I disconnected the cord to move the tv and then when I plugged it back in I got a green blinking light and does NOT stop. Called customer relations and all they told me is to hit the reset button. The TV is a Mitsubishi WD -62725
  • 438 Answers
I assume the reset button did not work, you may have inadvertently caused a power spike that did some damage, try unplugging the TV for 10 or so minuets then plug back in, if there are no functions it must be serviced
Posted on Jan 31, 2010
Red light blinking
blinking of red light indicates that fault in main board or related boards. you need to open back cover remove each cable connected with main board one by one & put on tv after each cable is disconnected. if red light stops blinking on disconnecting any of the cables, that means related board is defective, if it does not stops blinking, check the power supply is generating proper voltages. if it is ok that means the main board is defective.
Sep 26, 2011 | Panasonic TC-32LX24 32 in. LCD TV
Unplugged my Ws-55711 TV to move it to another room so the carpet could be cleaned. When I moved it back and plugged it in, the green light kept blinking for more than 60 seconds. I unplugged the TV for...
Open up the front, look under the right side picture tube. Look for puddle of oil on signal board. If you see this, it has bad picture tube & signal board. Not a good repair.
Jan 17, 2011 | Mitsubishi WS-55711 55" Rear Projection...
I noticed that there was a green blinking light on the front pannel of my WD-62525 TV. The TV would not power up. The cable sound was OK..I disconnected the power Cord for the TV from the wall. Waited 10...
The DM pwb is about 300.00 but it sounds like the caps have failed in the DM which is a 35.00 kit which includes the caps and detailed instructions. Its called the V26 DLP DM repair kit. You can get it at www.tvrepairworld.com
Aug 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Computer won't turn on
If the only light you get is a green blinking light in the back of the computer, odds are that your power supply stopped funcitioning properly.
The good news is, it is a relatively easy part to get and install, but you will want to be sure you get one with adequate power for your system.
Additionally, some systems have custom built power supplies, and can be expensive. If you go buy one, be sure to take your old one in for comparison.
Good Luck
tony
May 18, 2009 | Computers & Internet
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Green light blinking
The green light on the front blinkes and does not stop even after hitting re-set button.
Oct 26, 2008 | Mitsubishi WS-65513 65" Rear Projection...
Blinking Green Light of Death
I had this similar problem TWICE!!!. I called around for a repairman and they charged over $300 dollars to repair (HELL NO). Anyways I took a trip to Vegas hoping to win some of the money to repair it and left the TV plugged in and BLINKING during my trip. When I came back it was not blinking anymore and I got curious. Well I pressed the power button and to my surprise IT TURNED ON!!!!. A month later I moved to a different house and unplugged my TV to move it and when I plugged it in the DAMN BLINKING GREEN LIGHT OF DEATH was back. Well I thought I'd get lucky again and leave the blinking on, well 2 days later the blinking was gone and ONCE AGAIN MY TV WAS ON...... I hope this helps and works for other people. My point is, before you pay for a technician to repair it and before you give up on your TV and unplug it, Try leaving it on BLINKING for a few days and see what happens.
GOOD LUCK GUYS.
Oct 07, 2008 | Mitsubishi WS-55613 55" Rear Projection...
Toshiba lcd tv 17" 2003 model
I called my Brother in Law whom is an Electrician. He basically told me the same answers that your experts have told others. We're all pretty sure it's the cord, just haven't decided if it's worth it to spend 60 bucks on a new cord.
Thank you,
I'm sure We'll be back!
Posey88
Jun 10, 2008 | Toshiba Televison & Video
Power button blinking green
disconnect the power cord overnight try it if ok change power cord cheers
Dec 29, 2007 | Panasonic PT-40LC12 40" Rear Projection...
Green light just blinks
Four bad 1000mf/25v caps in DM module = Common repair
for qualified Mits tech..................................T.
Nov 11, 2007 | Mitsubishi WS-48513 48" Rear Projection...
Televison & Video Logo
51 people viewed this question
Top Televison & Video Experts
Electro Med Services...
