Question about Whirlpool ED2NHGXM Side by Side Refrigerator
Where is the water filter located and how do I change it
In grill located below freezer door.
Posted on Oct 25, 2010
How do I change the water filter
Depends on the Manufacturer and Model. What Manufacturer and Model do you have?
I have though seen some filters located in the Inside of the refrigerator section towards top. Usually there is a Label or something showing where filter is located and actually a LED telling you when it is to be changed unless you have a real old one then I am not even sure they come with filters that Is something optional you install and they have no indicators to tell you when it needs changed you have to keep track of months or of course when water tastes like crap change filter.
Apr 16, 2015 | Refrigerators
How do I change water filter
Hello Anita;
My name is Peter. I am a retired field service refrigeration technician.
You did not provide a model number, so I am going to have to tell you where the water filter might be.
1.) On the lower, front bottom grill or toe plate, in the center there is a round hole. In this hole is your water filter. Grab the end of the cylinder and turn 1/4 turn counter clock wise and pull out. There will be some water in the filter. Slide the end cap off the old filter and slide it back on the new filter. Insert the new filter, push in and turn 1/4 turn clockwise.
2.) In the upper back right hand corner of your refrigerator section is where your water filter is located. There is a plastic cover plate around it, but you can still see the bottom of the filter canister. Reach in and turn the bottom of the filter 1/4 turn counter clockwise and remove. Insert the new water filter and turn 1/4 turn clockwise.
After installing a new filter, there is air in the filter. Run your water dispenser until a steady flow of water come out. You will get air & water spurting out.
If you only have a ice maker, you will have to manually cycle your ice maker until it fills.
The water filter change light is not tied into anything in your unit. It is like a egg timer. Even when the indicator light indicates to change you water filter, you only change your water filter when either the water coming out of the water dispenser is slow or you are getting small ice cubes.
Nov 23, 2014 | Kenmore Refrigerators
Where is the water filter what is the part number and how do you change it
Hello Dwane;
You did not provide a model number of your unit. The water filter location is dependent on the model number. The model number is located on a label on the inside of the fresh food section liner.
You have a bottom freezer. In general the water filter is located in the upper right hand corner of you right side fresh food section.
You may have a screw on the side panel to remove the cover, or some retainer clips, of which you must squeeze the cover housing to remove, or you may have free access.
Once locating, or accessing the water filter, grab the base and turn 1/4 turn clockwise to release and pull down. Insert the new water filter, insert and turn counter wise to the right.
Purge the air out of the filter system. Water filters are dry and have air in them. With your water dispenser fill several cups until al of the air is purged out. There will spiriting sounds.
You replace your water filter when you notice your ice cubes are small & when the water flow from your dispenser is low. The change water indicator light is a timer. It is set to cycle every six months. It is like a egg timer. It is not connected to anything.
Depending on the size of your family, and the usage you may need to change the water filter every six months or every 1-1/2- 2 years.
Nov 08, 2014 | Refrigerators
Where is the water filter on kenmore coldspot 106.9505712
On the front bottom of your unit you have a grill. On the grill there is a round knob. Turn the knob 1/4 turn counter clockwise and pull the filter out. Note the slot on the back of the knob that holds the old filter. Slide the old filter out of the slot and replace with the new filter.
Reinsert the filter with the knob into the filter housing. Turn the knob 1/4 turn clockwise to lock it in.
Now, the new filter has air in it. At your water dispenser, fill cups with water. There will be a lot of air and water coming out. Continue this until all of the air is out of the filter and there is just water fill.
When to change your water filter - Your unit has a water filter change light. This light is not tied into water pressure. It is like a egg timer. Every 6 months it will light. This does not mean you need to change your water filter. Change your water filter when your ice cubes start to get small or the water coming out of your dispenser is of a low flow. Depending on your family size, you may not need to change your water filter for several years.
My name is Peter. I am a retired Sears Home Services refrigeration technician.
Oct 24, 2014 | Kenmore Refrigerators
How to change water filter on msd2352kew
Instructions on how to change the water filter are found on page 20 of the user manual Here=> MSD2352KEW User Manual
I will be here should you have questions, Thanks Sea Breeze
The water filter is located in the upper right-hand
corner of the fresh food compartment.
