Question about Whirlpool Refrigerators
Refrigerator model ET18NKXFN0 1 water dripping inside box
Refrigerator model ET18NKXFN0 1 . . . getting periodic water dripping from back area of air diffuser box.
SOURCE: refrigerator drip
My SZ 550 (fridge over freezer) dripped constantly. Turned out to be a frozen drain tube, located 6 inches above the refigerator floor, centered on the back wall (cold side of refrigerator). Remove both trays and the lower glass shelf to see it. This tube runs down, behind the freezer, dumping refrigerator condensate in the pan below the freezer. If it's frozen the condensate leaks out the front of the fridge, down and onto the floor.
The fix, suggested elsewhere (not my idea) is quite simple and elegant. Thaw the tube (this will take an incredibly long time.) Fish a string (I used a piece of yarn) from the refrigerator (cold) side of the tube, down and out the other end, under the freezer. I was able to use a vacuum to suck the yarn through. Be creative. Once the fish line is in, tie a piece of nylon fishing line to the yarn and pull it through the tube. You have replaced the yarn with a stronger fishing line, which you can use to pull a piece of copper wire (I used common 14 gage romex, stripped of insulation through the drain tube. Leave the copper wire in the tube. If you wind the bottom end of the copper wire around some of the warm evaporator coils under the freezer the heat will be sufficient to keep the tube from freezing. I did this about a year ago and have had no problems since. Good luck.
Posted on Mar 08, 2008
Sea Breeze
  • 4655 Answers
SOURCE: water is dripping inside refrigerator
This ia a common problem that indicates the drain from freezer is clogged or blocked. I will send you to another link to help explain how to resolve this, Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
Posted on Apr 27, 2009
  • 1531 Answers
SOURCE: Crosley model CRTE171AW1. Water drips from above
the most commom problem is that the drain hole is covered with frozen water or the drain tube is plugged.
Posted on Mar 10, 2010
marka19
  • 1430 Answers
SOURCE: Refrigerator has water dripping inside the unit down the back
The problem is the drain is clogged. Remove the back panel in your freezer and at the bottom of the evaporator coil you will see a hole about ½” in diameter this is the drain tube. You might need to use some warm water to melt the ice and then run a wire being very careful not to puncture the hose and run it down the tube to free up the drain. This tube travel down to the bottom of your refrigerator to a pan sometimes located on top of the compressor or somewhere else down there. It collects the water there to evaporate. You can enter your model # at www.appliancehelponline.com for a diagram or illustration of your refrigerator. Not all models are available.
Posted on Apr 19, 2010
mrbobfixit
  • 259 Answers
SOURCE: Water drips in refrigerator. I think it has to do
You are correct. the defrost drain is most likely plugged up causing the water to drip into the refrigerator through the air returns in the ceiling of the fridge.
To access the defrost drain hole in your model you will have to remove the back wall from the freezer compartment and possibly the floor of the freezer as well if it has the floor air flow tray.
The repair is quite simple- remove as much of the ice as possible (i use a putty knife to pull it up in as large chunks as possible and then use a moistened dish towel to pick up the smaller pieces.
Use a turkey baster with some hot water to "plunge" the drain hole out. The drain hole is located in the bottom center of the evaporator opening.
Posted on Jun 15, 2010
Top freezer whirlpool refrigerator condensation water leaking/dripping
there is a drain in the freezer that sum time get Clogged the drain is located below the evaporator coil you have to remove the evaporator cover to unclog it make sure the refrigerator is unplugged before trying this you can't unclog the freezer drain without removing parts
Sep 10, 2013 | Refrigerators
Water accumulating inside fridge bottom make GE Model #gta18pbnaww
That's normal especially if you tend to leave the door open alot. Moisture from the outside air condenses and drips to the bottom. Also, if the refrigerator is automatic self-defrosting it will melt ice collecting around the refrigerator and the resulting water will collect at the bottom. Check under the food drawers for a drain hole. If it is clogged, clean it out. If it doesn't exist, periodically sponge out the bottom under the drawers.
