Question about Moen T2152BN Brushed Nickel Brantford Single Handle Posi-Temp Pressure Bala
I need directions to install the handle that turns the water on and off for the t2152bn brantford.
  • 10,865 Answers
Hello. Here is the instruction sheet - http://www.moen.com/shared/pdf/instruction_sheets/INS1276.pdf
Regards, Joe
Posted on Jan 30, 2010
How to tighten set screw on Moen brantford shower lever
It sounds like the lever handle adapter may be broken or has become disengaged. . Remove the handle and inspect it. If the adapter is broken, it can be purchased at a plumbing supply house. Neither Home Depot nor Lowes will have it.
Dec 12, 2015 | Moen Home
What is the postal code for * ColonialCres, Brantford, ON?
The blocks from 23 to 31, at Colonial CRES in Brantford, Ontario (ON) Province have a unique postal code
23 - 31 Colonial CRES, Brantford Area Code is 226/519 and Time Zone is Eastern (GMT -05:00).
Remember you have 2 kinds of blocks: even or odd. In this case you are matching Even and Odd numbers for this block
Mar 10, 2015 | Computers & Internet
How do I remove the handle on a Moen Brantford doule handle lavatory faucet
there has to be a small setscrew hole on either handle .otherwise they could not be repaired
Feb 11, 2015 | Moen 6610 Brantford Two Handle Lavatory...
Faucet still running
Change the O rings in the mixer.
Mar 10, 2014 | Danco Faucet Stem
Have a moen brantford bathroom faucet. One handle has become very hard to turn. The hot water side turns fine, but you have to use muscle to turn on the cold. Does the handle need to be replaced or the...
It usually takes a special tool to remove a Moen cartridge. Just getting the handle off can be tough. How long have you had this unit? maybe it would be cheaper just to replace the whole thing. My last Moen lasted a good twenty years, still working good, but finally starting to corrode. Good product.
Nov 30, 2013 | Moen 6610 Brantford Two Handle Lavatory...
The cold water tap will not completely shut off. With the handle off the cold water slows down but does not shut off. When installed I turned the valve in the direction of instructions before installing...
Not positive about the model you have, but some faucet handles can be put on when the valve is not in the correct position.
Try taking the handle back off, turn it slightly clockwise, and re-install it.
Hopefully this will do the trick.
Good Luck!
Jan 23, 2011 | Home
My Brantford towel bar is loose. How do I remove
There are some tiny screws under the posts. Loosen them and lift the post off of its mount.
Aug 03, 2010 | Moen YB2218CH Brantford 18'' Towel Bar In...
Removing flow restrictor from Moen Brantford posi-temp shower he
How I remove them is take a drywall screw and screw in to the flow restrictor. Then grab it with a pair of pliers and pull out.
May 16, 2010 | Moen T2153BN Brushed Nickel Brantford...
The water doesn't seem to get hot . New cartridge installed . If turn right (Hot direction ) the knob will turn until water gets cold again ???
The cartridge sounds like it was put in 180 degrees out.
Pull it back out, and rotate 180 degrees and re-install & try that.
Jan 18, 2010 | Moen 1 Handle Lever Shower Faucet With...
Moen T2152BN Brushed Nickel Brantford Single Handle Posi-Temp Pressure Bala Logo
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
