Question about Jensen VM9510 Car DVD Player
I can not get the back brakes to lock on when i pull the hand brake on. i drive a renault master dci90, i have replaced all the cables and pads.
  • 66 Answers
Probably need to readjust the parking brake cable.
Posted on Jan 30, 2010
Renault megan. Intermittent loss of brakes, then pedal goes hard
Make sure the emergency brakes are back off and adjusted after pad replacement. A lot of mechanics forget or don't know about this. Also check the master cylinder. Push on brake pedal hard and see if it sinks to the floor, if it does then the master cylinder is bad. If there is air in the brake system it is best to pressure bleed or vacuum bleed the brakes to get the air out. Often when using the two person pump the pedal and hold will not be effective in getting all the air out if a line is broken and then replaced. Amazon com Online Shopping for Electronics Apparel Computers Books DVDs... and Automotive parts!!!
Jan 17, 2015 | Renault Cars & Trucks
Hand break light coming on with out using hand break
The cable tightness is loose therefore causing the light to come on while driving, tighten or replace the eb cable hope that helps or you need to push in the button on it hold the button and pull it back as far as you can. let go then push button pull back farther and release, this should tighten the tension.
Jan 02, 2015 | 1994 Chevrolet C1500
Brakes lock up the longer you drive
Check the brake pedal rod to piston clearance. Should be about 1" before you touch the brake master cylinder piston. If it is ok then replace the brake master cylinder as the compensator ports in the cylinder are not clear. The heat generated from the brake action is building up in the brake fluid and as it cannot get back to the reservoir it is expanding the brakes pads/ shoes and putting on the brakes. The more it heats the more brake action which heats the oil more and so the cycle is repeated until the brakes lock on.
Oct 26, 2013 | 2006 Chevrolet Malibu Maxx
How can ichange the disc brakes on a renault 19
Hi there, I have a few steps here to help you out:
  • With your hand brake ON, loosen the wheel bolts to hand tight, jack up front wheel, chock back wheels, and put axle stands/blocks in place (just in case) .
  • Remove wheel. Disconnect pad wear wire, it pulls out of the connector.
  • Remove lower caliper bolt (at the back of caliper at the bottom), need a 13mm ring spanner for head of bolt and 17mm to stop it spinning
  • Use a screw driver between the back of the outer pad and the caliper to raise the caliper back away from the back of outer pad. Pivot caliper upwards to rest on top of wheel disc (good idea to tie it up with some wire) .
  • Remove and discard old pads , clean out with wire brush and soft brush , don't breath in to much of the dust its nasty.
  • Fit new pads (remember pad wear sensor on inside pad), make sure that the pads are in contact with the disc , and the top of them sitting flush with the rim of the disc, don't force them into this position they should naturally sit there.
  • Lower caliper down into position, you may need to push back the piston further in order to make room for the new pads , do this with you hands or a small piece of timber. Keep an eye on the brake fluid reservoir , your pushing fluid back in so if its over full it may spill over. Refit lower caliper bolt (Renault say to replace this each time), and tighten. Reconnect pad wear sensor.
  • Pump brake pedal until normal brake pressure returns.
  • Remove axle stand/blocks, refit wheel and bolts, lower jack and tighten up wheel bolts.
Hope this helps...
Jan 17, 2011 | 1986 Renault Sport
Brake pad replacement 2004 audi a4 and rotor how do i do and what tools are neccessary?
