Question about Maytag Neptune MDE4000 Electric Dryer
Extreme squealing noise - Maytag Neptune MDE4000 Electric Dryer
  • Maytag Master
  • 43,501 Answers
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
456yt
Posted on Sep 29, 2010
Bear tracker squealing noise when trying to start after running it goes away help please it sat for a year before got rear end fixed
Joe, do you mean a bearing track?
If so, a bearing -or track - usually makes a grinding or knocking noise, not a squealing noise.
If a car stands for a long time the brake rotors can corrode a bit and the pads can stick. Sometimes, when the car is first used after standing, you may hear a rubbing or squealing noise from the wheel. That's the pads sticking to a rusty rotor. The noise may wear off after a few miles when the pads 'polish' the corrosion off the rotor.
The other thing that causes squealing from a wheel are the brake shims. Try cleaning things first.
Mar 14, 2016 | Cars & Trucks
Power steering squeal
You should not turn power steering to extreme locks and hold them there constantly. The squealing is the noise the power steering unit is screaming," You are killing me".
Mar 27, 2014 | 2005 Nissan Maxima
Rear squealing noise when accelerating.
nothing to do with breaks sounds more like a u joint or bearing
Nov 25, 2012 | 2003 Toyota RAV4
When turning the steering wheel to the extreme end either to the left or right, hear a sequeaking noise.
How long have you owned the car before discovering this noise? Have you replaced the tires recently? I'm not sure what your squeaking noise sounds like exactly, but it sounds like it could be one of the two problems. If it sounds kind of like rubber squealing your tires may be the wrong size for your car and at extreme steering degrees the tires can rub on the car in a number of places. If the squealing sounds more internal like a muffled tea kettle and you can feel it through your hands (even slightly) while holding the wheel it's probably your power steering. If your power steering fluid isn't low then you make want to get your power steering pump checked. This is always better than waiting until your power steering pump goes out on you while you are driving down the highway (usually happens in the middle of a curve). I can personally tell you that one is no fun at all! :)
Mar 28, 2011 | Nissan Sentra Cars & Trucks
My brakes make a noise when brake is pressed now abs light is on is it safe to drive
i would have the brakes checked out real soon, the brakes could be worn down past their limitations, abs light , is letting you know that the system has picked up a problem with the brake system.
Feb 14, 2011 | 1999 Chevrolet Malibu
Loud squealing noise during wash and rinse cycle
The dishwasher make "loud high-pitched squealing sound" during the rinse cycle that is periodic through out the cycle
Nov 24, 2009 | Frigidaire Dishwashers
Replaced brake pads, extreme squeal resulted
Pads will reproduce sound just like a needle on a phonograph. Hard linings will accentuate this. Have the rotors re-surfaced and finished with a non-directional pattern(I make a quick pass with a D/A sander over surfaces while still on the lathe) Generally this will help.
Mar 30, 2009 | 2005 Jaguar XKR
When engine fan engages makes loud squealing noise
Either tighten the fan/drive belt or replace it .. it is loose ...
Mar 22, 2009 | 2000 Mazda MPV
Belt squealing outside engine corolla 96
Hello
Sounds like you have a loose belt
and if a cv joint goes to long will need to be replaced.
RD
Jan 15, 2009 | 1996 Toyota Corolla
Maytag Neptune MDE4000 Electric Dryer Logo
90 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
