Question about Sony Televison & Video
Dark bar on lefthand side of screen and frosty video on some channels as though the contrast is over driven ;the bar varies as mentioned with the channel being selected.............
  • 83 Answers
This is a coman problum is sony tv this problum is in side of tv pls. check video output supplay 180Vdc. replace 10ufd /250v Dc capaciter replace with new then problum is solvied it is not expanciv and mager problum don' wory..
Posted on Jan 31, 2010
Two off contrast vertical bars
See the picture you posted on dropbox, the problem is a defective display panel.
May 06, 2017 | Sony KDL40EX600 TV
Tip
How to adjust contrast settings on a BlackBerry Tour
Whether you are colorblind, curious, or just into weird color schemes, you can change the contrast on your BlackBerry Tour from the normal colors it displays to either grayscale or inverted colors. Here's how:
1. From the main screen, press the BlackBerry button (the one with seven dots) to get to your Home folder.
2. Scroll down until you see the Options folder (the one with the wrench icon) and click on it.
3. Select Advanced Options from the list.
4. Select Accessibility.
5. Go down to the second option, Color Contrast, and use either the ALT key or the space bar to select a new contrast setting. As you select one, the screen will change immediately, so you can preview each one before making a change.
6. When you've settled on a scheme you like, save the change before exiting; press either the BlackBerry button or the Back button and then choose Save.
The contrast setting you choose will affect just about everything you see on your BlackBerry, including Internet content, pre-loaded games, and even third-party applications. When using the Tour's camera or video camera functions, everything will be displayed in normal color, but any pictures taken will immediately appear altered, depending on your contrast setting. Videos are an exception to this rule; if you watch a video on your Tour with either of the alternate contrast settings, the video will still appear in normal color. (Though if you pause the video, the image it pauses on will adhere to your current contrast setting.)
on Sep 21, 2010 | RIM BlackBerry? Tour 9630 Smartphone
Acer Aspire 5050 - screen is dark as if contrast not working. It has played up for some weeks, going dark but after 10-15 mins it returns to normal. now it appears permanent. Have adjusted the GAMA and...
put and external monitor and if fail remains then your gpu is damaged, if monitor goes good then your screen is damage or the video cable, so in that case will require a technician to fix it. good luck
Jul 29, 2011 | Acer Aspire 5050-3242 Notebook
Garmin etrex 12 channel gps, screen very dim contrast with new batteries
For the Etrex Legend you can click the page (top right hand) button till you get the main menu, select setup then display. Point the click stick down until the bar on the left is highlighted. You can then move the bar up and down until you get the contrast you want. You could first try clicking the square near the top right and selecting restore defaults, but if the default contrast is not to your liking then you can change it using the bar.
It is probably similar on related models such as the Venture or Vista, if in doubt check your manual.
Dec 30, 2010 | Garmin eTrex Legend GPS Receiver
I have no picture on my 15" LCD Insignia TV. My
You may have a burnt out blacklight... You can fix it easy by having the tv on while it’s a bright picture than quickly unplugging it... or it would be best to get a new TV.
Oct 27, 2017 | Insignia 15 in. Flat Panel LCD HDTV
Low/No contrast on main screen
There should be a setup menu for "video" where the brightness and contrast can be adjusted.
Feb 10, 2010 | TruTech LMD-5702RT Portable DVD Player
Downloading music to a Samsung MP4 player
all you have to do is when the samsung window is open
plug in your portable player.
then left click on portable device
then on the lefthand side of the window leftclick my pc
then when you have selected the song that you want all you have to do is keep the left hand side of your mouse push down
and drag it to your portable device on the right hand side of your screen let go and walla it will load onto your mp3
when you want to transfer videos then all you have to do is on the lefthand side of your screen you will see a video sign click it with the lefthand side of your mouse key then you just click
and drag and it will load stright away.
just remember that videos take more time to load as they have more data to transfer.
Dec 28, 2007 | Samsung Yepp YP-T9 Digital Media Player
Ghosting
I know exactly what your talking about. I've seen in many times. It' happens too in CRT monitors as well as LCD. It could ALTHOUGH be as simple as a bad cable catching interference. Most likely though, it sounds like a bad LCD driver board or video board. If you have warranty, call it in. Otherwise see if it lessens with adjustments of contrast and brightness up and down. This directly affect the driver board power and can improve it enough to be tolerable again.
Aug 04, 2007 | Acer AL1715 (Black, Silver) 17" LCD...
Picture adjustment questions
*The brightness control setting determines how bright your picture will be. *The contrast control sets the gain of the video circuit. This determines the difference between dark and light scenes. Low contrast settings make the picture "hazy". High contrast settings make the picture more distinction between dark and light scenes. *The sharpness control determine the frequency response of the video circiut. High sharpness settings give better resolution but also shows more noise in your picture. Lower sharpness settings smoothe out the picture removing noise but also fine detail. It needs to be set for the best all around picture. *Picture Enhancement is pre-set adjustments which give you different picture qualities. You just select the one you like. Stargazer
Mar 03, 2007 | Zenith B25A02Z TV
Televison & Video Logo
16 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
