Question about Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System
My home theater speakers make a constant hum whenever my receiver is on. The loudness of the hum changes with the volume control, and goes away entirely when the system is muted. All components are plugged into one power bar. I have tried unplugging all attached components except the receiver but the hum remains. I have also tried disconnecting all the inputs from the back of the receiver with no luck. Does anyone know what the problem may be? Thanks!
    Novelist:
  • 85 Answers
Jd40,
Sounds like a grounding issue. The first two places to look into is the powered subwoofer and antenna. During your last test, did you leave the FM antenna and subwoofer connected? Many times the hum is directly related to the antenna and/or the subwoofer and to how they are grounded; creating a ground loop through the receivers ground on the outlet. If the antenna is grounded to the dwellings wiring, hum is inevitable and sometime you can get a ground loop hum from how or how & where the subwoofer is grounded. Try taking them completely out of the loop.
Also try taking it further back to the basics, start with the receiver plugged into a known good grounded outlet with no surge or line conditioner in the loop and nothing connected to the receiver, nothing. Use one speaker and different wire to test each speaker output while in tuner and any other mode but phono. With no signal, you will either get nothing (no hum or static) or just static in the tuner mode. No hum is a good sign. Some systems will mute the speakers if no signal is connected to eliminate the static from being produced through the speakers but a ground loop hum will most likely still be produced even in mute. If you get a hum when nothing is connected to the receiver, try looking into getting a better grounded outlet, even maybe to a different dwelling.
-Chris
Posted on Feb 28, 2010
No audio come out in speakers.
change the input. Amp could be blown. the speakers should have some type of hum when volume is turned up.
Apr 04, 2014 | Sony Av Digital Audio Video Control Center...
Woofer is humming
Usually a faulty cable or blown speaker will cause a humming. If it is a constant humming I would surmise a faulty cable. On the other hand, if the humming comes and goes I would guess a faulty speaker.
Dec 28, 2013 | Vizio 2.1 ch. Sound Bar with Wireless...
There is persistent low volume humming sound coming through all the speakers when the reciever is on, it is just loud enough to interfere with the audio I'm trying to listen too (especially dialog on the...
You could have done a very slow damage to the Yamaha if your UPS was not a pure sine wave type ( on line UPS ). Most of the UPS we get are called Off line type and are far cheaper than the On line pure sine wave type. The out put of the Off line type UPS is not a sine wave ( the natural waveform of AC voltage ) and strains the Power supply circuit of any device connected to it.
Now if the humming sound is the same irrespective of the volume position, it is a power supply problem. You might be having a leaky rectifier diode or capacitor. First change the diodes and see if its ok then change the main filter capacitors too.
Apr 28, 2011 | Yamaha RX-V663 Receiver
I just purchased a onkyo hts6200 and when the volume is over 35 or there is a loud noise in a movie or TV show, the receiver turns itself off. Also, when I performed the speaker set up, it shut off when it...
There's a clue in that. Swap the back left and right speakers and see what happens with the setup. If it followis - it's the speaker. If it goes away there was probably somethign amiss with its wiring. Report back.
Feb 07, 2010 | Audio Players & Recorders
There is a loud hum when volume is on low to high
go to control panel
sound and audio devices
voice
under voice recording clk volume and mute the mic phone...........
or
some how your mic is conflicting with speakers. Keep your mic away from your speakers..
Do reply if this woks
Oct 03, 2009 | Bose Companion II Computer Speakers
My receiver produces a humming noise that is so dang annoying I can't stand it. On top of that you have to have the volume of 50 or better to even he speakers what can be the problem?
I had this problem also on a different set top box (STB). What I did to get rid of that annoying humming noise was to unplug the RED plug only (from red, yellow, white combination) from the back of the STB, YEY!!! peace!!! This did not interfere with the picture or audio quality.
Jun 26, 2009 | Onkyo TX-SR506 Receiver
Strong humming sound coming from the over head speakers
are you running a stand alone dvd player or is it built in?check all plugs for sources coming ineg.dvd,vcr,xbox etc,if one is not in all the way,this will cause a hum.
Oct 20, 2008 | Sony DAV-C770 System
Intermittent, random, loud popping noises.
you should check the outline ctrl..for a mic...it could produce a noise...if you have your speakers connected to pc...check the position of the plugs and the volumen of mic put in down...
Nov 24, 2007 | RCA RT2760 System
Hum & noise coming from the speakers
IF it was too load you probable blew the speaker Just disconnect the side that is making noise or is it both side?
Oct 16, 2007 | Coby DVD-937 5.1 Channel DVD...
Yamaha 5.1-Ch. Surround Sound Home Theater Speaker System Logo
1,148 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
