Question about Sentry Fireproof Safe
Pushed wrong button, now will not let us enter the right code, it just beebs with the push of any number
  • 3 Answers
Wait 2 minutes to retry.
Posted on Feb 02, 2010
Washer gets to rinse cycle and starts to pump water then stops?
Before hitting any buttons you need to write down the fault code. As soon as it starts beeping take note of which lights are on along the top row. There are 8 lights. Count from the right and tell us which number light is on and which are off. That will tell us the error code and what it means.
May 30, 2017 | Fisher and Paykel GWL11 Top Load Washer
How do i install a new radio
The process is very simple, just follow these steps and you'll be on your way to listening to your radio again. First of all don't think you need to unscrew anything. The wood panel surrounding your stereo snaps out by pulling on it or using a flat screw driver at the corners. Once you have taken the panel out, you can see that the radio is held in by 2 hooks. Push up and pull forward slightly. You don't have to pull out the entire radio because you can see the serial number on the top surface very easily. Write down the number next to where it reads s/n. Once you have the serial number, call the local dealership and give them your serial number. They will in turn give you a four digit code number that you will enter on your radio. One thing to note is that if you have entered the wrong code number 3 times, your radio would lock up and it would read "OFF". To unlock it, simply park your vehicle in a safe place and leave the radio on for about 1 hour (no engine running just click the ignition switch to operate the radio). After one hour, the radio resets and will ask you again to enter the code. start entering one number at a time using the first 4 buttons. Example, if your code is 4538, you would push button 1 four times to get to the number 4, you would push button 2 five times to get to the number five and so on.. After you have entered the correct code, push the CD button and there you have it.
Feb 22, 2012 | 2002 Mitsubishi Galant
I have a uniden bearcat bc145xl 16 channel scanning radio, every time I push the manual button, and try to put in a code I can't get all the frequency numbers put in. I don't know what I am doing w
When you press the manual button and then enter numbers it thinks you are entering channel numbers not frequencies.
Try manual button and then prog button.
Then enter the frequencies.
Hope this helps
Aug 18, 2017 | Radio Communications
I push in the wrong radio code 3x on my 2001 audi now its stuck on safe mode and wont let me in to push in the right code
First of all you should exit from safe mode. Then turn ON the radio and let it turned ON for at least one hour, in order to exit from safe mode.
IMPORTANT NOTE:
You must have the security anti-theft code for your VW radio from the car manufacturer, or from a VW dealer!
You can find the radio code at: http://www.radio-code.co.uk/
The sequence of a 2001 Audi Concert radio programming is:
1. Push simultaneous "SCAN" and "RDS" keys until on the screen will appear "1000" displayed.
2. Release keys. No more push on "SCAN" and "RDS" keys because otherwise number "1000" will be considered as first safe code attempt.
For example: we have the security code "5079". Then:
3. By the no.# 1 key you will set up the first safe code digit. Push 5 times on the no.# 1 button. The "5" number will be setted.
4. By the no.# 2 key you will set up the second safe code digit. Push 10 times on the no.# 2 button. The "0" number will be setted.
5. By the no.# 3 key you will set up the third safe code digit. Push 7 times on the no.# 3 button. The "7" number will be setted.
6. By the no.# 4 key you will set up the four-th safe code digit. Push 9 times on the no.# 4 button. The "9" number will be setted.
7. Then push again simultaneous "SCAN" and "RDS" keys for confirm this safe code. On the screen will be displayed "SAFE" notice. Release keys! For few seconds a radio frequence will be displayed.
The radio is now ready for use!
Audi Delta CC Radio
Please perform the following procedures while the car is parked. Otherwise you risk getting into an accident while your attention is not focused on the driving. Entering anti-theft code The following is the procedure to re-activate the radio if the display shows "SAFE". It is important that the procedure be followed in the correct order.
  1. Turn on radio. The radio display shows "SAFE".
  2. Press the FM1/2 and DX buttons simultaneously and hold until "1000" shows on the display. Release the buttons. Do NOT press these buttons again, otherwise the radio will consider "1000" to be the code.
  3. Use Preset buttons 1 ... 4 to enter the four-digit code number from your radio card. Preset button 1 corresponds to the first digit, Preset button 2 corresponds to the second digit, etc. Each press of the button increments the number by 1.
  4. Once the code shown on the display is correct, press the FM1/2 and DX buttons simultaneously and hold until the word "SAFE" appears in the display, then release the buttons.
  5. The radio should unlock and be usable shortly afterwards.
  6. If an incorrect code is entered, the word "SAFE" appears, first flashing and then continuously. You can repeat the above steps to unlock the radio once more, the number of attempts will be shown in the display. If an incorrect code is entered again, you radio will be locked for about one hour. After one hour - the radio must stay on and the key must remain in the ignition lock - if the display goes out, the you can repeat the above procedure to unlock again. The cycle - two attempts, one hour lock-up - still applies.
