Question about Dell 3110cn Laser Printer
When I print only one side of the page has black printing out and other half is blank except for other colors that print everywhee. dark strip all the way down right edge of paper.
    Novelist:
  • 217 Answers
Likely to be a faulty black cartridge, try another one
Posted on Feb 03, 2010
My mp610 Canon printer will no longer print email documents (black)- leaves page blank, except for email address (in blue print)., But printer will still print satisfactory color pictures (Photos). B
Get the latest driver from Canon's web site. Then uninstall the printer. Remove the driver from your computer. Use regedit to remove any traces of your printer from your registry. Install the new driver. That should do it.
Jan 10, 2015 | Canon MP610 Photo All-In-One Printer
How to reset counter workcentre 6505dn?
Try this link:
Read the Billing Meter The total number of printed pages can be reviewed at the Printer Control Panel, on the Configuration Page, and in CentreWare Internet Services (CWIS).
Three meters are available:
  • Total Impressions
  • Color Impressions
  • Black Impressions
The billing meter counts the number of pages that were printed properly.
  • 1-sided prints, including N-up, are counted as one impression.
  • 2-sided prints, including N-up, are counted as two.
    NOTE: During 2-sided printing, if an error occurs after one side is printed properly, it is counted as one.
  • Color documents converted using an ICC profile on applications with the Color (Auto) setting can print in color, even if displayed in black and white. The data prints in color even if it seems to be black and white data on the Display Screen. In that case, the number of Color Impressions is increased.
    NOTE: Grayscale images printed with the composite black setting count as color pages because color consumables are used. Composite black is the default setting on most printers.
  • When printing automatic 2-sided printing, a blank page can be inserted automatically depending on the settings in the application. In this case, the blank page is counted as one page.
View the Billing Meters:
IMPORTANT: The Bill Meters track the total number of pages printed for the life of the printer; it cannot be reset.
To view the total number of pages printed:
  1. Press the [System] button on the Control Panel.
  2. Press the [Up] or [Down] arrow button until "Billing Meters" is selected, and then press the [OK] button. The Print Volume Report will be printed.
  3. Press the [Down] arrow button to scroll to the required meter. The number of printed pages is displayed below the name.
  4. Press the [Return] button to exit the Billing Meters menu.
http://wss.support.xerox.com/GTConnect/UnifiedAcceptor/AddWebFramework.Main/site/XeroxProductSupport/product/product_wc6505/lang/en-US/region/region_US/source/DND/Xlang/en_US/Xcntry/USA/prodID/WC6505/KBlang/en/#!view-content/ViewContent/View/contentId/x_6130_en-O8884
Jun 13, 2014 | Xerox WorkCentre 6505/N Multifunction...
Dark print colors no longer dark.
Check your default print settings have not been set to draft mode or half tone.
Apr 08, 2014 | Dell 968w Printer
Lexmark z705 printing blank envelopes soft ware ok
The problem that you are experiencing is caused by the way the text is formatted in most word processing documents. By default envelopes are printed not in black, but a dark gray. This confuses the printer and causes it to use the color cartridge to process gray instead of using the black cartridge.
You can fix this problem with one of two ways:
1. Click on "Start", "Control Panel" and click on "Printers and Faxes." Right click on the "Lexmark Printer" icon and select "Properties." Click on "Printing Preferences." Go to "Quality/Copies" tab and select the option "Print color images in black and white."
2. You can also change the color of you text to a true black in your word processor. This will require you to resort to the word processor's documentation and help files.
Both of these settings will cause your printer to use the black cartridge instead of the color. If either one of these solutions solves your problem, it means your color cartridge needs to be cleaned or replaced. If you feel that the color cartridge should not be out of ink, please follow the steps given below:
Clean Nozzle Procedure:
1. Go to the "Solution Center" and click on the "Maintenance" tab.
2. Select "Clean to fix horizontal strips."
The colors that you should see here are black, yellow, magenta (a reddish purple) and cyan (a dark sky blue). You should notice the diagonal lines above and below the solid horizontal lines. These diagonal lines should be solid from left to right with no gaps.
If there are gaps in the lines or the print diminishes across the page, you should run the "Clean Print Nozzles" page a couple more times to try and clear it up. If you still have gaps at the top and bottom, you should "wick" the cartridges by following the steps given below:
“Wicking” Procedure:
1. Select "Install color/black cartridge" and remove the cartridge from the printer.
2. Get a damp paper towel.
3. Set the ink cartridge right side up on the damp paper towel so that the ink nozzles are against the towel and hold the cartridge in this position for about 15 seconds.
4. Now wipe the print head (on the bottom where the ink comes out) across in one direction only (left to right) until it looks clean.
5. Next dab the cartridge on the towel to make sure that the ink is flowing.
6. Snap the cartridge back into the printer.
7. On your computer, select "Old Cartridge installed."
8. Repeat the "Clean to fix horizontal strips" procedure listed above.
If this procedure does not help, please let us know so that we can continue with technical support.
Oct 01, 2009 | Lexmark Z705 Inkjet Printer
HP 2600n will not except print jobs.
just reset the printer to factory settings , use the menu to find factory settings .
Feb 03, 2009 | HP Color LaserJet 2600n Printer
PIXMA Ip4000
I assume you're using photo paper.
Go to File/Print. Click Properties. Click Media Type and chose the photo paper you are using, whether it's Photo Paper Pro or whatever. If you're printing using Plain paper and you have photo paper in the printer, you'll get the stripes.
Hope that helps
Oct 22, 2008 | Canon PIXMA iP4000 InkJet Photo Printer
Word 2003 not printing text, but prints everything when a clip art is added
I solved it! Aint no stopping me now!!!
This may not be a permanent solution, but it is one that will remedy the problem if you are caught in a bind!
Change the color of your document to the next color lighter than black but dark enough to print as black. Other colors do print.
Perhaps it is a problem with the black ink and/or cartridge.
My 6 page document printing normal with the exception that I changed it from the default black setting to the next lighter black color.
Now who will pay me for this tip? No charge, just kidding!
Sep 24, 2008 | Microsoft Office 2003 Pro (269-07387) for...
Lexmark black cartridge-and printer x1270 not printing black
I have a lexmark 6570 with similar problem. Who can help?
Nov 08, 2007 | Lexmark Inkjet Z517 Photo Printer
HP Color Laserjet 3500 printer - no black on left side of page
The folded paper solution for for me. Thanks to all for sharing!!!!
I had the same problem. No black or cyan on the left side of the pages. From this advice... I folded a stack of 4 pieces of paper in half and then half again. I took out the transfer unit and put the folded paper in the upper left corner and then put the transfer unit back in. WORKS BEAUTIFULLY! Thanks you all sooooo... much!
Sep 25, 2007 | HP Color LaserJet 3500 Printer
Dell 3110cn Laser Printer Logo
229 people viewed this question
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
