Question about GE GSS25JFM Side by Side Refrigerator
Refrigerator left open for a few hours, and doesn't seem to work.
Refrigerator side of the side-by-side left was open probably at least 8 hours. I found it slightly open when I came home from work. It wasn't making the usual hum, not getting cold. Freezer side seems to be working fine.
  • 116 Answers
SOURCE: control panel for freezer and refrigerator
Behind the back panel of the freezer section is the evaperator assembly. on the rh side of the evaperator is a sensor pack that is for the defrost cycle. there is a thermo fuse inside of this pack that is open. The fridge goes into an error state if this fuse is open. unplugging the fridge resets the system. the sensor pack will have to be replaced.
Posted on Apr 27, 2007
watugot
  • 290 Answers
SOURCE: freezer works but fridge remains warm.
The same fan that circulates air in the freezer also blows air in to the fridge. If you open the freezer door and hold the door switch closed you should hear the fan running. If not you have a failed motor or motor control. Look at the back wall of the freezer section and see if there is a heavy frost build up. If so. you have a defrost system problem. Please post back with what you find and with the complete model number and I will try to walk you through the steps of checking everything.
Thanks/Mike
Posted on Oct 27, 2007
zeusfaber
  • 247 Answers
SOURCE: left refrigerator door open over night, next day it stopped working
If this is a frost-free model with the evaporator buried in a tunnel behind the cabinet, there's a good chance you've just got it thoroughly iced up inside.
I'd be tempted to see if you can borrow some space in a neighbour's freezer for a day or so and turn your freezer off for 24 hours (with the door propped open) to defrost thoroughly.
Once all the ice has melted and you've mopped up all the ensuing mess, I think there's a good chance all will be well again. Even if it isn't, you haven't really lost anything through trying.
A.
Posted on Apr 16, 2008
  • 172 Answers
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 17, 2009
  • 12 Answers
SOURCE: My whirlpool refrigerator (8 years old) is not cold and hums
Possible of 3 reasons.
1) Defrost bimetal is open and not allowing power to heater element in evaporator coil in freezer.
2) Defrost timer is not going into defrost, motor stopped moving.
3) Evaprator fan motor is not rotating. Possible motor.
First check for frost in the back panel of the freezer section.
if there is frost and the fan is operating, would suggest manually putting unit into defrost, depending on particular model. may be a switch you can move with a standard screw driver to get the fans and compressor to shut off. If you find this either. Top of fridge in refrigerator section below temperature selection controls. Or remove toe plate, the pretty decor under the door. and it will be in there.
If this is an electronic style, look under that toe kick and there is a technician's sheet that will explain how to get into defrost.
Allow 10 minutes for heater to heat, listen for water sizzling on heater element. if this does work. you will need the defrost timer.
Hope this helps.
Posted on May 14, 2009
I have an admiral refrigerator admiral designer series 21.1 cu ft.the motor is constanly running 8 to9 hrs at a time the left side of the door is always hot and the top of the refrigerator a repairman came...
yes compressor runs and shuts off every 8 - 10 hours for a half hour for defrost system mode. but ur hot left side may be a sign of issues needing to be addressed>
FRIDGE COILS or door walls SEEM VERY HOT:
The condenser coils do get hot. They can even be to hot to comfortably touch and this is normal.
The refrigerator should not run constantly but shut off with each defrost cycle.
Running constantly and never cycling off can indicate a cooling problem.
One thing to try is to wait till it has been running a few minutes then open the door and turn your cycling thermostat towards the off position. It should cycle off before getting to the off position on the dial.
If it does not cycle off then it's not getting cold enough to satisfy the thermostat. This is likely the reason the refrigerator runs all the time.
A thermometer in a glass of water can be used to check the temperatures in the refrigerator section.
You can check that all fans are running.
Feb 26, 2015 | Admiral Refrigerators
My Samsung RB215LASH Refrigerater the freezer is set at -2 was on 8 and the door was left open for most of the day, it seems that know it is taking forever to freeze
It may take up to 24 hours for it to get back to normal and stabilize again...also don't be surprised if a bunch of water runs out the bottom when it goes to defrost the next time... you left a lot of humidiy in there with the door open...
heatman101
Apr 21, 2011 | Samsung RS265LBBP Side by Side...
I have whirlpoll side by side model gd25dfxfh182 and it stopped getting cold enough so i cleaned the coil that was extremly dirty thinking that might help it took good 8 hours to get fridge side down to 38...
IS THE FANS WORKING? DEFROST IT GOOD WITH A FAN BLOWING IN THE FREEZER SIDE FOR A HOUR, IF YOU SEE A BUNCH OF WATER ON FREEZER SIDE BOTTOM , YOU KNOW IT WAS THE PROB. LISTEN CLOSE FOR FAN WHEN YOU OPEN FRIDGE SIDE DOOR.. #2 DEFROST TIMER
May 25, 2010 | Whirlpool GS6NBEXR Side by Side...
Refrigerator won't cool
MUST DEFROST LEAVE IT OFF FOR 24 HOURS .
Apr 07, 2010 | Kenmore 57029 Side by Side Refrigerator
Freezer not cold enough
Begin by turning the freezer temperature setting dial to a lower setting. Then wait a few hours to see if your problem is fixed. If that does not correct the problem you probably need to have the coolant system recharged. That requires special equipment so you will have to call in a repair person.
Dec 29, 2008 | Frigidaire FRT21H8 Top Freezer...
Refrigerator not cooling but freezer is
Something has stopped the cold air being ducted from freezer side to refrigerator side of things. Possibly duct blocked due to ice build up, evaporator not self defrosting etc. Turn unit off for a few days till it melts and then turn back on. If it was because a door has been left slightly open you will be ok. If for any other reason you will want to have it serviced in the next week or so.
Mar 17, 2008 | Maytag MZD2766GES Side by Side...
Freezer was left ajar & now Refrigerator does not work properly
you have ice build up on the evaporator. two ways to cure. first switch off for 24 hours and leave with doors open. second switch off. remove back panel inside freezer and melt ice off with a hair dryer
Jul 06, 2007 | Amana AFD2535DES French Door Refrigerator
GE GSS25JFM Side by Side Refrigerator Logo
90 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
