Question about HP Compaq Presario SR1830NX PC Desktop
Compaq presario doesnt boot upon powering up
At power up, i hear fan whirling and orange "disk activity" disk light flashes but system doesn't boot up
    Scholar:
  • 94 Answers
Boot into the bios or if bios support diagnostics boot into that (typically F1 of F10 on power up) If that is not an option boot off the CD recovery disk and run diagnostics on the HD. Let me know we can take it from there.
Posted on Jan 30, 2010
Compaq presario 56000cl won't boot up / red light flashing in the back.
When you press the power button do you hear the fan running, hear the disk drive running, see any lights, do you hear the cd drive click once and see the light come on briefly on the cd drive door? If you see all the aforementioned then it is surely trying to boot. Computers don't boot mainly because of the following problems. 1) Bad Power Cord or Power Supply. 2) Electro Static Buildup. 3) Bad Motherboard 4) Bad boot or system files.
Remove the Power Cord and the battery if it's a laptop. Press and Hold the Power Button for 30 Seconds. Then replace only the Power Cord and try hitting the Power Button. If it boots you had an Electro Static Buildup. If you have boot or system files that are missing or corrupt normally the system will be telling you that on an error message that appears on the screen. Does your system show you anything on the screen when you press the Power Button? If not you have a Power Supply or Motherboard issue.
Mar 18, 2012 | Compaq Computers & Internet
My HP Compaq Presario SR2170NX starts up but won't load
  • Make sure you computer is powered off
  • Turn your computer on and start hitting the F8 key
  • An Advanced Boot Menu will come up with an option to boot into safe mode
Restore your PC to the date when its performance was good.
Use a system utility software like RegInOut to fix this issue.
Hope it works for you.
Dec 26, 2011 | HP Compaq Presario SR2170NX (RK549AA#ABA)...
After powering on monitor says no sync
I've almost the same problem. When the system turns on the monitor doesn't sync. After a variable trials with down/up the sync is enabled and the computer starts.A very clear event occurs : when the monitor can''t sync ( and system doesn't boot)you can hear very clear a high fan rotation. When I look/hear in the system the Isuspect the cpu fan. The system boots ( monitor syncs) when the fan rotationgoes from high to low. So the system hangs on an internal check on the rotation speed of the cpu fan.I've googled a lot , but until now doesn't find an answer . Possibilties which I think about : replace cpu fan , clean cpu fun ( but it looks clean).I cannot measure the fan rotation speed when the system is hanging. At normal rotation all info can retrieved witth the program cpu-z.Did you already have a solution ?
Dec 07, 2011 | Compaq Presario 5000 PC Desktop
Compaq Presario laptop C300 - issues (orange light)
Sometimes when a PC gets stuck in hibernation mode, the only way to reset it is to remove the CMOS battery for 10 minutes and replacing it. It resembles a large watch battery and is usually located near the center of the motherboard.
Dec 16, 2009 | HP 435768-001 - Compaq Presario C300...
Compaq presario sr215onx wont boot up
Go to bootdisk.com and download boot files for your operating system (ex. Windows XP). There are software for floppy disk which is the easier way to get your boot files. If you do not have a floopy you will have to get the CD files, there you have all the instructions how to get the CD. Once you get the files, insert the floopy or the CD and reboot your computer. The filse should be installed automatically, if not do it manually and reboot computer again.
Oct 29, 2009 | HP Compaq Presario SR2150NX PC Desktop
Upon booting, fans whirl and I can hear HDD
Sounds like your graphic card is not working. Try replacing that. Check and make sure you have the cable plugged into the right port in your graphics card.
Aug 27, 2009 | Acer AM5641-B5560A Desktop PC & Monitor...
Flashing lightning bolt on Compaq C300
This sounds like a battery problem. The best way to test this is to remove the battery and then power the laptop up with just the power cord plugged in but no battery. If the computer boots then the battery is bad you will need a replacement. Also try letting the battery charge for a day. Be sure that the charging light is coming on when you have it plugged in.
Dec 09, 2008 | Compaq Presario Notebook
"Disc Boot Failure" upon powering up the compaq
your harddisk is not detected.
open your cpu case.
then reattch the power code and datacode to hard disk.
Nov 03, 2008 | Compaq Presario S6300NX PC Desktop
Wont Boot Power Light Flashing orange
onbord video maby might wann add pci card video see if u get screen ok thx nick
Feb 06, 2008 | Compaq Refurbished TC2120 (c23742001)...
No screen and no sound but i can hear the fan and processors sound in the back
Hi dheerendra let me know the display massage when you are start your system by pressing the power key. let me know are you able to boot the system or not. Try to put windows xp bootable cd in drive and choose boot from cdro option in cmos setup. when setup is started then choose repair option.
Jun 26, 2007 | Sony VAIO VGN-SZ460N/C Notebook
HP Compaq Presario SR1830NX PC Desktop Logo
376 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
