Question about Samsung SGH-e315
I have files on my phone i carn't delete or rename what shall i do?
  • 136 Answers
Connect your phone to computer and then try to delete or rename through computer
Posted on Jan 30, 2010
I am tryign to uninstall fix it, get error 5006
Installation or uninstallation of an application or game fails and gives the following error code:
This issue is due to a previous installation not finishing properly
Solution 1. Rename the Installshield folder
Make sure you've enabled Show hidden files and folders.
Find and rename the Installshield folder:
Windows 32-bit: C:\Program Files\Common Files\Installshield
Windows 64-bit: C:\Program Files (x86)\Common Files\Installshield
If there is an Installshield file in the Common Files folder, rename that one also (e.g. to Installshield_OLD).
Solution 2. Remove all traces of previous uninstall
If renaming the Installshield folder had no effect, find and delete any traces of uninstalled applications.
Applications that can assist you are: Revo Uninstaller, Windows Installer Cleanup Utility , CCleaner.
Alternatively, do a manual clean-up:
Close all running programs. Then clear the Temp folder (found via input of %temp% in Start > Search or Start > Run).
Use the Windows registry editor to delete registry entries related to the program.
Restart the computer.
hope this helps
Sep 10, 2012 | Microsoft Windows Vista Home Basic Edition...
Tip
MAKE YOUR S60 DEVICE FASTER AND RECOVER RAM In the next few posts i will...
In the next few posts i will post some tricks to make your phone faster and also recover precious RAM.
1. MOVE HELP FILES TO MEMORY CARD
If you are running low on phone memory and have a lot of apps installed, you can recover a part of it by transferring help files to the memory card.
Enable CAPS OFF
open Xplore or fxplorer and move C/resource/help to E/resource/help.
All the apps will find it automatically in the E drive.
This trick will increase your phone memory thereby making your phone a little bit faster.
2. DISABLE LIFEBLOG PERMANENTLY
first use jbak taskman to kill lifeblogobserver process
make sure x-plorer is set to show hidden files
then go to c/data/lifeblog/database
now delete the lifeblog.dbfile
reboot phone
now use jbak taskman to kill lifeblogobserverprocess once again!
select llifeblog.db file and press 6 tick hidden and read-only reboot phone. You'll notice the phone's boot up is faster and it will also release some RAM.
if you want to use lifeblog again go toc/data/lifeblog/database
and untick hidden and read-only
3. STOP AUTO STARTUP OF APPS ( for a faster boot up)
You can disable the third party applications to boot at start . These applications boot at startup and slow down the phone,s startup. In order to stop them to boot them use the following process.
The info of all the start up apps is stored in c:\private\100059c9\start.dat
whenever you allow any application to start automatically at startup the file start.dat is updated. The simplest method to disable the apps to load at boot up is to simply rename the start.dat file i renamed it to start.dat.txt. After renaming it your phone will boot as it boots after a fresh formating.
When ever you again want to enable the startup apps just remove the .txt extension.
You can also edit start.dat file to enable some applications to boot at start up and disabiling others but i don,t know how to edit .dat file. But you can edit it if you know how to edit it.
The easiest method of editing the .dat file is to delete the old start.dat file and then go to the applications which you want to boot at start up and rechange their setting ie (enable auto start=yes). A new .dat file will be created automatically which will only boot those apps which you want.
You can even further boost up your phone start up by renaming files like
C:\private\100012a5\DBS_101F99FB_NSmlDSSettings.db
C:\private\100012a5\DBS_101F99FB_nsmlagentlog.db
C:\private\100012a5\DBS_101F99FB_NSmlDMsettings.db
C:\private\100012a5\DBS_101F99FE_NSml_Adapterlog.d b
C:\private\100012a5\DBS_101F99FE\NSml_adapterlog?? ?.dat
C:\private\101F99FD\nsmladapterlog???.dat
C:\private\101f9a06\nsmldmtree.db
C:\private\100056cf\clockapp.dat
C:\private\100059a8\nitz.dat
C:\private\100012a5\DBS_101F9A02_nsmldmfotaadapter .db
C:\private\100012A5\101f8683_ScShortcutEngine.db
C:\private\1000850\logo*.*
C:\private\100012a5\DBS_10205030_accpolicydb.db
C:\private\1000c959\localdata\commondata.D???
C:\private\1000c959\localdata\localdata.D???
To .txt files or simply delete them.
