Question about Dishwashers
On my GE Profile Dishwasher model GSD4320Y72BB, water is leaking during the rinse cycle for a about 10-15 seconds from the bottom of the drain solenoid (GE part WD21X802). The water does not seen appear to be coming from another source. Are drain solenoids known to leak water? Thanks, Bud
  • bpgasiorowsk Jan 30, 2010
    Thanks for the quick reply. How do I check for a bad connection and/or bad seal. Please note: Today, I just replaced the pump connect, which I did successfully. I discovered the solenoid leak while watching for leaks after replacing my pump connect.
  • 1,531 Answers
They can leak if there is a bad seal or they do not have a tight connection.
Posted on Jan 30, 2010
  • seth adams Jan 30, 2010
    there could be a problem with o rings they need to be lubricated with soap prior to reassembly they can roll over if not lubed
When is a dishwsher supposd to drain? Is pump working correctly?
normal to fill pan during wash and rinse fix door seal if it leaks
Jun 15, 2015 | KitchenAid KUDE40FXSS Builtin Dishwasher
I have a GE GSD 5130 Dishwasher that leaks about 12 oz of water when it is pumping out the wash water and the rinse water. Its fine during the wash and filling cycle. Is it a seal problem?
This is more likely the hose connection at the drain pump or the pump housing is leaking. You will need to remove the toe kick, place unit into a drain cycle and inspect for a leak. Here is a couple links that should help.
http://appliancehelponline.com/dishdraincircpumpvideo.html
http://appliancehelponline.com/dishwasherdrainpump.html
Jul 15, 2010 | GE GSD5130 Dishwasher
GE Profile Dishwasher does not drain. model #
I had a similar problem with a GE GSD5811 model. The hoses were clear, and the auxiliary pump worked fine. It turns out that it was the "piston" assembly that had basically disintegrated over time. This part diverts water to the pump during the drain cycle.
To check it, remove the mesh filter at the rear of the inside of the machine, by carefully unclipping the heater element from the back of the machine and removing the 4 hex-head screws securing the filter panel.) Unscrew the piston assembly from the tub, and pull it out. If the sealing plunger has deteriorated or is jammed, replace it. The part number for the "piston and nut assembly" for my machine (and probably numerous others) is WD24X10018. It should cost anywhere between $10 and 16, depending on where you shop.
Another possibility is a bad drain solenoid. (This is what actually triggers the piston assembly during the drain cycles.)
Dec 13, 2009 | GE 24 in. Profile PDW9880JSS Built-in...
Door leaks at the bottom of my ge profile dishwasher
1 has the machine been pushed into the cupboard hole,this will push the door away from the front of the machine,does it hit the trim around the opening before the closeing?pull out check under are the legs still straight,some you can remove the lower front panel to look under
Dec 02, 2009 | GE Profile PDW8400J Built-in Dishwasher
GE Triton Dishwasher timer may need adjustment ?
you have a clogged drain hose or a weak pump.  There are no adjustment on the timer it is what it is.
Apr 12, 2009 | GE Tritonr XL GSD6260JCC Dishwasher
GE profile dishwasher does not drain out aat end of cycle
I just fixed the very same problem by replacing the piston and nut (part # WD24X10018).
Jan 07, 2009 | GE Dishwashers
Will not drain
the selenoyd is bad take front bottom cover off you will see the problem selenoyd with 2 wires conected to it
May 03, 2008 | GE 24 in. Profile PDW7800 Built-in...
GE Nautilus won't drain after Rinse Cycle
Check disposer plug. If a garbage disposer has been recently installed, it is possible the disposer drain plug was not removed. The drain plug is a plastic piece in the disposer that blocks the hole where the dishwasher hose connects. Also check the hose connected to the disposal. Mine apparently had a kink in it. When I straightened the hose the dishwasher drained at full speed (I recently had a plumber re-route a hot waterline. He must has bent the hose). Hope this helps. If not go to the GE website. That's where I found my answer.
Nov 03, 2007 | GE 25 in. Nautilus GSC3400J Free-standing...
Dishwasher doesn't drain
Greg, if the model number ends in GO1, your dishwasher has a piston nut assy. thats problably giving you the grief. If this assy. goes bad you will have water left in the tub at the end of the wash. A common GE problem. It's located under the filter screen in the back and just unscrews out. Part number is wd24x199. It's an easy fix. Look up the part on the net to get an idea of what it looks like. Catriver..post back.
Jan 25, 2007 | GE 24 in. GSD1000G Built-in Dishwasher
Dishwashers Logo
160 people viewed this question
Top Dishwashers Experts
