Question about Philips 42 in. Plasma TV
Tv turns on but no sound or picture led light green
  • ardolford05 Feb 02, 2010
    i took off the back of the tv n its a lcd n not a plasma so how do i know if the power board is bad or what should be replaced that would cause the tv to power on but no sound or picture...im not sure what to be looking for..thanks
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. A plasma TV is a very hard working device. It is working harder than any TV that has been built before, and as a result it produces a lot of heat. 75% of technical problems in plasma TV's are caused by overheating problems. X, Y sustain, buffer boards controls picture, fires the gas, and many others functions. When either of these boards goes bad common problems include negative image, no image, vertical or horizontal stripes on picture, turns on and than turns off, and many more. You’ll need to open the back off the TV and check for any swollen/bulged/leaky capacitors on these boards and replace whichever has gone bad. All this is only recommended if you have electrical expertise & know how to solder/re-solder components as these units contain high voltages even when switched off.
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Jan 30, 2010
  • Rylee Smith
    Rylee Smith Feb 02, 2010
    If its a LCD TV then take
    a look at the power board-the board where, the power cords/plugs goes into. You
    might see some filter capacitors a little bulged up in the top-If this is the
    case-this is your defective part(you can try to replace them-but some soldering
    equipment is needed). If not, then probably the main board has gone bad. This
    is the other board-where all he inputs are going into. Also check for the
    Backlight Inverter Board if the sound is coming fine from the TV however as its
    shutting off so it should be either the power board or the main board. All this
    is only recommended if you have electrical expertise and know how to
    solder/re-solder components.
    . Please do accept the solution if
    Thanks
    Rylee
I have a viore led42vf80 when turning on the light turn green but still no picture or sound can you please help me
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
Jan 20, 2015 | Viore 42" 1080p Led42vf80 Lcd Led Hdtv
I HAVE A SONY-KV-ES34M61TV,PICTURE GOOD,SOUND GOOD BUT LIGHT BLINKIG FIVE TIMES
A search of previous questions found this:
5 times flashes is error of White Balance and its cause is defective part in Picture Tube (CRT) board or CRT itself.
CRT Board - 3 and CRT - 1
25317392-0bjacsudnesclogzm4oikctc-5-0.jpg Sony kv32dx30u led flashes 5 times no picture had green tint in previous...
Dec 11, 2014 | Sony Televison & Video
Tv turned off by itself, red light came on. when i turned it back on if had a flashing green light the turned solid green, there was sound but no picture, it turned off again within 2 minutes of turning it...
Tv probally needed a new tv projection lamp.This tv has not been change it projection lamp like 1 1/2 or 2 years already?Tv been on and used it like 4 or 5 hours everyday?Yes,than the tv flashing or solid on green LED light is on have a word "LAMP" written on it tv bazel frame?Yes,tv 100% require a new tv projection lamp replacement.
Aug 31, 2011 | Mitsubishi WD-73737 73 in. HD-Ready TV
No sound/picture and red power light always on (Hitachi 43FDX15B)
When u turn the tv on,u hear alot of clicking?That mean the Ballast that help the projection bulb to work is dead.Change the Ballast,might as well change the bulb too.U don't know what is the condition of the projection bulb in.
May 29, 2010 | Hitachi 43FDX15B 43" Rear Projection...
Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
Aug 07, 2009 | Hitachi 51SWX20B 51" Rear Projection...
No Picture & No sound. Red LED, Green LED, Red LED.
If the power supply outputs are good! Then I would say the back light inverter is bad! If the screen stays black and does not come on.
Jan 14, 2009 | Akai LCT2660 26 in. HD-Ready LCD...
Philips  42 in. Plasma TV Logo
41 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