1. Remove blue bypass cap and
retain for later use.
2. Remove sealing label from
end of filter and insert into
filter head.
3. Rotate gently clockwise until
filter stops. Snap filter cover
closed.
4. Reduce water spurts by
flushing air from system.
Run water continuously for
two minutes through
dispenser until water runs
steady. During initial use,
allow about a one- to two-minute delay in water
dispersal to allow internal water tank to fill.
• Additional flushing may be required in some
households where water is of poor quality
Mar 22, 2013 | Maytag Refrigerators
Red light on to replace water filter, how to do this?
Knowing just who made your Kenmore refrigerator may some day be important because Kenmore does not make the brands they sell. I am going to try to get you as many different ways the water filter can be changed as I can but if you can you locate the model number of your Kenmore it may make things much easier should you need parts or a manual some day. The number should look like this 521.345678 and located around the inside of the fresh food section door.
Here nis what I have found on different models and water filters from Whirlpool How to Replace In-Grille Refrigerator Water Filter - Push Button
How to Change the Water Filter in Your Refrigerator
Whirlpool Part UKF7003
How to Change a Kitchen Aid Refrigerator Water Filter
Read more:
If by chance you are able to find your model number that looks like the 513.235647 I mentioned before this will solve just what instructions you need or you can post a photo here or swend one to my email appliancepartsse (@) yahoo.com and I will be glad to help you get a manual and instructions for changing your water filter, Thanks Sea Breeze
How to Replace Interior Refrigerator (Filter1) Water Filter
Jun 25, 2012 | Kenmore Side by Side Refrigerator
After i change the water filter de button of water still red
The water filter status light, located at the top of the refrigerator
compartment, will help you know when to change your water
filter cartridge.
Style 1 - Standard status light (on some models)
When the water filter status light changes from green to yellow,
this tells you that it is almost time to change the water filter
cartridge (90% of the filter life has been used). It is recommended
that you replace the base grille water filter cartridge when the
water filter indicator light changes to red OR water flow to your
water dispenser or ice maker decreases noticeably. See
"Changing theWater Filter Cartridge" later in this section.
After changing the water filter cartridge, reset the water filter
status light by pressing the light switch 5 times within
10 seconds. The water filter status light will change from red to
green when the system is reset.
If you need Adobe Reader Click=> Adobe Reader X (10.1.0) (50.25 MB)
If helpful please rate this solution, Thanks Sea Breeze
Click Photo Below for User Manuals
Jul 29, 2011 | KitchenAid Superba KSRG25FK Side by Side...
Where is the water filter located and how do i replace it.
The water filter is located in the fresh food or fridge side of the appliance, at the rear - in the upper right hand corner.
To change the filter, open the fridge door, clear the top shelf and grasp the filter. All that is needed is to turn the filter to the left about a 1/4 turn for it to drop down. A few drops of water may spill onto the shelf. To install a replacement, remove the protective cover (shown as a red cap above), and position under opening for filter. Gently push upward while turning the filter to the right. The filter will pop in, and as you turn about 1/4 of the way around, it will be drawn up a small amount until seated. At this point it will no longer turn any further.
More info about the filter is below (taken from the manual).
Please rate this reply - thanks!
The water "Filter Indicator" light
• "Filter Indicator" light lets you know when it is time to change your water filter cartridge. The light
will change from green to orange. This tells you that it is almost time to change the current cartridge.
It is recommended that you replace the cartridge when the light changes to red. (see "Install the water filter" section for more information)
• If you install water filter, throw away the first six glassfulls of water filter, or until water flows clearly to flush impurities in the water supply system.
Using the dispenser without the water filter
• You can not use the water and ice dispenser without a water filter cartridge because the water line
blocks at water supply.
Ordering replacement filters
• To order more water filter cartridges, call 1-800-SAMSUNG and ask for accessory Part # DA29-
00003A or contact your authorized Samsung dealer.
Jan 04, 2011 | Samsung RS265LABP Side by Side...
Water Filter Indicator
I discovered by sheer luck that if I hold down the OK button for a few seconds the filter indicator changed from the flashing 1% to 99%.
Aug 01, 2007 | Whirlpool S20DRSS33 Side by Side...
Whirlpool ED2NHGXM Side by Side Refrigerator Logo
49 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
