Question about Xerox Phaser 8500/DN Printer
Xerox phaser 8550DP 09,008.43:64999 - Xerox Phaser 8500/DN Printer
  • acltype Jan 30, 2010
    Now why didn't I think of that? I started to do that but there was that error message. It kept asking me for more black ink sticks so I should have known it wasn't feeling well.
    Thanks for your quick response.
  • Xerox Master
  • 19,396 Answers
Hi.
09008.43 is ink loader fault for the black stick.
Start disconnecting power cord for ten minutes , then remove the black stick check it and put it back, ensure you are using original ones.
If that does not work I will publish the full reset procedure in five minutes.
Posted on Jan 30, 2010
  • Ginko
    Ginko Jan 30, 2010
    This procedure will clean errors like Note: type errors 09,005.49, 09,006.41, 09,007.42, 09,008.43
    ('Ink Loader Fault - respectively cyan, magenta, yellow, black)
    Turn the printer on, to enter the Service menu:
    1. -You can access the menu using the FRONT PANEL:
    • Press the down arrow, select "Troubleshooting" from menu and then press OK
    • Press the down arrow until you get "Maintenance Tools" and then press OK
    • While holding the arrow at the top, also press the down arrow at same time, to access the hidden service menu.
    • Scroll down the menu until getting "Enter Diagnostics" and click OK. Wait about 20 seconds, then go to Step 3
    2 - If you can not Access the menus because the printer is stuck with the error message on display.
    a. If the printer is on, turn it off and wait 10 seconds. Turn the printer back on.
    b. Wait to see the Xerox logo on display.
    c. Before the Xerox logo gets steady on display, press and hold the Back button (back) and 'i' (Help) on the Control Panel.
    d. Hold down both buttons until the display shows "Beginning Initialization Service Mode". Release the button and the printer will restart showing the menu "Service Diagnostics".
    3) Scroll using the arrows until "Function Menu" appears and press OK
    5) Scroll using the arrows until you get the command "Clear Fault ISC" and press OK twice to confirm.
    6) Now push the "back" button on the control panel (usually at the left), then press "Exit Diagnostic", then OK twice to confirm.
    7) The printer will restart, and the error message will be gone.
    8) Remove the sticks, chek them and load them back correctly.
    If the error does not clear, then it is due to a fault, in which case I contact Xerox technical support at the number listed on the manual.
I have moved my xerox phaser 8550 from one room to another. it wont power up, i have checked connections and cables. also the ink waste tray has got jammed. could this be related . help
you should see power indicator when you turn it on but the printer will still not work if it has jammed paper, check also the walloutlet maybe it has no power or connections are loose
Oct 19, 2009 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550DP printing duplex
are you not able to get even the print menu?
Jul 22, 2008 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550 Maintenace Kit is stuck in the
If you remove the right side cover, you can operate the process drive gearbox with a straight-blade screwdriver on the end of the shaft (bottom of printer right in front of maintenance kit). This is the end of the drum maintenance camshaft. Rotate clockwise slowly. It's possible that the cams have cracked and rotated on the shaft. This is the weak point on these printers. If so, they may not be in sync. Good luck.
Jul 13, 2009 | Xerox Phaser 8550DP Printer
I'm looking for instructions to install the control panel for a Phaser 8550 DP.
Xerox has a video on how to install the control panel at:
http://www.office.xerox.com/userdoc/P8500_8550/8500_8550_Web/videos/controlpanel_installation.html
May 28, 2009 | Xerox Phaser 8550DP Printer
Installation of Phaser 8550 DP on network
This is no problem for someone with even a little networking knowledge, but it would take longer to write the instructions here, than it would to have someone spend less than an hour configuring it on site. That's my recommendation
May 19, 2009 | Xerox Phaser 8550DP Printer
Xerox phaser 8550 error 37,004.40:158510
most likely problem, is that your printer is not getting enough power, verify that there are no external power supplies, or extention cords connected to the unit, also, you might want to try another power plug.
thanks
Apr 17, 2009 | Xerox Phaser 8550DP Printer
Xerox phaser 8550 prints garbled characters
This happens to mine occasionally after I have put it into standby a few times. If I reboot this always sorts it out.
Apr 05, 2009 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550dt printer
We take visa and mastercard. Call me at 5742431176
Jul 23, 2008 | Xerox Phaser 8550DP Printer
Garbled text
Did you just install it ? Sounds like a driver issue.
The only other thing I have seen cause that is software corruption.You can do a NVRAM reset from the screen.
But I would try restarting the machine first. Then go to the Xerox.com site and download a new driver before resetting the NVRAM memory.
It sounds like either the program you are trying to print from of the driver is the issue.
I bet you are printing out code.
Jan 29, 2008 | Xerox Phaser 8550DP Printer
Xerox Phaser 8550DP Printer does not recognize the ink it has
  1. Open and close the Top Cover to resolve the problem.
  2. If the problem persists, arrange the ink sticks until there are no spaces between sticks of the same color.
  3. Check for non 8500/8550 ink sticks jammed in the ink load chutes.
Nov 16, 2007 | Xerox Phaser 8550DP Printer
Xerox Phaser  8500/DN Printer Logo
42 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
