Question about Da-Lite Tensioned Director Electrol 89986 Projector Screen
Sony model kp46c36 rear projection tv looks like its 3d vision use to correct itself now just seeing double and colors similiar to 3d
  • 438 Answers
There is a problem with your convergence circuits which align the red,green,and blue colors this must be serviced again. sorry.
Posted on Jan 31, 2010
My mitshibitchi 1080hd has double vision with green and pink working perfect then all of a sudden
Tv have a problems known as a convergence problems,it dead.Tv have colors lines R,G,B mis alignments,have colors shadow pictures or 3D pictures look alike?Yes,the tv convergence board have dead 2 STK convergence ICS and some or all of it resistors too.These parts must be replaced on the tv convergence board to fix the tv convergence picture problems.The shop,will cost like $300-350 for parts and labors.
Mar 21, 2011 | Sony KP-48S75 48" Rear Projection...
We recently moved the tv and now when we turn it on it has double vision. It kinda looks like a 3d movie. What could be the issue? Is it worth fixing?
If tv picture was fine before moved then check dry/ cold solder joints/ connections on convergence output ICs and nearby circuit area.
Local tv repairman will resolder loose/ dry solder connections to solve double vision picture problem.
TV worth fixing if picture is good.
Thanks.
Feb 18, 2011 | Sony KP-57WV700 57" Rear Projection HDTV
Phillips 51pp9303h/17 red and green double vision of writen words and bowed line of red green at bottom. some objects in show look real shiney. and double vision of others.
Projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both. Repair kits with instructions are also avail from www.TvRepairKits.com
Common Problem #1) Convergence has gone out
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projection sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some pics of convergence problems.
69189a5.pngSOLUTION #1
For more more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Common Problem #2) CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
69189a5.pngSOLUTION
You can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Jan 29, 2011 | Philips 9P6031C 60" Rear Projection...
Double visions and focus on the picture.
projection TV sets have two very common problems. One is convergence ( 3D/Warped video) the other is CRT fluid ( Dull Video). Here are more details and solutions for both.
  • Screen looks 3D
69189a5.pngSOLUTION
Jan 09, 2011 | Philips 60PP9363 60" Rear Projection...
My sony kp57ws510 model tv has double vision and the double vision that shouldnt be there is in blue and red..whats wrong with my tv?
The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have shadows pictures or 3D pictures look alike.The tv convergence board have dead parts.The 2 STK convergence ICS and some or all it resistors on the tv convergence board are dead.These parts on the tv convergence board,must be replaced to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Oct 29, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Double vision
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Feb 19, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
Maganavox rear projection tv has developed double vision
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Feb 02, 2010 | Philips Magnavox 9P6034C 60" Rear...
Hdtv that has double vision
There are two common problems with these sets.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
Oct 23, 2009 | Hitachi 53UWX10B 53" Rear Projection...
Double vision in red and green
Its failure of convergence ICs and will be replaced.
Convergence ICs are mounted on silver heat-sink on D board of TV
Let me know exact model number to help you with more technical info.
Mar 21, 2009 | Sony KP-57WS500 57" Rear Projection...
53UDX10B 53 in. Rear Projection "3D vision"
I had the same problem with the same model earlier this year. You need to have the convergence module replaced on a circuit board inside. Expect to pay $400-$500 to a qualified repair shop.
Oct 11, 2007 | Hitachi 53UDX10B 53" Rear Projection...
Da-Lite Tensioned Director Electrol 89986 Projector Screen Logo
231 people viewed this question
Top Da-Lite Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Tony Mitri
Are you a Da-Lite Office Equipment and Supply Expert? Answer questions, earn points and help others
