Question about Indesit W 123 Front Load Washer
My Indesit Moon 1400 has stopped working. Shortly after the cycle starts the blue LED lights at start and 40 deg flash rapidly. Washing inside machine is soaking wet but has neither washed nor spinned. ANy help would be appreciated.
    New Friend:
My 1435 washing machine does not run it just takes the water in then drains out no cycle at all :-(((((
Posted on Aug 09, 2014
    Problem Solver:
  • 4 Answers
Mine started stopping half way through cycles then stopped all together, in the end it would switch on,all lights ok, select any program, the door would click to lock then nothing(did notice the little red led light beside the key stopped working) no water feed, no drum turning nothing! Thought the pcb needed repair or reprogram? Turned out to be a bad spade connection to the brushes on the main motor! All working 100% now
Posted on Oct 06, 2011
Tom, I'm having exactly the same problem, Have you managed to solve it? The Service center will no even tell me what's wrong with (they're quite keen to get me to arrange a visit from their engineer for £110 though). Thanks
Posted on Apr 23, 2010
Indesit washing machine
Indesit Washing Machine lWB5113 Flashing Lights(Faulty ...
? 3:34
www.youtube.com/watch?v=-lnfePzPwTQ
Jul 29, 2012 - Uploaded by porracaralho caralho
Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
How to repair Indesit washing machine that is Flashing ...
? 0:43
www.youtube.com/watch?v=Q9Yq2Cz8UFE
Jun 26, 2011 - Uploaded by XR600RQJ
Washing machine Indesit starts to flash for longer and longer ...How do you unlock the door when the power is off?? every time i turn it ... My washing maschine ( Indesit WITXL 129 ) had the same problem - 6 from 9 LED lights ..
Oct 14, 2015 | Kenmore 24032\24036 Top Load Washer
Power indicator and rpm indicator flashes
See:
? 3:34
Jul 29, 2012 - Uploaded by porracaralho caralho Indesit Washing Machine lWB5113 Flashing Lights(Faulty).mp4 .... older model- stopped in rinse cycle/flashing power and rapid wash lights- ...
? 0:43
Oct 14, 2015 | Washing Machines
Flashing lights
There is a Light Flashing on my Indesit Washing Machine
Many of our newer Indesit Washing Machines have a series of indicator lights, which flash to indicate a possible fault on your installation or simply to let you know a problem occurred whilst you were away from your Indesit Washing Machine.
Pre wash light flashing
Indicates a failure of your Indesit Washing Machine to fill correctly. Check your fill hoses for a blockage, a leak, a kink or to make sure that they are turned on.
Wash light flashing
Indicates that your programme dial has been moved from its original position. Simply returning the wash dial to its original position will restore the light to its original status.
Spin light flashing
Indicates that the Indesit Washing Machine has considered the wash load to be excessively un-balanced. Open up the door of the Indesit Washing Machine, re-distribute the garments and retry the spin to resolve this.
End light flashing
Indicates that the Indesit Washing Machine has reached the end of a wash programme.
Wash, rinse and spin lights all lit at the same time would indicate a possible blockage in your under sink wastes system. Check out the additional informationin our 'My Indesit Washing Machine Will Not Empty'
Aug 22, 2012 | Indesit Washing Machines
Indesit widl102 washer dryer has 2 led lights flashin
unplug it for a few minutes and plug it back in again might be a pain but till you can get it serviced it should delete the fault code and run thru a full cycle. hope this helps a little.
Not a true fix just a work around.
best to you.
Nov 30, 2017 | Indesit W 123 Front Load Washer
Lights flashing on indesit WIL123S
Hi, sounds like you need to change the door interlock located where the door catch pushes into.
Take the top off and undo the two screws with a tork screwdriver
and replace.
(Remember to turn off the supply and pull out the plug top)
May 09, 2009 | Indesit W 123 Front Load Washer
Indesit WIDL 106 wont start -ON/OFF-Door Led Flashes rapidly
It is a defectiv controller pcb. I think the eeprom on the controller pcb lost its program (happens often on Indesit machines).
The only solution I know is to change the controller pcb, - not a cheap solution.
I have the same problem with WIDL 106.
Dec 01, 2008 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
1,150 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
