Question about Kenmore 2.1 cu. ft. Portable Top Load Washer
It started out not spinning. The lights would
It started out not spinning. The lights would come on like it was trying to spin and then go off. Now it won't even fill with water
Kenmore portable washer will fill with water when button pulled out it just hums and occasionally tries to start.
Posted on Feb 19, 2010
Spin light keeps blinking and I am unable to start wash cycle
we also need more information to try to pintpoint the problem
Jun 18, 2014 | managemylife.com
I have a 2001 Chevy Malibu that wont start. All of the lights on the dash come on and when they settle.. only the battery and the check engine light are on. It has a full tank of gas and full oil and...
When you turn the key to the start position does the starter spin the engine ? The engine cranks no start ! Or nothing happens when you the key to start position ? no crank no start ? Is the anti-theft light lit on the instrument cluster (SECURITY) ? If the starter spins the engine does spin slow or normally ? Is there spark , fuel pressure ? Testing these thing's would be the place to start if the engine spins ! Videos on youtube showing how !
Apr 14, 2017 | 2001 Chevrolet Malibu
Flashing and beeping red spin light. won't spin
Have you emptied the filter recently. If it's clogged, the machine can't drain or spin.
Nov 15, 2013 | Washing Machines
Washer will drain but will not reach full spin in spin only mode
they dont spin full speed if they are overloaded, try it with less clothes.
Feb 11, 2009 | Frigidaire Affinity ATF7000ES Front Load...
Flashing time lights...pressed cxl button...not working
Flashed f ...time light flash...pump starts to work...doesn't spin...doesn't cycle...
Oct 16, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Technic 1200 mk2 turntable wont spin
need to know if it powers up. Does it try to spin, do you hear it trying to spin? More than likely the on/off switch went bad. No, I am not referring to the ON/OFF knob. THere is a switch this engages when turned. The part is S601. You might also want to replace the Start/Stop switch as well. If neither work, then the issue is on the main PC board, and probably IC101, or IC201 with the problem. At this stage, you will have to have a service tech look at your unit.
Oct 19, 2007 | Technics SL-1200MK2 Turntable
Tricity Bendix AW1400W Won't spin or agitate.
this could either b the motor brushes or the timer check the brushes first they r mounted on either side of the motor unplug the machine b4 u start good luck
Aug 26, 2007 | Tricity Bendix AW1400W Front Load Washer
Wont Spin
Hi Vixxy, Which lights flash when you hear the beeping?
Jul 23, 2007 | Fisher and Paykel GWL11 Top Load Washer
Washing machine stops mid cylcle
try pushing the door closed again, i have a problem with my machine that when i put a load on it starts then stops the light starts flashing then i firmly push the door (at the handle side) and it starts to work again, it might help!
May 10, 2007 | Whirlpool AWM6120 Front Load Washer
Kenmore 2.1 cu. ft. Portable Top Load Washer Logo
175 people viewed this question
Sal DeAngelo
fordexpert
Mike Squire
