between the Quartz and the battery are being made.
Jul 07, 2010 | Timex 27191 Wristwatch
Display disappears when Indiglo is pressed
That means your watch has two batteries - one for the movement and another one for INDIGLO. It may have just one battery, but in this case INDIGLO is taking up too much power. Replace the battery and you will be sorted. Rate me, plz.
Feb 19, 2010 | Timex Watches
I have a timex HRM. The indigo light just stopped working. I've had it for 3 weeks. There is a faint light on the edge, but it doesn't illuminate the face. Everything else works normal. Any ideas?
Check out if your watch has second battery for Indiglo function. It is quite common for Timex watches to have two batteries - one for movement and another for Indiglo.
Jan 21, 2010 | Timex 27191 Wristwatch
How to replace a battery in a timex indiglo pocket watch
Unless you have a way to both open & close the watch without breaking the crystal then you are better off taking it to a watch repair business.
Jan 07, 2010 | Timex Watches
After about two years, my indiglo night light function stopped working. The watch is still working, keeping time. Will changing the battery fix the indiglo problem?
Definitely, battery change will solve the Indiglo light problem. Many of wristwatches has separate battery for Indiglo function, but my advise is to change them both at once - will be cheaper for you.
Rate me, please.
Sep 01, 2009 | Timex 2J611 Watch
Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
Dec 30, 2008 | Timex Watches
Timex Expedition, beeps very quietly and indiglo doesn't work.
To clarify... Replace the cover with the arrow on the back pointing directly at the stem. The Indiglo backlight, alarms and chimes should all work when the back cover is in this position.
May 04, 2008 | Timex Expedition 40141 Wristwatch
Watches Logo
212 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Mark Schmit
Mark Schmit
Carol
Level 1 Expert
Are you a Timex Watch Expert? Answer questions, earn points and help others
