Question about Dryers
Kenmore series 90 dryer(5 years old). Power ok
Kenmore series 90 dryer(5 years old). Power ok (light on inside). Dryer will not start/operate. Fuses (2) in back look good and continuity checks ok. Door swithch appears ok, continuity checks ok. and can hear click in timer when closed. Motor looks very good. turns good. What next? What am I missing?
    Genius:
  • 1,122 Answers
Have you checked the start button?
Posted on Jan 31, 2010
Where to find fuses. My dryer is not heating up.
Does your dryer have power? If yes, then check (1) the flow of air outside the house from your dryer tube and (2) your circuit breaker panel for each circuit in the house (I've not seen fuses/breakers built into dryers -- though that could change). Then check (3) your heating element, (4) thermostat, (5) high-temp thermal cutoff switch, and (6) for debris in the air flow path to / from from the centrifugal fan.
Here are 3 resources that helped me with my Kenmore Series 90 Dryer:
No Heat? - http://chris-doityourselfrepair.blogspot.com/2011/10/kenmore-90-series-model-110-clothes.html
Looking Inside My Dryer - http://chris-doityourselfrepair.blogspot.com/search/label/Disassembling%20Kenmore%20Dryer%2090%20Series
Exterior Exhaust Duct - http://chris-doityourselfrepair.blogspot.com/2013/08/cleaning-out-and-replacing-exhaust-duct.html
Oct 10, 2014 | Kenmore Dryers
My Kenmore series 90 Gas dryer doesn't heat up.
This dryer is what I like to call a 4 wheel drive model. Because it has wheels on the front as well as the back. To access the gas assembly you pop open the bottom panel. Strat the dryer and observe the gas assembly. You should hear a click and then the ignitor should glow. Next the flame sensor should trip and cause the ignitor to shut down. The gas will now be allowed to come out and fire off a blast.I have 2 home videos. on shows the operation and replacement of the coils. The other is of an electric model but shows how to put the dryer together.
Sep 21, 2012 | Kenmore 73052 Gas Dryer
My Kenmore 90 series electric dryer not running
http://www.washerwizzards.com ,,,,check the thermofuse in the back,,it is a white fuse coverd in plastic with 2 wires attached ,,,,hook the 2 wires together and test it
Dec 23, 2009 | Kenmore 63942 Dryer
Kenmore 90 series, 7 years old, no problems til now. all of a sudden, 3rd load of laundry of the day, press start button, nothing happens. There's power to the unit as the light goes on when the door...
That doesn't mean there's power to all parts of the dryer though. My Kenmore used to run but not heat & invariably a wire was burned through at the end - they get brittle after a while. I'd unplug the dryer - very important - open the back & look for a wiring problem. I could usually shorten the broken wire & make a good connection again. After years of patching it up we gave up we got a new dryer.
Nov 25, 2009 | Refrigerators
9 yr old Kenmore 90 series dryer wont heat
is it gas ? next time open dryer door and send full model number if it heats for a while you have bad gas coils,when you change them out watch out for the coil with three prongs on it,there is a metal piece that sometime gets stuck in old coil when you remove it,if it happens just poke it out of old coil and slide it back on post where new coil will be installed
Nov 07, 2009 | Kenmore 63942 Dryer
Dryer wont run but lights are on
check the door switch.or you may need to replce the main control panel. but you also need to check the thermal fuses inside the dryer cabinet,one of those can be bad.
Sep 26, 2009 | Frigidaire Electric Dryer
Kenmore 90 series propane gas dryer
Hi, You should not have a pilot light, There are electronic ignitors on the dryers. Unless this dryer is 40 years old, just start the dryer and the heat should come on.
If the heat does not work, there must be another issue.
Please let me know if I can help you further.
Thanks
Vic
Jul 21, 2009 | Kenmore 63942 Dryer
Kenmore 90 Series Dryer start button humms, but that's it.
MOTOR HAS GONE BAD,IF YOU WANT TO TACKLE IT THE MODEL NUMBER IS INSIDE THE DRYER DOOR,YOU MIGHT FIND A GOOD DEAL ON EBAY OR GO TO SEARS.COM UNDER APPLIANCES,LET ME KNOW AND I WILL HELP YOU WITH IT-MIKE
Mar 06, 2009 | Kenmore Dryers
Kenmore 90 Series Electric Dryer will not run
chech to see if your belt is broken. It may have a belt switch
Oct 28, 2008 | Kenmore 62602 Electric Dryer
Dryers Logo
209 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