Deleting all these files is the other name of restoring your phone to factory setting without losing any application data. Deleting these files also deletes sim data mean the network data of all the sims used in a phone. When you will rename all these files your all phone setting will be lost like clock time ,month date year. When you will again set different settings like adjust the ,adjust the date duplicate files of all the files you renamed or deleted will be created mean fresh data files .to again gainyour original setting as they were before applying the hack just delete all the duplicate files and rename all the above files as they were before renaming and restart your phone all your setting will be restored.
on May 09, 2010 | Cell Phones
I have an Acer aspire one netbook. ?; why cant i rename a file. Its in, Computer-Ascer(C:)-Users-. There are two files in this folder. Im not able to rename either. Is there a way to rename them?
If you have the file open or part of the content of the file is in use some place in the pc it wont let you rename it
try open the file as an administrator in safe mode or it might be read only attributes
copy paste soem place else see if it lets you then change name
rename and save some place else
There are several reasons why Windows might not allow you to delete a file:
  • The file might be in use in which case you can't delete the file until the program using it gives it up.
  • The file might be marked read-only.
  • The file name might be so long that Windows can't handle it. File names with more than 260 characters in them are often difficult to delete.
There are also several reasons why Windows might not allow you to change the name of a file; particularly its extension. All above apply here; as well as...
  • Your system may not be showing file extensions by default.
We'll cover that one first and the others in turn.
File Extensions Not ShowingThis is the most likely possibility for why you might not be able to change a file's type (i.e., rename the file extension). When Windows installs, one of the defaults is to turn off the showing of the full names for common file types. Basically, in Windows Explorer only the file's rootname shows; the extension is suppressed, yet is "shown" via the description in the File Type column of the Windows Explorer display.
When Windows is set up this way, if you attempt to change a file's name you are only allowed to change the rootname of the file but not its extension. So, if you have a file that shows up as MYFILE as file type Text and you attempt to rename the file to MYFILE.DOC what you really have done is rename MYFILE.TXT to MYFILE.DOC.TXT and the file type in Explorer will remain Text instead of changing to a Word File.
How to you fix this? FILExt has a different FAQ here that explains the procedure in detail.
The File is in UseA file in use by the operating system generally can't be changed while the file is in use. A file in use by a program may or may not be able to be changed. These are not hard and fast rules and exceptions abound; particularly in a multi-user environment. But, if you try to rename or delete a file and Windows complains that the file is in use don't be surprised.
To fix this you have to determine what is using the file. The error message that Windows pops up may or may not have that information in it.
If you don't want to experiment a bit to figure out what might be using the file you can restart the computer with all startup options turned off. This will most likely not run whatever was using the file and the system will allow you to rename the file. Recognize that if you do this and then restart the computer with all startup options enabled some program will likely complain that it can no longer find the file you just renamed. This may or may not affect how your system performs (or even operates at all).
To change the startup options, use the System Configuration Utility.
  • Click on the Start Menu.
  • Click on the Run item.
  • Type msconfig into the dialog box and click OK.
Use the various startup options settings to reconfigure your system startup as needed to find the subject program or process. Remember the caveat about how changing the name of a file a program or the system uses might affect system behavior. Keep good records so you can reverse what you did if necessary.
If you want to experiment a bit, press the Control-Alt-Delete keychord (press all three keys at the same time) only once (if you press the keychord twice you will restart your computer). The Windows Task Manager will appear. Take the Applications tab and see if anything is running. If so, stop those programs (it's usually better to switch to the program and then close it from the program instead of picking Close from the Task Manager). Wait a bit as it sometimes takes Windows a bit of time to release all program assets. Then try to rename or delete the file. If you now can rename or delete the file you know one of the programs was using it (stop only one program at a time if you really, really want to know which one).
If you still can't rename or the file you need to go to the Processes tab. There should be a number of running processes. Two of these are particularly important: Explorer and Systray. Do not end these. The other processes should be able to be stopped. Try stopping those processes you may recognize one at a time. Attempt to rename or delete the file after each has stopped. If you can, then you know what process was using the file. Keep going until only Explorer and Systray are running. If the file is still in use you've got your answer. The most basic processes in the computer are using the file. The same caveat as above applies: the file was in use for a reason and if you rename it or delete it the system may become unstable if you rename the file.
File is Marked Read-onlyThis is the easy one. To find out if a file is marked read-only right click on the file in Windows Explorer. Select "Properties" from the menu that pops up. At the bottom of the dialog that appears are the attributes for that particular file. See if the Read-only box is checked. If so, you won't be allowed to modify the file. To take the read-only attribute off the file uncheck the box. Again, be aware that if some program requires that file to be read-only and you change that attribute or the file's name you may have system problems. Use caution.
