Question about Toshiba Satellite A205-S4639 Notebook
My Toshiba Satellite A205 Battery
Is it alright to plug my battery in every time I use my laptop? I mean, will it hurt the battery? I think I heard that over charging certain batteries can be bad for them.
Also, will letting the battery run out of power help it or hurt it?
Are there any battery-care instructions that would be helpful to know?
Thank you very much for your help.
Chris Santoro
cjs81@yahoo.es
  • Marty marty May 11, 2010
    NiCd (nickel-cadnium) batteries are prone to a "memory" effect where they tend to not charge fully if they are ever charged before full discharge. These should always be fully drained before charging. These type chargers sometimes have a "refresh" feature that drains them first. Ni-MH (nickel magnesium hydride) and Li-ion (lithium ion) batteries are "memory-free" batteries. What is your type?
  • 689 Answers
Laptop's battery is IC controlled. Circuit will stop the current when battery charged enough. So Battery will remain unused. However its also could be good idea to release the battery and keep dry place if you are using the laptop permanently stable AC power. If you need further assistance post your question.
Good Luck
Posted on Feb 18, 2008
Where is the cmos battery on satellite a205-s5308
What were the Toshiba Engineers thinking. Take a look at the :http://www.ehow.com/how_5136793_replace-cmos-toshiba-satellite-laptop.html
Dec 17, 2012 | Toshiba Satellite A205-S5803 Notebook
Toshiba a205-s4707 will not boot windows from any location.
You didn't mention the DVD/CD rom? Shut down, unplug, remove battery, plug in reboot and try this procedure: http://www.ehow.com/how_5766144_restore-satellite-laptop-factory-disc.html
Dec 16, 2012 | Toshiba Satellite A205-S4707 Notebook
My battery charges but only lasts about 20 minutes once it says it is fully charged. Just purchsed a new battery thinking it was old (laptop is about 3 years old) and the same thing happens.
From what you describe and assuming the new battery was "new", I'd say you have an internal short which is draining the battery over a short period of time. I'd also investigate the accuracy of the battery charge indicator. Download this free utility which will give you a more accurate picture of your battery:
http://www.mioplanet.com/products/batterymeter/
I'm assuming you gave the battery a "commissioning charge" when you bought and used it?
If not, this is something you should do with all new LI batteries. This bit is reproduced from a website that sells batteries for the Toshiba satellite series:
"2. The new Toshiba Satellite a205-s4777 battery pack needs to be circled (fully discharged and recharged) three to five times to reach its optimum performance.
3. Toshiba Satellite a205-s4777 battery will undergo self-discharging when left unused for a long period of time. Thus, it should always be stored in a fully charged state and kept in a cool, dry and clean place.
4. It is normal if the new Toshiba Satellite a205-s4777 battery gets warm when being charged or used. However, please pay special attention if the battery pack becomes excessively hot. This may indicate there is a problem with the charging circuit of the electronic device. Please consult a qualified technician if necessary.
5. To maintain the optimum performance of Toshiba Satellite a205-s4777 battery pack, it is highly recommended to circle (fully discharging and recharging) it at least once a month.
6. New batteries are hard to be charged. Sometimes, your electronic device may indicate a fully charged condition about 10 to 15 minutes when Toshiba Satellite a205-s4777 battery pack is being charged for the first time. When this happens, remove the battery pack and let it cool down for about 10 to 15 minutes then repeat the charging procedure. Sometimes, the new Satellite a205-s4777 battery will suddenly refuse to be charged. If this happens, a suggested solution is trying to remove the battery from the device and insert it again. "
Jul 21, 2011 | Toshiba Satellite A205-S4777 Notebook
Toshiba Satellite a205 the battery light started
I think you may need a new power supply, check this to make sure it is working OK, If this isn't working then the battery will not charge, and give symptoms you describe.
Feb 20, 2010 | Toshiba Satellite A105 Notebook
When i plug in my toshibba satellite a205, the plug light turns on, but the batery charge lights flashes just once, then goes off. my battery says 2%, not charging. is it a battery or combination laptop...
True turning it on while pluged in but without the battery in. If it works its your battery if not it is you charger or laptop, my bet is on the charger they have a tendancy to go out.
Feb 14, 2010 | Toshiba Satellite A205-S4777 Notebook
My toshiba satellite a205-5804 has a problem with the main board, when its plug in it freezes but when not , when is used whith the battery it works alright. a repair center told me is the main board, but...
Are you using the original charger or a universal replacement? As loose fitting power plug can cause this problem but so can a loose connection at the power jack (repairable) or a cracked trace on the main board from stress at the power jack (not usually repairable - ie needs a new board). JC
Nov 17, 2009 | Toshiba Satellite A135-S2276 Notebook
Toshiba Satellite A205-S5814 laptop will not power on
clear the bios by removing the small battery on the mainboard for 10 hours.the power on
Jul 30, 2009 | Toshiba Satellite A205-S4617 Notebook
Toshiba Satellite A205-S4639 Notebook Logo
65 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
