Toshiba DVR19D digital vcr records in black and white only when using Digital signal but can see it in colour if watching at the same time. Is the a fault with this brand new machine or is the a setting I need to alter
The Wolf
  • 10 Answers
SOURCE: black & white picture on vcr & dvd playback
Check your VCR or DVD for correct region and standard. If I had a camcorder, VCR, or DVD player here in America on Pal standard or eupopean region the same thing would happen.In fact I accedently did that on an unknown switch on the camcorder.
Posted on Dec 05, 2007
SOURCE: how to set time on Harajuku Lovers digital watch
See, you just have to hold the blue button (in TIME 1 "T1") till the screen tell you "LIGTH OFF", then push the green button and u will see all the option.
i found it by myself... i took time but i did it...
i hope this can help u...
see ya....
Posted on Dec 27, 2008
SOURCE: IVE GOT A TOSHIBA RD-XV45KB VCR to DVD RECODER.
i too have the same error 03-56 the only way i have found around it is to use the really cheap basic -r discs from tesco
Posted on Feb 12, 2009
Tech5508
  • 40 Answers
SOURCE: how do i hook up dvd recorder/vcr to my tv?
Hello.
If its a combined dvd/vcr unit you should be able to record on the dvd input from the vcr with a 3 split cord connected as described below..
VCR -
Video output - yellow.
Audio output - left and right - red & white.
DVD
Video input - yellow.
Audio input - left and right - red & white.
Or you might have to use a standared RF cable from the
antenna out on the video to the antenna in on the DVD.
Additional information....
Just as you can't copy commercially made video tapes to another VCR due to Macrovision anti-copy encoding, the same applies to making copies to DVD. DVD recorders cannot bypass the anti-copy signal on commercial VHS tapes or DVDs. If a DVD recorder detects the anti-copy encoding on a commercial DVD it will not start the recording and display some sort of message either on screen or on its LED front panel display that it detects the anti-copy code or that it is detecting an unusable signal.
A DVD recorder can be used to copy any homemade videos, such as camcorder videos and videos made from TV shows, and can also copy Laserdiscs, and other non-copyprotected video material. Also, remember that a DVD recorder also has a built-tuner for recording TV programming directly. The tuner can be programmed to record a series of programs on different days and times, much like a VCR. However, if you are recording a non-copy protected DVD to a DVD recorder you can record any of the video content, provided you click on the menu and start the video segments running and you have enough time space on the disc. DVD recorders function like VCRs in that they can record incoming video signals -- however, they do not automatically copy all the contents of the DVD - for instance, you cannot copy the interactive menu functions of a non-copy protected commercial DVD. A DVD recorder creates its own menu functions, it will not duplicate the function menu from a another DVD.
Hope this will help you.
/Tech5508
Posted on Feb 13, 2009
  • 30 Answers
SOURCE: I have a new digital tv but can't get my vcr/dvd
The output connection from the VCR/DVD needs to be different for the new digital TV. Instead of using the RF output from the VCR, use the video and audio outputs and connect them to the video and audio inputs on the digital TV. When you want to watch the VCR, select "video in" on the TV. The digital converter box should be hooked to the input of the VCR so you can record programs off-air.
Posted on Jun 15, 2009
TV/VCR Recording of TV Programs Using a Digital Converter Box
Hi Rick
I think you are painting yourself into a corner. So to Speak.
Why buy a SetTop Box to convert to an old VHS Tape when you can buy a Digital Recorder for probably the same price.
The modern way to Record video is to use a Hard Disk Drive Recorder rather than a VCR. They have a built in tuner and can record 2 stations at once and have a built in Electronic Program Guide. The EPG info is transmitted with the Digital TV transmission from the broadcaster.
I bought one 2 weeks ago for an old 85yo friend so he could record late night stuff and play back later. He still uses the VCR but only for old VHS Tape playback. It was a TEAC HDR9650TS Digital Video Recorder and I picked it up new for Aus$188.
Here are the unit features
  1. Main Features:
    DVB-T Twin Digital Turners
    DVR Recording: Record three channels while watching a 4th from same network Smart Series Record feature to record a whole series at a touch of a button
    2.5" Sata Hard disk: 500GB
    Time Shift Function (Pause live TV)
    HDMI Digital Output
    Digital Audio Output
    CVBS/YPbPr/SPDIF connectors
    Supports TV formats 4:3 and 16:9
    Electronic Program Guide (EPG) up to 7 days in advance
    EPG searching and auto download
    Recorded program edit
    Parental Control
    Copy files from internal HDD to external HDD
    Built-in WiFi
    Network Playback
    USB 2.0 Interface
Now
This was my original reply until I saw the light.
So, Hopefully one of these will answer your queerie.
A digital TV picks up the new Digital Transmission and stores it in memory, then supplies the high definition to the input of your TV.
With a STB, once the digital broadcast signal is captured by the Set Top Box tuner, it is stored in memory and then it is converted to Video Format and comes out of the back connectors as a standard video & audio signal on the Red & White (Audio) & Yellow (Video) as a composite signal that can also be attached to an older VCR tape recorder.
If the STB output connectors have a Red White & Yellow RCA plugs then it is all ready to be picked up by an older TV or VCR.
Most set top boxes also have HDMI Output for high definition video & sound in the one cable, which attaches directly to the back of your TV (assuming it doesn't already have a tuner (STB) already built in).
HDMI is the state of the art cabling for modern devices. But probably not on the old VCR.
