Question about Dryers
Dryer is not heating properly. I have a GE dbsr453eb3ww dryer
    Genius:
  • 1,122 Answers
Check your wall vent,if it is clogged the dryer will not work right-mike
Posted on Jan 30, 2010
G,e, dryer model DBSR453EB3WW no heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
Aug 21, 2011 | Dryers
Drum on GE dryer is making squishy noise model-dbsr453eb3ww serial-tl713439a the noise happen when on
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
Asker's Testimonial "That answer was very informative - thank you fortaking the time to educate me. " - teresa241964
Jul 20, 2011 | GE DWSR463EG Electric Dryer
GE dryer dbsr453eb3ww making very loud squealing noise. Could it be belt? How do you access the motor?
You probably have worn front bearing slides, 316 and 313 in the diagram. You may also have a worn rear bearing 3106 in diagram. Slide putting knife between front panel and top near edges to release clips to gain acess to internals.
Oct 01, 2010 | GE DBSR453EBWW Electric Dryer
Squealing dryer
it may also be a bearing, you have to remove the outer cover to access the workings
Aug 17, 2009 | GE DBXR463EBWW Electric Dryer
Dryer drum doesn't sart rolling when it is turned on.
It is not using the start winding in the motor. You might be able to remove the end bell and clean the switch?
Apr 24, 2009 | GE DBSR453EBWW Electric Dryer
Dryer is not drying clothes.
well im not going to look up the model # to see if its gas or electric,but check the exhaust tube for blockages
Apr 21, 2009 | GE DBSR453EBWW Electric Dryer
My GE Driver will not heat
Check the circuit breaker or fuse box it takes two one to run one to heat. Then check thermostats Hi limit may be burnt if it overheated If the venting had been blocked. Hope that helps
Dec 26, 2008 | GE DBSR453EBWW Electric Dryer
Timer only works on Timed Dry Setting
Check your heating element. If one coil of the heating element is burnt out the dryer will heat on the remaining coil, but the timer will not advance in automatic dry.
Nov 13, 2008 | GE DBSR453EBWW Electric Dryer
Dryer dbsr453eb3ww
sounds like electric heating element issue to me. Your gas dryer doesn't have electric heating elements which might explain your problem
Jun 26, 2008 | GE DBXR463EBWW Electric Dryer
Dryers Logo
147 people viewed this question
Top Dryers Experts
