Question about Indesit W 123 Front Load Washer
Washer not emptying and smells, is there a filter
  • Indesit Master
  • 3,463 Answers
Filter is located at bottom front right of washer behind removeable trim.
Lever trim off, and remove filter by unscrewing anti-clockwise.
Posted on Jan 30, 2010
Washing machine smells like mould
The odor may come from several sources. Mildew may be around the door's gasket. That might be cleaned with a rag and a half bleach/half water concoction. The soap dispenser tray may have had stagnant water present. Other hose areas may be growing mildew.
Here are some things you can try:
1) Run dishwasher powder detergent once a month through the washer. Or...
2) Run 3 quarters cup of bleach through an empty hot wash cycle once a month.
3) Yes, baking soda, ye olde oder absorber, can also be tried.
3) Clean the trap (where coins, etc. may be captured). Clean the filter.
Some High Efficiency machines have "high efficiency, HE detergents recommended for them. Does the drum have a soapy coating? If so, it will likely require at least an empty hot water cycle to get rid of the excess soap which may be responsible for the smell.
Naturally, if you are using bleach to clean the the washer door, you want to clean the bleach off too before you ruin some clothes by contact.
Hope this helps.
Aug 04, 2015 | Washing Machines
It smells stagnant,opened the flap on the front and smelly water came out,but how do I clean the filter?
Hi from retired Englishman in SW France @ 17:48 Sunday afternoon.
Sorry but I do not know your specific machine but most are very similar!
I will have to assume that the flap to which you refer has the filter behind it because you say- 'opened the flap on the front and smelly water came out'. You should be able to pull the filter out of its 'container' even if it takes some gentle persuasion and patience!.
Also are you absolutely sure that it IS the water itself smelling? If your washer water drain pipe shares a sink's plumbing, it could be that the smell is coming from the sink's u-tube and through the empty pipework. I have had a few problem tickets like that! Plus- normally waste washing water a) smells of the washing powder and /or conditioner and b) would be mostly flushed away.
This is not to say that it isn't the filter with something fairly obnoxious stuck in it!
Good luck,
John C
Feb 06, 2011 | Miele W2240 Front Load Washer
Bosch washing machine not emptying
There should be a filter located at bottom right front of washer.
To clean it ,unscrew anti-clockwise, remove and clean it.
If you cannot see the filter, it may be behind a removeable plastic cover at bottom of washer..
Hope this helps you
Dec 08, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Sour clothes smell from washer
Until you can find the filter (I'll investiate!) I suggest running it on hot hottest wash you can (empty) with just bleach. That at least should kill the bacteria that are causing the smell
Jun 16, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Mildew in ge front load washer
Try two things: Add several cups bleach to the tub and run it a complete cycle. When not in use, leave the door open so it will air out.
Jun 04, 2009 | GE WBVH6240F Front Load Washer
Washer empties and strong putrid/ammonia like smell
most likely you do have drainage problems where it is backing up
Apr 24, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Zanussi zwf1430w progress 14oo
Its your filter that needs to be emptied; open up the front, locate filter, clean out. Refer to users' manual.
May 11, 2008 | Zanussi ZWF1430W Front Load Washer
Moldy smell
Turn it off, unplug it. Remove filter and check if filter and/or filter and pump housing are clogged with something "smelly". When you're at it check the drain pipe for too.
May 08, 2008 | Kenmore Elite 45986 Front Load Washer
Bad Smell
this is caused by a build up of old detergent and limescale.there are some industrial strength descalers around.wpro descaler is one.add the sachet to the drum with no wash load.pour in a kettle of hot water(not boiling)and leave for thirty minutes.then put washing machine on a 60 degree cycle and allow to run right through.you will need to repeat approximately every three months
Nov 16, 2007 | Hotpoint Aquarius WMA42 Front Load Washer
Bad Smell
Make a boil wash (with no clothes and detergents) put in the powder's drawer a cup of bicarbonate of soda. It should clean the machine and remove out the bad smell. Good luck!
Aug 31, 2007 | Bosch Classixx WFC 2465 Front Load Washer
Indesit W 123 Front Load Washer Logo
149 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
Darren Moxam
Darren Moxam
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
