Question about Kitchen Ranges
Self cleaning oven latch is stuck and the oven no longer works
We have a Jenn-Air drop-in style stove (cook top + oven) that was bought about 1989. Recently the cleaning lady tried unsuccessfully to use the oven's self cleaning feature and could not get it to work. Although the oven door opens and closes normally, the locking handle seems to be slightly to the right of the fully left position. It seems stuck. I have not forced it. Since then, the oven and broiler do not work. The cook top works normally and the circuit breakers are set. Is there anything I can do or try other than call the repairman?
  • 725 Answers
This is absolutely soemthing that you can repair on your own! And you save money by doing it yourself.
We provide free diagnostic information when you tell us what brand and model number you are having issues with.
We are available from 7 AM – 7 PM CST. We also provide part removal/installation instructions for our customers when parts are purchased through us.
It is our goal to get you back up and running again ASAP, so please contact us when you need us to help you.
We look forward to hearing you and hope that you have a terrific day. Thank you, Ella
http://www.fixya.com/repair/d499389-accurate_appliance_repair_service
Posted on Mar 11, 2010
Lever will not unlatch after cleaning.
The lock is a latch connected to a temperature sensitive bi-metallic spring that locks the door when HOT and releases it when it cools to a safe level. Self cleaning ovens reach over 500F in cleaning mode.
If it's been a few hours and the door is cool it should open. If not, press the door closed a bit and whack the top of the stove with your hand. It may be stuck or gummed up as that part does not get cleaned during the cycle.
You may be able to raise the top of the burner deck like the hood of a car and see some part of the locking mechanism and be able to get the door open. Replace the lock.
May 22, 2011 | Jenn-Air Ovens
I get an F9 in the window on the oven what does this mean
Below are the details of error code F9...
JENN AIR
'Newer Style' Range/Stove/Oven Fault Codes
Fault : F9
Condition: Door lock safety circuit on power relay board sensed
Replace power relay board
JENN AIR
Fault:F9
Condition: Door latch supervisory
Check door lock circuit or replace clock assembly or ERC
Let us know if you want something else please accept the solution.
Thank You for contacting fixya.com
Jan 01, 2011 | Jenn-Air Expressions AR141 Electric...
Will the stove top work while the oven is on self clean
Yes, but it will be very uncomfortable and possibly very stinky...
also check this out...
Self Cleaning Oven Problem
heatman101
Nov 10, 2010 | Jenn-Air Microwave Ovens
Self-cleaning overn won't turn on. Clock tells time, but not sure if actually activating the self-clean feature. Oven interior light works. Other oven, cooking functions are ok, including time bake. Door...
Before you go working too hard to get you oven to go into the self clean mode....check out this tip...
http://www.fixya.com/support/r3969401-self_cleaning_oven_problem
heatman101
" Wish I had read this first. I never would have used the self cleaning option. Thanks for the info!! "
Apr 18, 2010 | GE 30" Self-Cleaning Freestanding Electric...
I am getting a F9 on front of my oven
We solved this by holding in the door/light switch, hitting "clean", then pressing stop/clear for about 3 seconds.
Nov 27, 2008 | Jenn-Air SVE47100 Slide-In Electric...
Jenn-air shut off while cooking giving f9 code
code F9 keeps flashing when I attempt to turn on my oven. What does this mean?
Sep 03, 2008 | Jenn-Air JES9800A Electric Kitchen Range
Need help unlock oven after self cleaning jenn air jjw9527
The temperature setting must be set on "Cleaning" and the oven cooking dial to "Clean"; otherwise the door will not open and forcing will damage the mechanism. Also, before the door will open, the internal temperature must drop to a safe level and a red "cleaning" light must go off, after the temperature drops inside the oven.
Aug 23, 2008 | Jenn-Air Ovens
Stove cleaning
The filter in the jenn air can be run through the dishwasher. clean the outside of the oven as best as you can before you start the self clean cycle. NEVER!!! use oven cleaner inside a self cleaning oven. or on the gasket. . You can use a degreaser or oven cleaner on the cooktop on any stainless steel, procelain or chrome surface. Don't get oven cleaner on painted or aluminum surfaces. Rinse off very well.
Jul 05, 2008 | Kitchen Ranges
Jenn air oven stuck closed after attempt to activate self-cleaning
The lock motor may have failed. Most often, bending a coat hanger into a hook and sliding from the right side as you move the door to the right,will allow you to release the lock and open the door.
Jun 09, 2008 | Jenn-Air JJW8130D Electric Single Oven
Jen air locked latch after cleaning
I finally got my oven to work properly by shutting off the breaker and resetting the main clock. Cured the always locked problem as well as the beep twice when self cleaning.
Have to repeat this every few months since the problem seems to come back.
Feb 24, 2008 | Jenn-Air JDR8895AAS Dual Fuel (Electric...
Kitchen Ranges Logo
156 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