It will either use Component, Composite or SVideo cables. Match one of these cable standards up with your VCR.
Cheers.... Trevor
Was this Helpful
.......Then give me a tick of approval
Aug 18, 2014 | Panasonic PV-V4022 VHS VCR
Connecting up Digital TV, DVD recorder and VCR
You need to hook the VCR and the DVD recorder to the scart connections on your TV.
VCR to one scart on the TV
DVD recorder to the other scart on your TV
Jan 31, 2008 | Televison & Video
Is it possible to record digital 8 material from my Sony DCR-TRV 145E on my Toshiba DVR 20KB? Thank you in anticipation
Well, yes, at the basic standard of the output on Composite connector leads (3 line, ID on plugs: Yellow for video, white for Left channel of audio and red for right) but the digital signal has been converted to analogue, sent over this cable and converted backto digital in the recorder.
Some quality loss but very slight.
Even less loss if you use separate 'S' (or Y/C) connector cable for video signal only and another twin cable again for audio.
Thats still a D-A-D conversion process.
If a DV connector is on your camera and recorder you'll unconverted video & audio over one cable which will be really crisp.
If the connectors are there a recorder will accept signal from anything.
Sep 21, 2011 | Toshiba DVR620 DVD Recorder/VCR
Hi,can I record digital transmissions on my sony slv-se820g vcr barry
You can record a digital TV signal on a VHS VCR but only in analog format. The digital signal must be input to the VCR by some component which has a yellow composite video output and a white audio output such as a digital cable TV box or satellite receiver. For over-the-air digital TV, either the TV must output analog video or you need a DTV converter box connected to the VCR. Bottom line, the digital signal must be converted to analog for the VCR since VHS VCRs generally are analog recorders.
Apr 12, 2011 | Sony SLV-SE820 VHS VCR
Can the LG 990W VHS VCR receive digital TV signal
VCR is analogue, However you can still use it to record digital programmes when connected via a digital set top box. You can only record the channel you have selected on the screen. In other words, you cannot record a channel programme while watching another channel. I use mine on a second TV and when recorded I take the tape out and put it into my main TV for viewing at a later date. I don't watch too much TV so it works fine for me for the odd programme.
Dec 05, 2010 | LG MG64 VHS VCR
Toshiba VCR. It records OK but playback is black, white shaky
What do you mean by "records OK"? It sounds to me like you are not getting a signal to record. I had this problem before, as well. There are two things I recommend you try. The first is that (if you are trying to record over-the-air tv, you will need a digital television converter box connected directly to the vcr. If you already have one and are sure that it is connected correctly, you may also try an RF modulator. When I got my new vcr, it wouldn't work at first. I eventually found out that I would need an RF modulator in order for it to work on my tv. I hope these suggestions help. Good luck! Sincerely, Der Strom
Apr 26, 2010 | Aiwa HV-MX100 VHS VCR
Black and white on my tapes
Is the vcr sitting directly on top of, or underneath the TV? If so, this could be causing magnetic/static interference, and that's not good. It's good practice not to have anything that uses tape near speakers or TV's. Hope this helps.
Another possibility is the signal you are recording is coming from a cable box/digital cable box/satellite cable box. Try recording using the RCA cable inputs and outputs, instead of 75 Ohm cable, if applicable.
Apr 25, 2010 | Toshiba M685 VHS VCR
Can;t record on VCR since Comcast went Digital
I have Dish Network and a DVR and I do not know what I would do without it. I can record 2 shows at once and watch to 2 recorded programs while recording two shows. But getting to your problem... It sounds like the vcr cannot process the digital signal. You could try hooking up the vcr to the rca inputs from the cable box but you will only be able to record whatever channel the cable box is on. Any way you hook them up the programming of the vcr to change channels at different times for different programs probably won't work now. It sounds like Direct TV with two DVRs will solve your recording needs.
Sep 13, 2009 | Toshiba Televison & Video
Is my Toshiba 27AF42 TV bought in 2002 capable of receiving digital signals? And whether it is or not, how do I integrate my VCR into the TV and my converter box? Right now the TV is hooked up with the...
This is probably way too late an answer, but I just ran across your post. No TV made in 2002 has digital tuning, so you would need the converter box to watch off-the-air digital broadcasts.
To hook up the pieces, take the converter box output and run it to the VCR antenna input jack. Then run the output from the VCR to the TV's antenna input. Leave the VCR and TV both on channel 3 (or channel 4 if that's what you have the converter box output set for).
To watch TV, leave the VCR off and the signal from the converter will pass right through to the TV. You'll do your channel changing with the converter box, so the TV stays on channel 3. To record a program, just remember that the VCR will always need to be tuned to channel 3 (4), since it will have to be on the converter box output channel. Again, you pick the actual TV channel with the converter.
Note that this arrangement will allow you to program your VCR to record while you are out, but there are some limitations. You can't record things on different channels, since you won't be home to switch channels on the converter. The VCR is always recording on channel 3 (4), and the program you'll be recording is whatever channel the box is set for. If another program comes on on a different channel later, you won't be around to switch. But you could program different recording times on the same channel, anyway. You also can't record one program while watching a different channel, unless you had a second converter box.
Hope you can still use the information provided here. If this has been helpful, please take a moment to rate this a fixya. Thanks for asking here!
Dec 16, 2008 | Toshiba 27AF42 27" TV
Televison & Video Logo
61 people viewed this question
Top Televison & Video Experts
Electro Med Services...
