Question about Polaroid FDM-0700A 7 in. TV/DVD Combo
No picture How do I use picture parameter setup without using a remote My picture is black
Same problem. No picture and lost the remote. How can I fix it? Can i get the picture back by programming it hte unit itself and how?
Posted on Oct 31, 2008
Is there a hidden service setting to adjust vertical height of picture as what ever ratio setting is used set over scans been like it since new but never got around to fixing as it was a second set only 13...
With most modern CTV sets, there is a service mode to adjust all the parameters to picture all other. Check these codes. If you wish to get more details, check the sites linked here. Setup code list, and setup procedure to many popular brand remote controls are given. http://electrohelponline.blogspot.com/ http://remotesearch.blogspot.com/ Selecting the view option, either to Mosaic / Time slide, can be selected by the drop-down list, at the top left of the display window, will make surf easy.
Oct 21, 2013 | Televison & Video
Somehow our picture became HUGE! So huge the picture doesn't fit the screen. I can't find the remote. I there a way to minimize the size of the picture without the remote?
It will be very difficult to explain how to do it without a remote so, instesd, buy a universal remote control available at drug stores, etc. Then you can go into the TV menu and setup and define the picture size.
Dec 31, 2012 | Televison & Video
How do we adjust color without a remote ?
Hello
If your TV has a "Menu" button on its front panel, press it once to get into its menu option. Surf thorogh and come to the picture control window. There you can see the adjustments. Will be Brightness, Contrast, Colour, Sharpness, Tint etc. Select the option you want to adjust, advance or decrese its parameter by volume Up/Down buttons. If there is no 'Menu' button on its front panel, it will be impossible to adjust these parametes withoug a remote control. OK.
Jul 24, 2011 | Televison & Video
Hi. We have a Sony dvd player dvp-sr200p and have a wide screen tv, when we play a dvd we get a small square picture with black sides. We would like the have a full picture like we had before. Could...
With the player in STOP mode, or without a disc inserted, press DISPLAY on the remote. Then press either the UP or DOWN arrow keys (on remote) to scroll down from LANGUAGE setup to SCREEN SETUP, then highlight the aspect ratio which best suits the connected TV, in this case 16:9 widescreen (according to the manual the default aspect is 4:3 letterbox). Once you have made the change, exit the setup. It should remember the setting you have made.
Pages 26 to 27 of the owner's manual illustrate the setup procedure for this model DVD player.
NOTE: some DVDs may be encoded as 4:3 titles, hence you will see black borders at the left and right sides of a widescreen TV. Not all DVD movies are encoded in the 16:9 aspect ratio.
However, you can check your player's setup menu just to be sure.
Apr 08, 2011 | Sony DVP-SR200P DVD Player
What is the boot up sequence please
You need to go inside BIOS to find out whats the boot sequence. To activate the BIOS Utility, press F2 during POST (when “Press <F2> to enter Setup” message is prompted on the bottom of screen).
Press F2 to enter setup. The default parameter of F12 Boot Menu is set to “disabled”. If you want to change boot device without entering BIOS Setup Utility, please set the parameter to “enabled”.
Press <F12> during POST to enter multi-boot menu. In this menu, user can change boot device without entering BIOS SETUP Utility. Navigate to BOOT page on top.
Hope this helps!
Aug 22, 2010 | Acer Aspire 5535-5050 Notebook
RCA TV picture bigger than screen
if the tv width is ok try entering to service menu (do not use remote control) as follow:
1) turn the set on.
2) press the menu button and hold it down while pressing the power button.
3) while holding down the menu button release the power button and press
the volume + button.
4) The screen will display a one line menu, on the left the parameter P00,
and on the right the value of the parameter V00
5) release buttons.
6) using the volume + button change the right parameter until 76
7) using the channel down button change the left parameter until 06 (vertical size)
8) whith the volume + or volume - adjust the screen size.
9) when your tv is OK back to parameter 00 using the channel up button.
10) press menu button.
and trouble solved.
Mar 05, 2010 | RCA F32650 32" TV
TV/VCR no setup key. Where is the setup key? Remote
how do i put TV codes in my SANYO remote it has the number IR 5435 on it dont no if thats the model or not
Feb 13, 2010 | Televison & Video
I have YPAO showing on my display and I can't get a picture on my tv. Do you know what YPAO means?
The receiver is in "Setup" mode and wants the microphone plugged in for testing sound parameters. Press "menu" on the remote, this will exit the mode. If you still have an issue, post a comment and I can help you some more.
Aug 04, 2009 | Yamaha HTR-5990 Receiver
Panasonic Viera Link stop working
Hey, you're not the only one to have this problem. Please see also
http://www.fixya.com/support/t5668469-viera_link_stopped_working_stating
Hope someone can help us all!
Jul 12, 2009 | Panasonic Televison & Video
Black box on tv
Use the TV/CAP/TEXT button on the remote to turn off the text box function of the closed caption decoder.
Dec 04, 2007 | Orion TVDVD091 9 in. TV/DVD Combo
Polaroid FDM-0700A 7 in. TV/DVD Combo Logo
107 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
