Question about Sterling RF75 Natural Gas Heater (75,000 BTU)
On a rf 60 fan will not come on
  • 20 Answers
If the flames come on, but the blower doesn't i would think it to be a bad fan motor. The easiest way to check without tools is to let the flames go for about 5minutes, then listen to hear a humming coming from the motor. If possable feel the motor, if it's hot, it's toast! be careful, as it might be hot enough to burn skin, so tap it first! If it's hot or humming, and not blowing, it's shot!!
Posted on Feb 01, 2010
What is wrong when I receive error code Er rF
Hello Anonymous!
Error code Er rF is an :Abnormality of BLDC FAN Motor for Freezer.
  • The freezer fan motor may be Defective.
  • Unplug the fridge for about 30 minutes and plug it back in, if the code appear again within 24 Hr , the Main Board might be defective too.
  • Check if the freezer fan is blowing normally, then the Main board has a problem.
  • If not, the Fan Motor is defective or both.
  • I would change the Fan first then the Main PCB
Good Luck,
JP
Jul 09, 2015 | LG Stainless Steel French Door...
1999 Dodge Neon Issues (HELP)
Here's a link to the P0340 code,and P1491.Powertrain Diagnostics Manual P-1491 Radiator Fan control relay circuit
Set condition: An open or shorted condition is detected in the radiator fan relay control circuit.
Possibilities:
Fan relay ground circuit open
Fused B+ circuit open
Rad fan control relay defective
RF relay output circuit volt cycles over to batt voltage
RF relay control circuit open
RF relay ctrl rly ckt wir harness observable or intermittant defect
RF relay ctrl ckt short to ground
Defective PCM
Get out your Multimeter.
Mar 22, 2013 | 1999 Dodge Neon
Icom IC-7200 transmit problem on 1600.000 kHz to 1999.999 kHz
If the radio is made to be sold only in the US then the phase lock loop is disabled when your are trying to transmit out of the US band edges. Try looking up a MARS circuit mod for this model and it amounts to only clipping one end of a diode to enable the transmitter on all frequencies.
Nov 12, 2017 | Icom Radio Communications
Is my remote ir or rf?
it;s easy to tell, look at the unit, if you can see diodes, then it is IRed, If NOT, then it is RF, usually these are IRed.
Apr 06, 2010 | Hampton Bay 52 In. White Redington...
Similar problem
Your fan receives RF signals from the remote for control. It may be picking up stray RF signals from a neighbor. Try re-programming your fan/remote to a different frequency.
(RF=radio frequency)
Jul 01, 2009 | Dryers
RF-69nr
The motor sells for about $140.00. I would check here https://www.centralvacuumstores.com/fan_help.php
or here http://nutone.com/
Jun 15, 2009 | Broan-NuTone N-RF69NR Attic Fan Attic Fan
New 60 in mitsu set up will not take
Make sure you're TV is set to either the main RF input or the AUX or 2nd RF input. If you are trying to auto program the TV in any of the video modes, input1,2,3 or component1,2, HDMI, etc. you cannot access this function.
michtech
Feb 10, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Sterling RF75 Natural Gas Heater (75,000 BTU) Logo
176 people viewed this question
Top Sterling Heating & Cooling Experts
Paul Carew
bobalix
deton8 von Splosion
Are you a Sterling Heating and Cooling Expert? Answer questions, earn points and help others