Note: If the file is in use (see above) or you don't have the necessary permissions (i.e., you're not logged in with administrator status) the read-only box may be greyed out and until you correct whichever condition is to blame you will not be able to change the attribute.
How does a file get to be read-only? Most of the time it's by copying the file from a CD. Most CD media, by design, is read-only and often when you copy a file from a CD (or an install program copies the file) a read-only attribute will be given to the file because it was read-only on the CD. This doesn't happen often, but does happen often enough to cause some people problems.
File Name is Too LongWindows has special problems dealing with extra long path/filenames. If the combination of the path and file names gets close to 255 characters (127 for Windows 95/98/ME) Windows will likely not handle it well if you try to delete or rename it (you can create it but not change it). While there are programs that can handle names that long or longer (e.g., FileBoss) the first thing to try would be to rename some of the folders that lead up to the file itself. Back the directory display up one level and then select and rename the folder the file is in. Try a single letter (obviously, keep a record of what folder you named to what so you can reverse the process!). Then, go back to the file and see if Windows then allows you to rename or delete it. If not, go back yet another folder and rename that one and so forth. At some point you should be able to find a series of reduced-length folder names that allow you to then rename the offending file to a short enough name to allow you to then recreate the original directory tree and still work with the file in question.
Special Programs for Deleting Files/FoldersSometimes you can't seem to delete a file or folder no matter what you do. In this case there are a few programs that might help you.
If, after all this you still can't rename/delete a file, not certain what else to suggest. Others have this problem often and as different ideas might come up in the FILExt forum I'll change this FAQ to include them. If you find a method that works for you and is not in this FAQ, please drop FILExt a note with details on that method so it can be added to the FAQ.
Jul 24, 2012 | Acer Computers & Internet
If I delete the EPAUDF01.AUD file from Windows 7 in order to print more swiftly in Photoshop CS 5, what will happen when I attempt to print in other programs? How important is this file? Thanks for your...
The best way to find out is NOT to delete that file, but to rename it (for example, rename it to EPAUDF01.AUX). If anything goes wrong, you will be able to rename it back to it's original name and everything should be ok.
On the other hand,
Aug 03, 2011 | Office Equipment & Supplies
My phone samsung gtb5722 is unable to show files exceeding 52 characters please help me out
rename files and delete tags. file names must be shorter, than 52 characters
Mar 08, 2011 | Samsung B5722 Cell Phone
My blackberry has the error 523 reset, i have tried to update my phone but it wont owrk
Delete or rename the vendor.xml file, here: C:\Program Files\Common Files\Research In Motion\AppLoader (you're windows file options needs to be set to 'show system files', to see said file...
After you delete the file try the update again.
Feb 23, 2011 | RIM BlackBerry Curve 8520 Smartphone
File format not supported.... I can't play a mp3 file on my phone despite changing name already
try to delete the file or mp3. after deleting the file transfer another mp3 file using a cable or by bluetooth.
this phone supports MP3/AAC/M4A however if your file e.g is not supported and you just rename it it wont work because it was not originally written in the file format that you device can handle.
hope this help
Sep 08, 2010 | Nokia 6151 Cellular Phone
KU990 .pxo file problem
hay there ..it will help you...i just made that same mistake but i overcome from it..connect ur mobile to usb..and open it through efs media..then.select the port if it shows..if not try refresing and reconnecting...after connect u will see a new lg app create by system..rename it to toto again and disconnect ..then reconect and rename..toto to lgapp..this return back my viewty..and am so glad..
Nov 26, 2009 | LG KU990 Viewty
Nokia n 73..my memory card was locked
HI
You have to choose the simple way to remove the password in your memory card, Follow the steps below...
Insert the memory card into the card reader or any mass storage device into your computer
  • go to the file <memorycard>:/system then find the file "mmc store".and rename the file to "mmcstore.txt" (Hidden file should be made as shown from tools->Folder option->Show hidden files)
  • Now open the file in notepad ,
  • No you will see the password.
ENJOY! RATE THIS SOLUTION
RNJ VINOD KUMAR
Nov 03, 2009 | Nokia 7373 Cellular Phone
File copy error.
maybe your drive is already full, if your drive is already full try to delete the temp file or delete your unnecessary files, if not try to check the file that you are trying to copy, maybe there some associate file which have a long file name, try to rename it but copy first the original file name to notepad, and after copying rename again your file that you renamed before, if still not tell us what kind of file you want to copy.
Sep 08, 2008 | Computers & Internet
Samsung SGH-e315 Logo
19 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
