Question about Emerson Televison & Video
How can I place tv on channel 3 with out remote?
  • 7,993 Answers
Near the switch ON/OFF button there must others that control the volume and the channels. Usually the channel switching buttons have an arrow pointing Up and another pointing down. The two button may be the up end and down end of a bigger button. That is the general idea. But you should examine the TV around the control buttons looking foe some inscriptions that will help you identify which is which.
Turn your TV on. Identify the volume control buttons.
By pressing on the button (or the button end) with an UpArrow you ascend the channels. Pressing the button with the down arrow decreases the channel number.
Posted on Jan 30, 2010
Without remote how do I set in on channel 3, the channel button of front of TV only goes from 95 to 99 and back again.
you will need the remote to do a channel search or manually reprogram the tuner to tune in ch3
A good place to fine cheep factory remotes is on e bay. enter your model and make, only buy factory remotes not universal .
Factory remotes can do things a universal one cannot.
Jan 23, 2016 | Televison & Video
Lost remote. Must do manually on t.v. Two problems:\r\n1) I cannot get channel back on channel 3. It skips from 2 to 4. 2) TV has large black box on screen covering most of screen. I can push buttons...
Try website like Remotes.com to buy the tv original remote to used.U will used the tv original remote to turn to channel 3 with ease.After u have the tv original remote push the menu button go into Closed Captioning functions turn off like TEXT 1,2,3...The big black box will not appear on the screen again.Tv used it manually control buttons up and down channels trying to get to channel 3.U will never get it to tv channel 3 because tv channel 3 was not save on it memory list of on the tv turn manually channels buttons programming memory.Tv have a manual button said MEMU button on it tv front bazel frame?Yes.Might could used the Menu button on the tv frame to get in to turn off TEXT 1,2,3...to stop the big black box to show up on the tv screen again.
Aug 17, 2011 | Toshiba 36A50 36" TV
When i turns off video for to get the channel 3 back aucan signal comes up how would i get back to the channel 3 to watch tv
If your DISH remote is programmed to operate your TV, you can press the TV button at the top of the remote and release it. On the number pad, press the number 3. If you get a picture, press the SAT button on release it. You can now operate your satellite receiver.
If you don't get a picture, use the TV remote to place the TV on channel 3 or you can use the channel button on your TV.
Aug 06, 2011 | DISH Network 625 Duo DVR Receiver...
How can you change to channel 3 without remote?
U only can now used those buttons like channels + - for channels,it will alway skip channel 3.U can't get channel 3 if channel 3 is not in ur tv save memory.Try website like Remotes.com to buy the tv original remote to used.
Jun 30, 2011 | Daewoo DVQ13H1FC 13 in. Combo
Please program channel memory and all channels are unavailable I have fios so I only need channel 3
U still have the tv original remote?Yes,must used it to get into chanel 3.Because the manual buttons channels up and down on the tv bazel frame will skip channel 3.Only able get into channel 3 by manual channel buttons up or down only if it was save in the tv memory.Try website like Remotes.com to buy the tv original remote.
Jun 07, 2011 | Philips Magnavox 27MS343S 27" TV
I chose the wrong channel on remote it took me to a Dish site whcih I chose to exit - when I did that my picture totally disappeared - could not get it back. It is fine on my other tvs - so I need to get...
Guest
Are you getting a snowy/blue/black screen on your TV? To get your picture back, you need to get the TV back to the correct channel or input. If the receiver is in the same room as this TV, the TV should be on channel 3/4 (normally 3) or an input setting depending on the TV. TV 2 (away from receiver) would be on channel 60/73. If you have the TV remote, put the TV on one of those channels. If you get a picture when the TV is placed on the correct channel, press and release the SAT button. This puts the remote back in SAT mode and will now operate the receiver.
If you don't have a picture, unplug the receiver for 10 seconds from the electrical outlet and plug back in. This will cause the receiver to reboot and re-acquire Satellite signal. i hope this helps.
Ray Calo
DISH Network
Jun 30, 2010 | DISH Network IR Remote Control
I have a philips I got from a hotel but i cant program the channel to 3 to hook up a dvd player even with a universal remote what do i do?
Channel 3 is probably locked out... here is how to fix it....
1) Press the Menu button on the remote or press both Volume buttons on the front of the TV to access the TV's internal menu's
2) Scroll to highlight INSTALL using down arrow on the remote or Channel - on the front of the TV.
3) Press the Right Arrow on the remote or Volume + on the front of the TV to access the INSTALL menu.
4) Scroll to highlight Channel Edit using down arrow on the remote or Channel - on the front of the TV.
5) Press the Right Arrow on the remote or Volume + on the front of the TV to access the Channel Edit menu.
6) Use the Left or Right Arrow on the remote or Volume + / - on the front of the TV until you get to Channel 3.
7) Use the Down Arrow on the remote or Channel - button on the front of the TV to select SKIPPED.
8) Press the Right Arrow on the remote or Volume + on the front of the TV to select OFF.
9) When finished press Exit on the remote or press the power button on the TV and then power the TV back on.
You should now be able to use channel 3.
Good Luck....
Jan 15, 2010 | Philips 20PT6441 20" TV
RCA DTA800 TV Converter Box I need TV codes for the remote to work. The TVs are a GE, phillips magnabox
Good day,
I might be missing something, but you are describing a converter box that converts digital signals from an antenna to analog.
The converter box will be set to channel 3, and you should set your tv's to channel 3 as well.
Using the remotes that came with the tv's go into setup and if available as an option, you will find an option to select cable/antenna or automatic. Select automatic or antenna and save. If there is a selector switch on the back of the tv's, set to 3.
Connect antenna cable into input, and use supplied cable to connect from the output of the converter to your tv.
plug in power supply for converter box, tune tv to channel 3 then follow instructions to setup converter box including channel scan.
When done, the converter remote will control everything. However, the tv volume control will work even though the converter remote will have volume as well. The tv remote as well is needed to shut off or turn on tv. These functions can on most tv's be performed on the set as well.
No codes are required. The converter remote will work on any tv.
If you want to use both tv's then you will need a splitter on the output of the converter to send the signal to both tv's. Only one channel can be viewed at a time.
Viewing separate Chanel's requires a second converter box and a splitter connected to the antenna cable for viewing separate channels.
More options are possible, but I hope this helps you get started.
The converter box takes place of the tv's tuner and in essence disables it.
Nov 05, 2009 | Tablets & eReaders
I do not have a remote control for my Symphonic tv and I am trying to put the tv on channel 3 or 4 but I can't. It goes from channel 2 to 8. Please help.
Below are some places where you can purchase a symphonic remote control. But if you don't fancy buying one why not tune channel 8 and upwards to the station's that your are after and just forget about the 3,4,5,6,7. My quess is that the tv system is set to skip these channels. If you go to Menu > tv settings, check out the channels that you are skipping, it should be in the installation part of the tv setting's menu. Make sure that where it say's SKIP > OFF on all of the missing channel's.
Hope this is of some help. Bit long winded but hey! :-)
Hughie.
www.remotecontrolscenter.com/symphonic/ -
www.tootoomart.com/buy-symphonic+remote+control/ -
Jun 17, 2009 | Televison & Video
Cant turn the tv to channel 3
Go to the Menu setting, and do a auto channel scan, it will automatically program it to NOT skip 3.
Nov 25, 2008 | RCA Universal Remote 3 Device Remote...
Televison & Video Logo
42 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
