Question about Dryers
Whirlpool dryer LEQ9858LW0 won't cool down - clothes too hot to touch. tested on Low also - still too hot. tried the Accudry and also timed dry. removed vent hose from back thinking maybe vent was blocked. still too hot.
  • 10,319 Answers
Heat sensor is at fault
replace it before it starts a fire
Posted on Jan 30, 2010
Dryer won't dry clothes
How to check the timer:
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 26, 2012 | Whirlpool Dryers
My dryer, Kitchen Aid KEYS850LQ does not cool down! The buzzer goes off, I open the door to remove clothes, and they are so hot I can hardly touch them!!! The dryer is only 6 years old - it never has...
If your dryer is not drying like it once did or if you just have nottaken the time to give yourself a clean dryer in a long time then youneed to do that. At least once a year the dryer cleaning should takeplace. Lint build up in the dryer duct is one of the main causesfor your dryer to fail.
Here is the rest of this tip about DryerMaintenance
heatman101
Jul 30, 2011 | KitchenAid KEYS850LQ Electric Dryer
When washing Machine goes into spin cycle, , it starts making a grinding noise and never goes to full momentum and starts to slow down, after the grinding noise. The clothes aren't fully dry as they...
Sometimes, a Whirlpool dryer may not function as you'd like.Although specific details vary by model, the company offers several generalguidelines to troubleshooting your Whirlpool dryer and getting it back intoworking order.
Verify that thedryer is connected to its power source if it won't turn on. Whirlpool alsosuggests checking your home's circuit breaker, as the high power needs of thedryer may have tripped the circuit. If the circuit has been tripped, reset itby flipping it back into the "On" position. Push the door of the dryer. Whirlpool designed its appliances to not turn onif the dryer isn't secured and notes that the dryer door may not be fullyclosed even if it appears shut. Push firmly at the top and bottom of the door,as some Whirlpool models have two latches. Press the "Start" button again. Whirlpool reports that some modelsrequire you to press and hold the button for five seconds to fully start themachine. Depending on the model, the button may be labeled "Hold toStart," "Start" or "Push to Start." Check that the dryer's settings knob is set to an actual drying mode and notsimply "Air" or "Tumble." On most Whirlpool models, themanufacturer states that the settings knob should be set to"Accudry," "Timed Dry" or "Automatic Dry." Clean the lint trap, typically located at the top of the dryer and removedby pulling its plastic handle. Over time, lint and dust builds up here. Thethicker the trapped layer of lint, the slower your dryer performance. Whirlpoolrecommends removing built up lint after every dryer load. Remove some of the wet clothes inside the dryer if it's taking an unusuallylong time to dry your clothes. Whirlpool warns that placing too much clothinginside the dryer reduces hot air circulation, which also reduces dryingcapabilities. Recommended dryer load s vary, with compact Whirlpool modelsholding approximately 3.4 cubic feet while extra large Whirlpool dryers holdingmore than 7 cubic feet.
Jun 07, 2011 | Washing Machines
I have a Whirlpool model WED5300VW0, electric dryer. It's only 1 1/2 years old. The other night, I had a load of laundry going, and discovered it was still running after almost 3 hours. The laundry was...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
Yes, the timer is bad...
That is not that hard to fix and you can easily buy the parts yourself online...
Here is a tip that will help you with the online buying...
How to Buy Appliance Parts Online
heatman101
Sep 08, 2010 | Whirlpool WED5300S Electric Dryer
Doesn't automatically turn off in accudry sensor
yes,the moisture sensor bars inside the unit can be replaced,you need to tear down part of the machine to do so,to further assist you,a model/serial# would help
Jul 17, 2010 | Whirlpool Dryers
Dryer is taking too long to dry clothes, even on AccuDry setting for Jeans/towels - it still is heating, just not heating enought to dry clothes, I have been doing two cycles at least for a very small...
Your house vent is restricted causing the long time to dry complaint.
