Question about Whirlpool Ultimate Care II LSQ9564J Top Load Washer
Doesn't agitate. I can't remove the dog assy. It's a 2 piece agitator
    Genius:
  • 1,122 Answers
Pull the whole thing out,there are 4 tapbs holding the dogs in,you can try to bend the tabs alittle and pull on it,or do like i do and hold the bottom of agitator with your shoes and pull like hell-mike
Posted on Jan 30, 2010
Whirlpool stylemaster 4217141 REV A Agitator/spin cycle broken upper agitator spins by hand but tub won't spin
open the lid and get a model #, sound like all you need is agit dogs # 80040. then remove top of the agitator, could be a softener dispenser. under that you will find a plastic cap, pull up with needle nose pliers. under that you will find a 7/16 or 1/2 bolt, remove the bolt and the agitator can be lifted off. the agitator can now be split into to pieces, turn the top half over and the assy with the agit dgs will fall out. simply replace and reassemble and DO NOT OVER TIGHTEN BOLT. just snug it up. should be fine.
Jan 02, 2012 | Washing Machines
Tip
Whirlpool: How to replace the dog kit of direct drive washers
How to replace the dog kit in agitator
To replace the dog kit in the agitator, remove the top cap/rinse dispenser and the inner bolt cover. Remove the 7/16" bolt and lift the agitator out of the washer. Separate the upper and lower pieces of the agitator and replace the dog kit inside the upper part of the agitator. Make sure the 4 pieces remain in place while putting the agitator back together.
on Feb 12, 2010 | Washing Machines
Is the upper part of the agitator supposed to spin with the lower part? It spins freely when I turn it, but doesn't spin when spin cycle is activated during a cycle.
You have bad agitator dogs . Easily replaceable and inexpensive . Remove the center bolt holding the agitator on and seperate the 2 agitator pieces . You will see 4 teardrop looking pieces ( dogs ) . Replace and your done .
Jun 29, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitator doesn't engage in roper AX5133 washing machine
Check these excellent youtube videos out I found while a surfin this here world wide web.
Old school washers:
Newer models:
May 29, 2010 | GE WWSR3090TWW
Should you be able to turn tke adgatator by hand with ease? it sound the washer makes when adgatating is not the same it made in the past and it seems to be slipping.The washer was new in 2005 or 2006.
Your agitator dogs are stripped out. Pry off the top lid of the agitator. Reach inside with a pair of pliers and pull the plastic tab loose. Take a 7/16 socket wrench and a extension to remove the bolt inside. Pull up sharply on the agitator to remove it.
Take the center piece holding the rubber dogs out of the agitator. Replace the 4 tear shaped dogs and re-install the agitator.
Nov 08, 2009 | Kenmore 24032\24036 Top Load Washer
Agitator top does not move during cycle. Bottom
Hi, You will need to change the dog kit inside the agitator. Remove the cap on top of the agitator and you will find a 7/16" bolt. Remove the bolt and seperate the agitator. The dog kit is located betwee the 2 pieces.
Please let me know if this helps you or if I can assist you further.
Thanks
Vic
Jul 16, 2009 | Washing Machines
Replacing the agitator dogs in a Kenmore 80 series washer
Hi, Remove the cap on the agitator and then remove the inside cover. There is a 7/16" bolt under the inside cover. Remove the bolt and the agitator will lift out. Seperate the 2 pieces of the agitator and replace the dogs. You might have to use a flat blade screw drive and punch out the 4 tabs around the bolt hole in the agitator if this applies.
I hope this helps you. Please let me know if I can assist you further.
Vic
Jul 03, 2009 | Washing Machines
Agitator does minimal agitation
Hi Omni,
The Agitator "dogs"/cams have given up the ghost and need to be replaced. Access to them is easy. Before starting the repair, have this part in hand.
Here's a tool list;
1.) small flat screwdriver (to remove the top part of the agitator)
2.) 3/8" ratchet
3.) 8" X 3/8" extension (for the ratchet)
4.) 7/16" socket
Take a gander at this pic... you'll be going after #10 'cause that's the problem.
All you gotta do is remove the top parts from the agitator to access it. See #2 in the diagram? That's the bolt holding the agitator to the transmission shaft. Remove that, then lift the whole agitator out of the tub. Now place the agitator on the floor and put both of your feet on the base. Now lift the agitator (#3) off the base (#4). Place one of your hands into the opening of the top of the agitator (to hold the cam (#9) in place) then turn the agitator over. The cam will slide right out.
Now you'll see the cam "dogs"... little white curved plastic doo-hickeys. All you gotta do now is install the new cam assy. and rebuild the agitator! Cool, huh? All it takes is about $15 bucks in parts and ~20 minutes.
Let me know if you have further questions. And don't forget to rate my solution as "FixYa"! Thanks, BB
Apr 14, 2009 | Whirlpool LSQ9610L Top Load Washer
Whirlpool Ultimate Care Washing Machine Agitator
after removing the agitator from the machine (7/16 bolt) i place the agitator on the floor, step on either side of it and pull up on the top half, ittl come loose, needs a little help! a word of advice though is after replacing the agitator dogs, turn the entire agitator upside down and insert the bolt through the entire agitator assy and keep constatn pressure on the bolt as you turn it boack over and try to realign with thte tranny shat. ( you see the parts wanna seperate as you try to reinstall them otherwise)
Oct 26, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
How to replace agitator dogs
Remove the bolt and pull the entire agitator off. Turn upside down and separate the two pieces. You'll see the part that holds the dogs in place
Jan 04, 2008 | Estate TAWX700JQ Top Load Washer
Whirlpool Ultimate Care II LSQ9564J Top Load Washer Logo
67 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
