Question about Hamilton Beach Cool Mist 05521 Humidifier
Short cycling After years of dependable service, our humidifier has started an annoying short cycling behaviour. For example, with a setting of 50% and a room humidity of 45%, the unit will gradually raise the humidity to 50% and shut off. Immediately after shut off, the unit's humidity reading will start dropping down and when it hits 48% it turns on again (this only takes a few seconds). At this point it raises the humidity back to 50%, again within seconds, and turns off. This cycle repeats over and over for several minutes until the humidity reading holds at 50%. Any idea what has failed?
  • Anonymous Mar 16, 2014
    When I set the humidifier to any percentage the fan would run for a few seconds then turn off for a few seconds. Then it repeats this cycle for the whole time that it is on.
  • 123 Answers
It doesn't sound like it has failed.
The whole point of the % setting is so that the room holds at that %. When the humidity drops lower than, it will kick in. When it raises to that number it will turn off.
If the on and off is bugging you try raising the percentage. Or lower the temperature of your house. Heating will dry out the air and cause your machine to kick in.
Good Luck.
Posted on Apr 18, 2008
Here is all the info I found Ser # 50908272 Holmes Humidifier HM-300
It depends on how humid it is in the conditioned space, how well sealed the conditioned room is, and how high you have the humidifier set. If you have low humidity in your conditioned space and you are asking for a higher humidity number, it could go through quite a bit of water. If your room is not sealed well, it will allow lower conditioned air into the room and put a larger demand on the humidifier
Jan 21, 2018 | Humidifiers
My Holmes HM630 humidifier doesn't get up to 40% it levels out 33-34%. How do I get it up to 40-50% air humidity level?
, this cool mist tower is ideal for medium rooms. It provides a refreshingly cool, invisible mist, as well as a digital humidistat which offers precise humidity control for your optimal comfort.
I got this off the Sears website so either the room you're trying to make humid is too large, or the humidistat needs to be set properly. Also make sure there is plenty of water in the tank.
Jan 04, 2015 | Humidifiers
Honeywell humidifier short cycles
It's not uncommon for duct work in an older home to Bang as the furnace cycles due to age. The humidifier banging while turning on and of is mostlikely the solenoid valve; if the solenoid is bad it is actually to your benefit to replace the entire humidifier as the solenoids are very expensive, 50%+ of a new humidifier. Plus you get the 5 year parts warranty on the new unit instead of just one year on the solenoid. If you don't want to replace the entire unit you can replace the Humidistat, and that should fix the on/off cycling, however a new humidistat is included with a new unit, which again is more cost effective. They are easy enough to replace as a do it yourselfer, especially when replacing an existing unit. I hope this helps you.
Dec 29, 2012 | Honeywell HE360A1027 Whole House...
Hi, We just purchased a vicks warm mist humidifier. We used it for two nights in my daughter's bedroom...we then noticed a sticky residue over sections of the wall as well as crackling paint? Is this...
is it possible that you have the mist turned up too high? If the room is very small, the high setting could be providing too much humidity to the room. I'm thinking that the paint crackled as the humidity climbed.
Nov 04, 2010 | Vicks Warm Mist V745A 1 Gallon Humidifier
Sears humidifier is running at less than 50% after only one year
If your sure you have water supply to the unit,the float switch/valve is either clogged or defective.
Jan 09, 2010 | Kenmore Humidifiers
The humidifer on the Sunpentown SH-1500 heater
what country are you in... winter time is low humidity to begin with.
Robert
Jan 06, 2009 | Sunpentown 1500W Heater Fan Humidifier...
Fill level & digital readout (bemis humidifier)
There is a sticker that comes in the owner's manual that apparently falls out frequently. I was told that the fill level is two inches below the top edge of the reservoir. I am going to mark mine with a Sharpie since stickers have a tendency to fall of when wet.
Jan 05, 2009 | Bemis Whole House Digital Humidifier ED11...
Honeywell warm mist humidifier shuts off
I want do any thi9ng after I====push the power button once,
push timer once, I chose 50%hum. the icon (two tear drops)
stoped blinking. Nothing happen at this point as for as
humidity in tothe room. HELP
Jan 04, 2008 | Honeywell Warm Mist HWM-255 Humidifier
Mildew
If you are keeping your humidifier set to 76, this is far too high. A humidifier setting of 40 to 50 percent is about right. Depending on your window insulation, you may have to reduce the setting in very cold weather if you start getting condensation on or around the windows.
Hope this helps.
Anthony Newman
Oct 17, 2007 | Honeywell HE360A1027 Whole House...
Hamilton Beach Cool Mist 05521 Humidifier Logo
130 people viewed this question
Top Hamilton Beach Humidifiers Experts
Paul Carew
Dennis
Are you a Hamilton Beach Humidifier Expert? Answer questions, earn points and help others
