Question about Hoover U6311-930 Power Drive Bagged Upright Vacuum
Doesnt **** - Hoover U6311-930 Power Drive Bagged Upright Vacuum
  • 268 Answers
If the vacuum sounds like it usually does and still doesn’t pick up, you probably need to replace the belt. To check this, turn the vacuum on and lay it down sideways. Check to see if the roller is spinning. If it's spinning, turn the vacuum off. Stand it up and turn it back on. Do you hear the roller spinning. Some belts stretch over time. If the roller was spinning when the vacuum was on it’s side and stops when the roller has some pressure on it (your carpet), change the belt.
A clogged vacuum cleaner usually sounds "clogged". The noise the vacuum normally makes will seem muffled. First, Unplug Your Vacuum. Then change the vacuum bag or empty the dirt cup. If the bag is filled up more than halfway, this could reduce your suction. Throw out the bag. Look at the area that holds the dirt cup or vacuum bag. Remove any debris. Look for a filter in this area. If you find a filter make sure it's relatively clean. A clogged filter will shorten the life span of your vacuum. Make sure your filter is back in place or replaced, and reinstall the vacuum bag or dirt cup.
A lot of the current style upright vacuum cleaners have attachments and a hose on board. If you have a vacuum hose on your upright, pull it out like your going to vacuum with it. Look at the area you removed the hose from. Remove any debris. I recommend wearing gloves, and try not to use any sharp tools like a needle nose pliers that might puncture your vacuum hose.
For the final step in this vacuum cleaner repair, place the vacuum in a position where you have a birds eye view of the bottom plate. You can usually see if there is any debris that requires removal.
Here is a link that will take you to a site that shows how to access your machine to change belt or look for clogs.
http://www.info-vacuum-cleaner.com/hoover-vacuum-cleaners.php
Hope this helps
Posted on Feb 01, 2010
Roller doesnt spin on my dc15
Hi there, it's Jack at Dyson.
If your DC15's brush bar won't rotate, it may need resetting. In order to do this, please follow the steps shown in our Support video:
If you'd like further advice after giving this a try, you can reach our experts directly by calling 0800 298 0298 (UK), 1-866-693-9766 (US), 1-877-397-6622 (CA) or 1800 239 766 (AU).
Sep 10, 2014 | Dyson 909592-05 DC-15 Roller Brush Beater...
Vacuum works but doesnt ****
make and model is ?????
Jun 16, 2013 | Vacuums
Cleaner lights up water doesnt get hot doesnt steam
change thermal link ....sat ontop off boiler
Feb 23, 2011 | Vacuums
No dirt is collecting in chamber and doesnt seem to be picking up
the hose is clogged. try sucking the dirt out with another vacuum (backward) If this doesnt work, you will have to disconnedt one or the other or both ends of the hose to remove the clog. this is a simple process.
thanks for your interest in FixYa.com
Dec 13, 2009 | Bissell 6594 PowerForce Bagless Upright...
My carpet cleaner doesnt **** up the water and cleaner it is a bissell turbo proheat 2x
Here is a tip that will give you all the information you need to fix your BissellProheat Vacuum Problem.
Bissell Proheat Upright Wet/Dry Vacuum Problems
heatman101
ydtyd
Sep 20, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
IROBOT - CLEANED USING WATER - NOW DOESNT WORK AT ALL
you probably got the switches wet ,make sure all the water is out,then take a blow dryer to dry out the electronics
Feb 13, 2009 | iRobot Roomba Discovery SE Bagless Robotic...
Kenmore vacuum- no suction, brush wont turn
Sounds to me like you have a plugged vacuum. Check all the way through.
Jan 29, 2009 | Kenmore 22812 Bagged Canister Vacuum
Why doesnt my brush turn on when power is switched on
sounds like the belt is broken. Bad news regarding all Dyson's. You can't replace just the belt your self. You have to purchase a new belt assembly which includes the gears. And it wont be cheap. I would call it a design flaw but i am sure that dyson calls it a profit scheme.
Jan 29, 2009 | Dyson DC15 All Floors - The Ball Bagless...
Hoover U6311-930 Power Drive Bagged Upright Vacuum Logo
253 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
