Question about Copystar CS-2550 All-In-One Printer
I had a light imaage in the center of the page, I cleaned the mirrors and lenses,lowered the fuser temp and it solved the problem. Now only when i scan through the ADF I get a blank copy If I use the glass or print no problem what could have caused this??
  • 1 more comment
  • yan dikshteyn Jan 30, 2010
    where is there a piece of paper please clarify, your saying there is papaer in the adf or on the glass blocking the scan area??
    there is nothing blocking the glass or adf but only when i use the adf the image copies blank prints fine off the glass fine.
  • yan dikshteyn Jan 31, 2010
    very helpful thank you
  • 3,741 Answers
The position of the light image and lenses is got moved from its actual alignment.this same type of problem occurs many times after cleaning the internal parts of the printer.you will have to reassemble all the parts again to its actual position.its just a bit moved from its position not very much.you will have to slightly adjust it and recheck.if that does not helps again readjust a bit and recheck.do it 3- 4 times will exactly make it set the position.mark the position with a marker so that you know on which position you have tried before and you don't try on that same position again n again. ------- but if lenses and light image all are perfectly set and you are confirmed that the position is not moved from its alignment then there is a cable passing from ADF unit assembly.may be that cable i got loose,unplugged or got short.you will have to open the printer machine and check out.if its loose /unplugged reinsert it to the proper port.it will be easily seen where to insert.but if its short then cable needs replacement.you can get this cable at printer repair shop dealing it electrical parts of printer/copiers. This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya
Posted on Jan 30, 2010
  • 542 Answers
This means you have blocked the scanning area for ADF or any piece of paper is there on ADF scanning area. Check and remove the same will resolve your problem.
Revert back for more assistance.
  • Rajesh Pai
    Rajesh Pai Jan 31, 2010
    Give your valuable feedback and ratings on the solution to provide better service/solutions.
Printer only printing blank pages
scanner unit problem. open and clean the mirrors and lenses with chamois/lint free cloth. if it solved OK. if not replace the unit.
Oct 20, 2014 | HP Photosmart C5380 All-In-One Laser...
Replacing laser printer fuser
Fusers are user replaceable parts on laser printers. Check this video for a look at how to replace the fuser.
Dec 30, 2012 | Dell 2330dn Laser Printer
2 of our Lexmark E250dn printers have both developed the same issue over the span of a few weeks where printing appears more and more faint towards the right hand side of the page, we have tested the...
If the Toner Cartridges are OK, the faint image is certainly due to the dust/ toner dust on the optics inside the printer, which reflect the laser beam forming image on the drum. The lase beam gets partially blocked due to dust and as a result the image is faint. There are mainly two parts responsible. (1) The mirrors (s) lenses.
So, it is recommended that you carefully clean the optics of the printer (lenses & mirrors) from front as well as back and edges of the mirrors. You may use cotton swab or a very soft, lint free cloth for cleaning. Apply some glass cleaning liquid (only) if it is required. Hope you would be able to fix it.
If you are familiar with the process of printer repair etc, you can do it yourself. Otherwise, the printer requires cleaning/ servicing by a professional.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jul 01, 2011 | Lexmark E250d Laser Printer
Blue, red and green are very average quality but yellow is not visible. On a windows xp test page. the yellow is replaced with an orange color. A logo test page indicates some ghosting/shading - for...
Ghosting and shading on this series printers is usually caused by either a bad fuser or out of date firmware. There were fixes in firmware that stopped ghosting from happening. As for the cleaning the lens. These models have a bad habit of collecting dust on the inside of the scanner unit and the only way to resolve that is disasemble the laser unit and clean the inside of the lenses.
Mar 04, 2011 | HP Color LaserJet 2600n Printer
Imaages are distorted and so is the color no convergence settings
There should be a way to adust Level 1, 2, and 3 convergence settings. If not try to clean the lenses with qtips and alcohol.
Mar 07, 2010 | RCA HD52W56 52" Rear Projection HDTV
Repeating white spot deletion suggests drum, fuser roller, cleaning roller,etc has a defect. Drum/imaging unit replaced and fuser roller can be seen and looks good. how do i get the fuser out to inspect...
Fuser doesnt sound like your problem generally speaking fusers will add black marks not deletions look to your image creation lense mirrors erase lamps or defective charge grid
Jan 16, 2010 | Canon PC-921 Black and White Copier
HP 1020 produces 2 grey lines at edges of page
it is the problem humadity or laser mirror is dirt clean it and then solve your problem
Jul 05, 2009 | HP LaserJet 1020 Printer
HOW DO YOU CLEAN A CANON D860 COPIER?
your fuser rollers are dirty and tracking the image
unplug the machine open the fuser area wait until they cool down
take fuser oil(silicone lubricant) and wipe the rollers
while you are at it remove the glass and clean the reverse side and clean the mirror and lens
take a q tip and ubbing alcohol and clean the charger wire
Dec 30, 2008 | Canon ImageRUNNER 1670F Copier
Dull picture on my KP61s65
You can safely clean the mirror and lenses, it can greatly increase your picture if its dirty. If you unplug your tv you can safely remove the back and gain access to the lenses. All it takes is a philips screwdriver. After you remove the back, you can remove the light barrier between the upper and lower half to free up some room. Take a dry scratch-free cloth and wipe the dust from the lenses. If they're grimy, use a little lens cleaner (liquids used sparingly here, electronics don't like liquids, be careful) You can look up into the top and see if the mirror is dirty. A flashlight shined on it will illuminate the dust/dirt if its there. If you don't smoke you likely won't need to clean the mirror, but it may need it. Use windex or similar for tough grime.. I can usually reach up to get the whole mirror but I've heard of using a swiffer mop to reach the top. Removing the screen is difficult but possible if needed to get inside. Don't touch the back of the screen but lightly with a rag to get cobwebs, etc.
Nov 27, 2008 | Sony KP-61S65 61" Rear Projection...
Copystar CS-2550 All-In-One Printer Logo
29 people viewed this question
Top Copystar Office Equipment & Supplies Experts
Kyocera HP Expert
CheckitRight
CheckitRight
Tammie Duggan
Tammie Duggan
Are you a Copystar Office Equipment and Supply Expert? Answer questions, earn points and help others