Jan 12, 2013 | Refrigerators
Model ET18NK drain freezes up and water runs down in the inside of the refrigerator box when the refrigerator sits for long periods of time, unused. it is located at a vacation home and just used...
All refrigerators with a frost free freezer go into a deforst cycle automaticly 3 - 4 x a day. As the frost melts it drips into a pan located behind the rear panal in the freezer, ending up in a pan out side the refrigerator underneth, were it evaporates. Debris can clog the line causing the melted frost to back up and eventually drip into the refrigerator. The sure way to clear the path is to remove the back panel (inside the freezer) and remove any forign material in the pan, then blow out the line with compressed air. An easy way may be to pull the plastic drip line off were it comes out of the back of the box and clean/ blow it out from there. The problem with doing it the easy way is that your not removing the clog, just moving it in the freezer pan where it may find its way back clogging the drain again. Unplug the box prior to removing any screws.
Jul 27, 2010 | Whirlpool 18.2 cu. ft. Top Freezer...
Water drips in refrigerator. I think it has to do with the defrost feature, which seems to drip only periodically.
Jun 15, 2010 | Kenmore 20.6 cu. ft. Top Freezer...
Water dripping from inside of freezer compartment.
The condensate drain has a blockage further down and possibly in one of the turns as it leads down to the pan below your refrigerator. Most times the blockage begins slowly until the opening of the drain hole under the evaporator freezes itself shut. Below is a link to some solutions I have collected over a period of time. Also has a short movie2.gif that makes the repair look simpler. There are many reasons for this happening for example water leaking from a water supply line for the dispenser or ice maker, a crack in the defrost pan, water leaking inside and draining through the refrigerator cabinet, but most are caused by a defrost drain line blockage. Below is a link that may be helpful so try to take it all in and use the parts that most refer to your specific problem, Thanks Sea Breeze
click on link below
- Click Here=> HOW TO FIX A LEAKING REFRIGERATOR OR FREEZER
If you have more questions or need help feel free to let me know, Thanks, Sea Breeze
appliancepartsse@yahoo.com
SEA BREEZE TIP'S
http://servicepartstec.blogspot.com/
http://appliancepartsse.blogspot.com
Sep 24, 2009 | Jenn-Air JCD2389G Side by Side...
Water draining from back of the inside into the crisper
Check other question on this problem, but the long and short of it is try defrosting the fridge completly. (with the doors open)
Aug 25, 2009 | Refrigerators
I have a hotpoint refrigerator model CSX24XJ that was leaking water out the freezer door. I found that the drain was clogged and fixed this but I cannot find the drip tray. Does this model have a drip tray...
There is a leak somewhere in your defrost drain. Most times this is caused by a blockage near the area of the leakage. Below is a link to a very informative way to help you resolve the problem. Thanks.
Yes your model has 2 drip trays. 1 is below the evaporator inside the freezer and behind the back wall covering the evaporator. The other is below the refrigerator next to the compressor where the condenser fan heats the water and returns it back to the air inside your home. Thanks, Sea Breeze
Jun 28, 2009 | Hotpoint Refrigerators
Water is dripping inside the refrigerator from one of the holes in the top in the area back from the light
The drain is plugged and in defrost the water has to go somewhere. Try to blow out the drain with air. Or you might have to remove the evaporator cover to get hot water down the drain. First try to clear the line.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Water dripping into refrigerator from cooling area
Your defrost drain in the freezer is frozen closed.
Turn the fridge off.
Remove the rear freezer panel.
Remove the visible ice.
Use a hair dryer to thaw the drain hole in the back of the freezer in the center of the drain trough.
Mar 12, 2009 | Refrigerators
Water Leaking
The defrost drain is clogged up. I can't say much more because you didn't supply the model #
This may be a drip catch that you can get to from inside the refer or it may be the big tube on the backside of the box.
You may have to take the freezer apart and use a hair dryer to thaw out the ice.
Model numbers are important!
Jan 18, 2008 | Whirlpool 21.0 cu. ft. Top Freezer...
Refrigerators Logo
104 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
