Question about 2wire (1000-400108-001) Router
Help trying to use laptop with my router 1700hw and it says limited or no connectivity
HI,
PLS. FOLLOW THESE STEPS.
START----SETTINGS----NETWORK CONNECTIONS
STEP-2
RIGHT CLICK ON ICON GO TO PROPERTIES
SELECT INTERNET PROTOCOL AND CLICK ON PROPERTIES
MAKE SURE THAT OBTAIN IP ADDRESS AUTOMATICALLY SELECTED
CLICK OK RESTART MACHIN AND SEE WHETHER PROBLEM SOLVED OR NOT
Posted on Feb 18, 2008
    Novelist:
  • 142 Answers
If ur using WIFI with ur router, then there are two possiblities
either the wireless encryption key or WPA password that you are trying to enter is incorrect
Make sure the wireless key is correct.
If u dont know how to get the wireless key then contact 2 wire people and they will give u the key.. or contact ur ISP and check whether they support 2 wire or not so that they can provide the wireless key
second reason might be you are not getting the correct ip adress from ur router
try to reset the router and restart the router and the check whetrher ir works or not ,,, it will give u correct ip which will hopefully resolve the problem
If ur using LAn connection not WIFI then also try to reset the router
Check if this works or not....
There can be many other reasons as to why this is not working
but the steps that i have told you are the main reasons for this to happen..
you can contact me if problem still occuurs
email2rohit21@yahoo.co.in
Trying to connect to my wireless router belkin n150 with my laptop compaq presario 2500 have a yellow triangle saying limited or no connectivity
Limited connectivity
If you get a 'Limited connectivity" on you wireless connection on your laptop, it means that the wireless card on your laptop probably did not get an IP address from the wireless router.
To fix this problem, right click on the wireless icon on the Task bar and then click Repair.
This will force the wireless router to issue a IP address to the wireless card on the laptop.
Jan 01, 2013 | Computers & Internet
Computers have limited connection to linksys wrt54g although signal is full strength
Also try resetting the wireless router by turning off the power to the wireless router for a few minutes and the boot up your computers.
Oct 28, 2012 | Linksys Wireless-G WRT54G Router
My laptop can detect the wi-fi but I cannot connect to the internet. What is wrong with my router? Please help me out. This is a new router by the way.
routers have a limited bandwidth.. but some routers need to register your laptop serial to be able to connect to the internet.. there is a permission to allow your laptop to use the wireless connection.. check your wireless connection setting, then choose your router name, then try to connect..
May 21, 2011 | Edimax BR-6226n nLite Wireless Broadband...
Trying to connect wirelessly to 2 wire. I get limited access icon
Hi groveland1,
I see that you are having issue with your Internet Connection, Limited or no connectivity is a possible issue with your network key / security key on the router and your laptop.
1. Try and check the network key in your router.
2. Check your network settings in the Laptop and see if the security settings in your Laptop is the same as the security/network key in your Router.
3. If possible recreate your wireless connection in windows for a fresh connection from your Laptop to your Router.
4. Change your Network Key in the Router and in your Laptop see if it will connect in-case you may have forgotten you old Network Key.
Hope this helps.
Apr 04, 2011 | 2wire (1000-400108-001) Router
I have a 2Wire 1700HW router that is locked or encrypted. How do I unlock it? It is old and I'm not with the same internet provider.
First you will need to open the router set up.
Is there any computer connected to the router with the Ethernet cable ?
If not then you will need to connect the computer to the router.
Check the IP address of the computer and open the router set up.
Click here to know how to find Encryption key / password
Nov 27, 2009 | 2wire Computers & Internet
Cannot add a new laptop on my eHome wireless router
There is not a limit to the amount of devices that can hook "wirelessly" to your router, but your bandwith is limited. Internet bases phone services will eat up a large majority of your available bandwith. try limiting the bandwith of your phone service or disconnect it all together and see if you can then connect.
pls rate as "very helpful" if this assists you in your problem. ^_^
Sep 21, 2009 | Computers & Internet
Limited connectivity - wireless
Verify if your wireless option on the router is enabled.
Also when you setting the wireless on the router, be sure that channel is not on automatic. Specify a channel number. After that try to connect again to wireless
Aug 05, 2009 | Blitzz Technology BWA711 (B3WL000900)...
Limited Connection
shut off the router then turn it back on again.
Jan 27, 2009 | 3Com OfficeConnect Router
check your ip adreses
it is range of router
Jan 01, 2009 | Linksys Wireless-G WRT54G Router
Limited Connectivity
connection is to the router not the desktop pc
Ignore the desktop pc
check the wireless security settings in the unnamed router and make certain that the non-connecting laptop has the same settings.
Jul 10, 2008 | Computers & Internet
2wire (1000-400108-001) Router Logo
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Ron Stone
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