YOU NEED REMOVE A LITTLE BRAKE FLUID FROM MASTER CYLINDER.THEN YOU RAISE VECHICLE SAFELY.SUPPORT IT WITH JACK STAND.MAKE SURE VECHICLE IS ON LEVEL SOLID GROUND.REMOVE TIRE OR WHEEL.THEN YOU NEED A LARGE C - CLAMP.PLACE C - CLAMP OVER BRAKE CALIPER AND BRAKE SHOE BACKING.TIGHTEN C - CLAMP JUST ENOUGH PUSH CALIPER PISTON BACK IN CYLINDER BORE TO REMOVE CALIPERS FROM ROTORS.TO REMOVE BRAKE CALIPER YOU NEED 2 OPEN AND BOX END WRENCHES ONE TO HOLD CALIPER SLIDE PINS AND THE OTHER WRENCH FOR LOOSEN CALIPER BOLTS.THEN YOU REMOVE CALIPER AND REPLACE FRONT BRAKE SHOES.IF YOU NEED TO REMOVE BRAKE ROTORS JUST REMOVE THE BRAKE CALIPER CARRIER SUPPORT BOLTS THE REMOVE THE BRAKE CALIPER CARRIER SUPPORT THEN REMOVE ROTOR.YOU NEED TO REPLACE BOLTS WITH NEWS AND USE LOCK TIGHT.THEN YOU PUT IN NEW BRAKE PADS IN CALIPER PUT CALIPER BACK ON SUPPORT CARRIER.REPLACE WITH NEW BOLTS USE LOCK TIGHT THEN TORQUE BOLTS TO 26 FT LBS.MAKE SURE MASTER CYLINDER COVER IN PLACE.WHEN YOU FINISH REPLACING BOTH FRONT BRAKE PADS PUMP BRAKE PEDAL TO SEAT BRAKE SHOES AGAINST BRAKE ROTORS SO YOU WILL HAVE FIRM BRAKES WHEN YOU APPLY THEM. THEN CHECK YOUR BRAKE FLUID LEVEL IN MASTER CYLINDER MAKE SURE ITS NOT LOW. MAKE SURE YOU HAVE FIRM BRAKES BEFORE DRIVING.IF YOU HAVE ANY PROBLEMS CHANGING FRONT BRAKE PADS YOU CAN GO TO ANY AUTO PARTS STORE AND BUY A HAYNES REPAIR MANUAL.
Jun 16, 2010 | 2004 Audi A4
Our car has been sitting parked for the past 8 months, today we tried to move it and the back brakes are locked, and the back wheels will not move? What could be the cause of this?
The bracke drum / Hand brake cable is stuck . Try to hammer the rear wheel centre and if the brake drum is stuck it wiill be released .
Also the cable of hand brake is stuck . try puling the hand lever of the hand brake up and down many times this may free it .
Mar 14, 2010 | 2000 Hyundai Elantra
Change back Brake pads on renualt megane 2
1. Hand Brake ON , loosen wheel bolts to hand tight, jack up front wheel , chock back wheels , put axle stands/blocks in place (just in case) .
2. Remove wheel. Disconnect pad wear wire , it pulls out of the connector.
3. Remove lower caliper bolt (at the back of caliper at the bottom) , need a 13mm ring spanner for head of bolt and 17mm to stop it spinning
4. Use a screw driver between the back of the outer pad and the caliper to prise the caliper back away from the back of outer pad. Pivot caliper upwards to rest on top of wheel disc (good idea to tie it up with some wire) .
5. Remove and discard old pads , clean out with wire brush and soft brush , don't breath in to much of the dust its nasty.
6. Fit new pads (remember pad wear sensor on inside pad), make sure that the pads are in contact with the disc , and the top of them sitting flush with the rim of the disc, don't force them into this position they should naturally sit there.
7. Lower caliper down into position, you may need to push back the piston further in order to make room for the new pads , do this with you hands or a small piece of timber. Keep an eye on the brake fluid resivoir , your pushing fluid back in so if its over full it may spill over. Refit lower caliper bolt (Renault say to replace this each time), and tigthen. Reconect pad wear sensor.
8. Pump brake pedal until normal brake pressure returns.
9. Remove axle stand/blocks , refit wheel and bolts , lower jack and tighten up wheel bolts.
Sep 18, 2009 | 2006 Renault Le Car
How to change back brakes? I can't get the brake cylinder to go in.
Do you mean back brake pads or the back brake callipers?
To change pads you need to use a rear brake pads changing tool to screw in the calliper piston or if you are experienced enough you could screw in the calliper with a two mm thick piece of metal sheeting that fits into the grove of the piston.
If you need to replace the whole calliper remove the hand brake cable first and clamp the flexible brake hose remove brake hose, remove the callier with cylinder and then remove the calliper holder. fit new holder pads and locks and the calliper with the piston and the brake hose and the hand brake cable. Bleed the brakes. Mike
Apr 26, 2009 | 2001 Volkswagen Beetle
Rear disc pistons, are they wind in? on a renault trafic van
these are a bastard, yes they are wind in. i have the proper tool, £300 this struggles, a cheap £60 sealey pisses the job. they have to turn and push at same time. tricky junk job. have fun.
Mar 14, 2009 | 2005 Renault 181
Jensen VM9510 Car DVD Player Logo
50 people viewed this question
Top Jensen Car Audio & Video Experts
xxxxxx xxx
Are you a Jensen Car Audio and Video Expert? Answer questions, earn points and help others
