Question about Frigidaire FEF352 Electric Kitchen Range
I have a Frigidaire FEF352A-WG Kitchen Electric Range. When we turn the oven on the display turns on but there is no heat. The stove top works but the oven and broiler do not work.
  • boyer425 Jan 30, 2010
    Is that called an ERC? Is there somewhere to find directions for replacing this?
    When I plugged that number in it says it's a stove clock/timer. Is this the part you're talking about? The clock and timer work on the range.
  • 1,531 Answers
This is usually a control board failure.
if the broiler and bake element.have continuity then replace the control board.if there is no continuity the replace the elements.
your problem lies in the control board.also make sure the power supplied is correct
Posted on Jan 30, 2010
  • seth adams Jan 30, 2010
    the part number is 316207511 they can run about $184.00 dollars.they are easy to replace just remove the back panel on the range top side rear the remove the four screws that hold the control in place.then you can remove the over lay and put it on the new control.
    yes that is the manufatures descrition of the part you need
No heat from burners or oven after relocating stove
Hi Ron - From what you have described if neither the burners nor oven turns on make sure the electrical connecting is 240V. The oven light and clock portions only required 115V. The clock and oven light working may indicate an electrical circuit breaker supplying the range is tripped or a fuse is blown. Confirm household circuit is correct and the range cord is properly wired to the terminal block.
Sep 16, 2012 | Frigidaire Gallery GLEFM397DS Electric...
Oven panel buttons will not turn on oven. Stove top works fine.
If your electric oven is taking too long to heat or just not heating up right, then check out this tip that will give more detail about your problem.
Oven Problems Electric Oven is Heating Slowly or Poorly
heatman101
Feb 06, 2011 | Frigidaire Gallery GLEFM397DS Electric...
Frigidaire electric stove, burners work oven does not. No clock
one of the stoves does not work. What could be the problem and how to fix it?
Thanks
Jan 06, 2010 | Frigidaire FEF336BC Electric Kitchen Range
Electric stove top and oven
hi
if neither the cooktop nor the oven works check your voltage. Is there 240 volts to the unit. Flip the breaker off and back on. If that doesn't work, with the unit unplugged, remove the cover where the stove cord is connected and check the connections
Good Luck!!!
Dec 10, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Stove won't heat
Oven was working, I had it on pre-heat, then I turned on the stove top, but the burners won't heat. When I turn on the stove top the stove makes a short BUZZ noise and the clock area lights up, when the burner is turned off all the lights go out. Please help, food prepared.
Thank You
Dec 02, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Oven cuts off
turn off breaker to oven pull stove out and check incoming power supply, possible looseconnection at that point
Feb 17, 2008 | Frigidaire FEF336BC Electric Kitchen Range
Frigidaire Electric Slide-in Range - Oven Flash
Richard, sounds like you did all the pretests. You'll need a new display panel. When you work on it, be sure to cut the power.
Dec 13, 2007 | Frigidaire FES367 Electric Kitchen Range
Stove top and oven will not heat
first check your voltage, and the pigtail connections at the stove, then check your elements inside the oven something has shorted
Oct 27, 2007 | Frigidaire FEF366DC Electric Kitchen Range
Frigidaire FEF352 Electric Kitchen Range Logo
219 people viewed this question
Top Frigidaire Kitchen Ranges Experts
Dan Webster
Dan Webster
Ismael Rodriguez...
Mike Carew
Are you a Frigidaire Kitchen Range Expert? Answer questions, earn points and help others
