Question about Sterling Plumbing Sterling& Deluxe By-Pass Shower Door
Sterling shower door. May be at least 12 years old. Each door swings in and out and each side also collapses/slides in on itself. Kind of a bi-fold. Current Sterling line does not carry this model. Problem: The bottom right hand hinge has broken. It is a grey plastic piece that the frame sits on with a portion of the part exposed to provide a pivot point for the door. It is labeled E9883. I have searched all over the internet for the part. Sterling web site doesn't have much in the way of part diagrams. I can make this door as good as new with a new piece! Any ideas to source this part?
  • 122 Answers
Start contacting Sterling distributors across the country. They may have that part laying around somewhere.
Posted on Feb 02, 2010
Years ago I purchased a Kinkead Vista-Pivot Shower Door, model 1500-31, Silver. For a variety of reasons the shower didn't get built until recently. However the door opening is now 32.5 inches wide so it...
Ace Hardware sells that door and you will need to see if they can order the parts but it looka like they sell the doors 36" size so when you order you will need to order for the Sterling Plumbing 1500D-36S "Vista Pivot" Shower Door Fits Openings 31 -1/4" To 36" H 66" . Now if you have not completely finished the shower you could always make the door opening fit what you have.
Mar 16, 2011 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
How do I replace a seal at the bottom of my shower door. I was recommended by a Lowe's employee to use seal #RPK2800-S Genuine Parts Sterling. Having a hard time figuring out if the seal slides into the...
I know this is an old thread but posting the answer for the sake of everyone else who are looking for the same answer. Once you pull the old one out, you can slide the new one right in without having to remove anything else. The RPK2800-S has a T top, so just line it up with the opening on the button of the door and push it in. Basically do the opposit of what you did when pulling the old one out. Easy task and should not take than one minute.
Nov 12, 2010 | Sterling Home
Have a two handle Sterling shower stall. The shower head is leaking from the cold water inlet. Believe need a replacement stem. Have changed the O ring but has not stopped the leaking. Is there any...
The part # you supplied is for a shower door and has no bearing to your question. There is no relationship. However, I can say there is no adjustment for any two handle shower stem or even single handle stem. Very rarely will just replacing an "O" ring stop a drip unless it it from through the stem itself and comes out under the handle. When in doubt replace the whole stem...shortcuts will only exasperate the problem. There are no shortcuts in plumbing.
Oct 24, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Sterling shower stem replacement, anyone know how? I changed it out, hard to turn, and slips at times
Sterling like many others made many different types of faucets and stems. To service any of them you need to remove the handle. Then depending on the type of stem you can make your repairs. Most common Sterling stems were brass. Most common cause of slipping is stripped broach on stem and or handle. The broach is the star shaped part of the stem that the handle slides on. If it is stripped replacing the stem and or handle should do the trick. As for the tighteness of the stem, this could be the packing nut on top being to tight or stem may be damaged. Hope this helps. Please share a vote if it does.
Jan 31, 2010 | Sterling Plumbing 1500D-31S VISTA PIVOT...
I have a sliding shower door in my bath but unfortunately, I do not know the manufacturer of it. It's about 14 years old and the bottom plastic part that is attached to the bottom of the door has broken...
there is a good chance you won't find this part for a number of reasons,...you'd be best to either change the door (with a "basco" door, great company) of if your feeling some oats, make the part you need.
Nov 20, 2009 | Sterling Plumbing 1500D-36S "VISTA PIVOT"...
Need installation instructions for sliding shower door...probably #5475. When reinstalling, the inside door is swinging with nothing to secure the bottom.
not sure what you mean when inside door "swings" on a "sliding" door,...i'll assume you need the "inside door guide", a little plastic piece that screws with one screw to the main threshold,.....
Nov 02, 2009 | Sterling Plumbing 1500D-31S VISTA PIVOT...
Spartan brand curved glass shower door installation info needed.
curved cut glass will not always be the exact dimensions though they may look identical there should be several set screws on both the door glass frame and the shower glass frame that can be loosened and reset to make the door fit and close and open more properly without seeing the showwer itself i can not tell you exactly where they are but they should be either visible or behind a facade piece of metal frame
Aug 27, 2009 | Sterling Plumbing Sterling& By-Pass Shower...
Sterling Plumbing Sterling& Deluxe By-Pass Shower Door  Logo
182 people viewed this question
Top Sterling Plumbing Home Experts
Donni Steen
john h
Mike
Are you a Sterling Plumbing Home Expert? Answer questions, earn points and help others