Oct 27, 2011 | 2001 Audi A6
Radio is in safe mode i tried twice and it locked me out i now know the right code what do i have to do to enter code again in a 96 audi a4
The sequence of programming for 1996 Audi radio is:
Aug 16, 2011 | 1996 Audi A4
I WAS RE-PROGRAMMING MY AUTO DIAL BUTTONS AND WAS ON MY 3RD ONE WEHN IT DECIDED THAT ALL MY BUTTONS WOULD NOW DIAL THAT NUMBER. i CAN'T TOUCH A SINGLE BUTTON WITHOUT IT DIALING THAT NUMBER.
To Program Buttons On Your Phone:
For External Numbers:
1. Press the Feature button, then * 1
2. Push the button you want to program
3. Display will read "Program and OK"
4. Enter the telephone number, then press the OK softkeyFor Internal Numbers (Extensions.:
1. Press the Feature button, then * 2
3. Display will read "Intercom #:__"
4. Enter the extension number
For Feature Codes:
1. Press the Feature button, then * 3
3. Press the Feature button then enter the Feature Code
Aug 12, 2009 | NorStar M7310 Corded Phone
Stereo is asking for a code
Here is the answer to the best of my knowledge. This applies to any body that has the need to get the code from the dealership and requires to pull out the radio and look up the serial number. The process is very simple, just follow these steps and you'll be on your way to listening to your radio again. First of all don't think you need to unscrew anything. The wood panel sorounding your stereo snaps out by pulling on it or using a flat screw driver at the corners. Once you have taken the panel out, you can see that the radio is held in by 2 hooks. Push up and pull forward slightly. You don't have to pull out the entire radio because you can see the serial number on the top surface very easyly. Write down the number next to where it reads s/n. Once you have the serial number, call the local dealership and give them your serial number. They will in turn give you a four digit code number that you will enter on your radio. One thing to note is that if you have entered the wrong code number 3 times, your radio would lock up and it would read "OFF". To unlock it, simply park your veichle in a safe place and leave the radio on for about 1 hour (no engine running just click the egnition switch to operate the radio). After one hour, the radio resetes and will aks you again to enter the code. start entering one number at a time using the first 4 buttons. Example, if your code is 4538, you would push button 1 four times to get to the number 4, you would push button 2 five times to get to the number five and so on.. After you have entered the correct code, push the cd button and there you have it. I hope this helps.
Sep 20, 2008 | Mitsubishi Montero Sport Cars & Trucks
Radio code
If you don't have the radios security code, you can try entering 1111 as some replacement radios were coded with this security code. Your local Audi Dealer may be able to provide the correct security code for your vehicle, if you provide them with your vehicles Identification Number (VIN). This VIN is typically located on the drivers door pillar.
The radio should have a serial number on the unit which also can be given to the Audi dealer and checked in their data base of radio security codes. The serial number will start with AUZ, one radio serial number for example is AUZ1Z9A1965412.
To enter the code on the Wiesbaden Radio: Turn on the radio, SAFE should be displayed.
Push and hold the AM/FM button, then while holding the AM button down, push and hold down the SCAN button. Release the AM/FM and SCAN buttons, and the display should show 1000. Now enter the correct code using the radio pre-set station buttons (1-4). Button 1 changes the first digit in the code "1"000, Button 2 changes the second digit in the code 1"0"00, button 3 changes the third digit, button 4 changes the last digit in the code. In most cases the first digit is a 1 and won't need to be changed. You push each pre-set station button multiple times to step through the digits (1-9) to get the correct code displayed.
Code 1246 would entered by pushing button "2" two times, pushing button 3 four times, and pushing button 4, six times.
After entering the correct security code, push and hold down the AM/FM button, then while holding down the AM/FM button, push and hold down the SCAN button. The display will then show SAFE, release the two buttons, and now the radio should play correctly.
Sep 19, 2008 | 2001 Audi S4
Cd player is in off made after I put the wrong code in 3 times
Here is the answer to the best of my knowledge. This applies to any body that has the need to get the code from the dealership and requires to pull out the radio and look up the serial number. The process is very simple, just follow these steps and you'll be on your way to listening to your radio again. First of all don't think you need to unscrew anything. The wood panel sorounding your stereo snaps out by pulling on it or using a flat screw driver at the corners. Once you have taken the panel out, you can see that the radio is held in by 2 hooks. Push up and pull forward slightly. You don't have to pull out the entire radio because you can see the serial number on the top surface very easyly. Write down the number next to where it reads s/n. Once you have the serial number, call the local dealership and give them your serial number. They will in turn give you a four digit code number that you will enter on your radio. One thing to note is that if you have entered the wrong code number 3 times, your radio would lock up and it would read "OFF". To unlock it, simply park your veichle in a safe place and leave the radio on for about 1 hour (no engine running just click the ignition switch to operate the radio). After one hour, the radio resetes and will aks you again to enter the code. start entering one number at a time using the first 4 buttons. Example, if your code is 4538, you would push button 1 four times to get to the number 4, you would push button 2 five times to get to the number five and so on.. After you have entered the correct code, push the cd button and there you have it. I hope this helps.
Aug 08, 2008 | 2001 Mitsubishi Galant
Sentry Fireproof Safe Logo
105 people viewed this question
Top Sentry Home Security Experts
Jim London
Jim London
Computer Repairing
Computer Repairing
Joseph Vernice
Joseph Vernice
Are you a Sentry Home Security Expert? Answer questions, earn points and help others
