Question about Water Heaters
Triton as2000 xt .i have water pressure at shower inlet pipes but when commissioning i only get a trickle of water at shower outlet
  • 105 Answers
The shower head is clogged,..easy to clean. just take the head off, and clean screen
Posted on Jan 31, 2010
I CLOSE THE SHOWER OFF BUT WATRE STILL RUNS THROUGH AND DRIPPS
Incoming Inlet valve's plunger might not closing properly or ur faucet water valve defective.
Sep 10, 2014 | Camp Chef Triton Propane Hot Water Heater...
My water is not very hot on my triton T300si shower why ?
What is hot, it is an subjective measurement.
If you have one of those instant hot water heaters, they have a maximum temperature rise at a given flow rate. If you exceed this flow rate, the temperature will be become cooler depending on how much over flow capacity you are operating it. This will not damage the unit, just give cooler water then what you expect.
In 1988, the Consumer Product Safety Commission recommended that water heater manufacturers preset the maximum temperature at 120 degrees Fahrenheit to prevent burns. Since several states have mandated this maximum temperature.
Apr 28, 2014 | Water Heaters
Cold water pressure poor in shower. Just had Rheem installed.
You might have clog in water lines.
If shower is only place where low pressure exists, then clog is probably at shower valve.
Disassemble valve and see if clog will flush out.
From there, you have to keep moving back along cold water line looking for pipe filled with sediment or elbow that has obstruction.
If pressure problem is bad at every cold tap, but doesn't affect Hot water, then clog is inside Cold line somewhere after water heater connects to cold line.
Buy a pressure gauge that connects to water hose.
Buy adapter that also fits pipe thread.
For example Brady BTG 100.
Test outdoor spigot for baseline pressure.
Open cold tap inside house and see how much pressure drops.
Close cold line and open hot tap and see how much pressure drops.
Next, move pressure gauge along cold water line.
Take apart pipes and inspect for obstruction at elbow or pipes filled with sediment.
Look for any place galvanized pipe connects to copper pipe, since this will be likely place for obstruction because of bi-metal corrosion.
Add a comment for more free help.
Also take advantage of fixya phone service.
For a price, fixya expert speaks with you over phone while you work on pipes.
Jan 05, 2011 | Rheem 40 Gallon FVR NATGAS Low WATER...
My waterheater has three water connections on the top of it one has a C for cold is that a inlet or outlet ? The other spot has a H for hot is that a inlet or outlet ? And the other one is not marked what...
My water heater has three water connections on the top of it one has a C for cold is that a inlet or outlet ? IT'S THE COLD INLET. The other spot has a H for hot is that a inlet or outlet ? IT'S THE HOT OUTLET. And the other one is not marked what is that one for and is it a inlet or outlet ? please email me at nsjuby@yahoo.com. The last one is a pressure release valve that lets off excessive pressure when the temperature goes too high in the unit. When you install the heater, it should be installed into the drain pan that existed before or into a new one. You should also install a drain pipe from the valve to that drain pan, or into the drainage system for the house. This may depend on the codes where you live. Also install a good quality shut off valve on the inlet side for emergencies. A Ball type is good. Hope this helps,
Best Mark
I'm new to this site, so I'm not sure if I can email you directly or not. I believe not. Good Luck.
Dec 28, 2010 | Whirlpool Water Heaters
The hot water just trickles out of the hot water taps, I've checked & cleaned the tempering valves, mains water pressure is fine, is the cylinder scaled or blocked
Something is blocked. Turn off water to heater disconnect outlet and attach a waterheater flex connector to tank outlet bend other end into bucket. turn on water briefly - water should blast into bucket.
If not:>>>>>>>>>> disconnect water heater inlet -you may find part of the flex washer stuck into the inlet nipple. Or dip tube may have disintegrated and be plugging outlet nipple, if you have the energy saving nipples the ball can jam debris in the nipple.
If water does blast into bucket >>>>>>>>>>>> Then the problem is farther down the line, maybe bad mixing valve. disconnect mixing valve outlet and use a garden hose to backflush through mixing valve with bucket under hot pipe disconnected from water heater. If flow through valve is restricted, replace valve.
Jan 01, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
No hot water when heating tempreture reached.flow switch is operating, power at flow switch terminals on pcb (three wires),? but when working hot water runns for ever and heating runs ok too untill the...
I have a triton opal shower.
I turn shower on low pressure and cold water. then no low pressure and piping hot water for a very short time then low pressure and cold water.
I've changed the solenoid and the little black plastic ball.
Help !
Aug 21, 2009 | Water Heaters
Low pressure on hot water taps and showers
Many states building codes require a pressure regulator and expansion tank for hot water heater installation. Check the pressure regulator if you have one as this would only affect the hot water pressure. Adjust or replace. Rap the expansion tank like knocking hard on a door. Hollow sound is good. Dull thud means it needs to be replaced as it is filled with water.
May 24, 2009 | Rheem 50 Gallon FVR NATGAS Water Heater...
Nothing happens when I press start button on my shower
try flushing out the water pipes put some pressure on it with the selenoid taken out and nothing but the pipe there use some shark bite fitting I know this is in close quaters and if you don't know how to solder these are easy connections, take the whole assembly out and flush it, might have a kink in one of the tubes to the shower
Apr 11, 2009 | Water Heaters
New water heater, shower hot then only warm water in 5 minutes
try this, set the bottom therostat if it is electric , 10 degrees hoter than the top is set , if gas have no ideas
Dec 05, 2008 | Water Heaters
Water Heaters Logo
129 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
