Question about Moen & One Handle Tub & Shower Faucet
Have a stuck cartridge in shower. Just bought a
Have a stuck cartridge in shower. Just bought a cartridge puller, but it's still not budging. What do I do?
  • 35 Answers
You will have to use some considerable force when pulling out the cartridge. I like to use a pair of plyers and as I am pulling the cartridge I also wiggle the cartridge up and down.
Posted on Feb 18, 2010
How do I take out the catridge from a Moen 3175 Legend valve?
you need a cartridge puller, it installs onto the faucet and you thenntighten the bolt and the cartridge pulls out, about $12 at home depot or ace
Jun 24, 2014 | Moen 3175 Legend One Handle Shower Faucet...
Cartridge is stuck inside housing and will not come out
Moen makes a puller for this situation...
you can purchase at your hardware store.
Aug 07, 2010 | Moen 3175 Legend One Handle Shower Faucet...
How do I pull a Moen cartridge from a tub mixing valve?
You pull the little clip out from around the stem and then pull straight out on the cartridge, If it doesn't want to come out you may need Moen's cartridge puller (around $40.00)
Jun 26, 2010 | Moen & One Handle Tub & Shower Faucet
No pressure.. Help
cartridge # 1222,i am not aware of the # for the puller, i just asked for a moen puller.be sure to get one that pull's pos'i cartridge's. because the older type puller will not pull positemp easy.and while you have cart out run water to flush valve body out.good luck!
Feb 01, 2010 | Moen 2352 Chrome Chateau Single Handle...
Replace the cartridge for a moen shower
It is stuck, they come out very hard and a puller is made to make removal easier.
Nov 12, 2009 | Moen & Replacement Cartridge
How do I pull a moen single lever kitchen cartridge out that is old and stuck?I removed the horseshoe shaped clip. When I pull the valve stem, it doesn't budge.
there is a little plastic tool that comes with a new cartridge....you use it to turn the cartridge back and forth....breaking the seal that has formed between the rubber on the outside of the cartridge and the inner wall of the valve. After doing that you should be able use a pair of channel locks to pull the cartridge out.
Oct 20, 2009 | Moen & Replacement Cartridge
Moen one handle tub & shower is leaking from spigit
A stem is a cartridge in a real old valve. You have pulled retainer clip, you can try to pull it out with pliers, but you might need a moen cartrigde puller.
Sep 06, 2009 | Moen & One Handle Tub & Shower Faucet
Handle stuck
you may need a tool to pull thi out. you can get it at home depot,it's called a cartridge puller,you screw it on the cartridge and follow the directions it will come out.or just pull real hard.this is the only way to get it out,force!
Apr 10, 2009 | Delta & Single Handle Shower Faucet
Single lever moen shower valve -can't remove handle
if you have taken out screw then pull off if you have a handle puller use it
Feb 23, 2009 | Moen 3175 Legend One Handle Shower Faucet...
Moen positemp cartridge won't come out of brass body housing
If the clip has been removed it will come out. these things get incredibly tough to remove. Moen does sell a little puller just for these. I have used a socket with the screw in the stem to act as a puller.
If you have the water off AND your sure your have the correct new cartridge you can give the valve a little heat to help soften things up a touch. Use a heat gun with caution
Please rate this response and good luck, Phil
Dec 28, 2008 | Moen & Posi-Temp Single Handle Shower Or...
Moen & One Handle Tub & Shower Faucet  Logo
548 people viewed this question
Top Moen Home Experts
Mike
john h
Andrew Bugbee
Are you a Moen Home Expert? Answer questions, earn points and help others