Please clean the entire vent to the outside.
Also make sure the vent behind the dryer does not get smashed when the dryer is pushed back to the wall.
Jan 19, 2010 | Whirlpool GEQ9800P Electric Dryer
Need help
This is some basic info I could find on your dryer. I will need you Serial Number in order to determine the year it was produced. Please post back with comments and let me know.
Whirlpool Duet GEW9250P 7.0 Cu. Ft. Super Capacity 8 Cycle Front Load Electric Dryer With AccuDry Sensing System. Dry clothes in the time it takes to wash them. The dryers uses AccelerCare™ technology to work just as fast as the washer (Up to a 9 lb. load), giving you more time to enjoy all the good things you've worked hard to achieve.
AccuDry™ Sensing System - Monitor remaining moisture and automatically stop the cycle when the load is dry, with the AccuDry™ sensor. Reduce overdrying and save time and effort, by not having to return to the dryer to re-check progress.
Senseon™ Drying System - Moisture-sensing strips and temperature sensors inside the dryer drum monitor how fast the load is drying, how hot the air should be and when clothes are dry. The system automatically stops the cycle to help save time and prevent overdrying. Senseon™ technology safely dries clothes faster than it takes to wash them.
Wrinkle Shield™ Plus Feature (120 Minutes) - The Wrinkle Shield™ Plus option automatically tumbles the load without heat to help prevent wrinkles from forming.
Whirlpool brand offers an ergonomic solution for its front-load washers and dryers to help reduce bending, stooping, or arching. Based on your height and laundry room needs, optional 10 in. and 15.5 in. pedestals make loading, unloading, and filling the dispensers easier. The 15.5 in. pedestal doubles as a storage drawer with a convenient sliding shelf to support your laundry basket.
Item Features:
  • Super Capacity Plus - 7.0 Cu. Ft.
  • AccuDry™ Sensor
  • Senseon™ Drying System
  • 8 Automatic Cycles
  • Bulky Items Cycle
  • Adjustable End-of-Cycle Signal
  • Wrinkle Shield™ Plus Feature (120 Min.)
  • 5 Temperature Selections
  • Quiet Dry Plus Noise Reduction
  • Dry Rack
  • Reversible Side-Swing Door
  • Dryer Door Window
  • Reversible Side Swing Door
  • Electronic Controls
  • Front-Mounted Lint Screen
  • Interior Drum Light
  • 4-Way Venting
  • Porcelain SpillGuard™ Top
  • Optional Storage Pedestals Available
  • Stackable Installation with Matching Washer
  • Matches Duet® Washer
Specs:
  • Warranty: 1 Year Parts & Labor
  • Capacity: 7.0 Cu. Ft.
  • Dimensions (HxWxD): 38 in. x 27 in. x 31 1/2 in; Depth with Door Open - 51.5"
  • Construction: Front Access, Reversible Side-Swing Door Style, Powder Coat Drum Material, Dry Rack, Extra Large Front Mount Lint Screen, Power Cord & Venting Accessories, Stackable
  • Controls: Electronic Controls
  • Electrical Requirements: 30 Ampere, 120/240 Volts, 60 Hertz (1/second). AC-ONLY. USE COPPER WIRE ONLY. A FOUR-WIRE OR THREE-WIRE, SINGLE PHASE ELECTRICAL SUPPLY REQUIRED. A TIME-DELAY FUSE OR CIRCUIT BREAKER AND SEPARATE CIRCUIT IS RECOMMENDED.
You can get an owner's manual replacement for your dryer at laundrymanuals.com. I believe there is a membership fee for the website, however. I hope this info helps you.
Nov 23, 2007 | Whirlpool GEW9250 Electric Dryer
Whirlpool Dryer GEQ9858J autodry problem
Are you running the dryer in a relatively humid environment?
Sep 07, 2007 | Whirlpool GEQ9858J Dryer
Dryers Logo
131 people viewed this question
Top Dryers Experts
