Question about Whirlpool Dryers
Whirlpool gold ultimate care II dryer GEQ9800pw1-- Where is the service panel located? The back panel will NOT come off. I took all the screws out and it seems to be "glued down". Can you service this from the front "KIK" panel?
  • tculpeppe623 Jan 31, 2010
    Yes, you can help me some more. The reason I needed to remove the kick panel was because my dryer overheats and then trips the breaker. I put in a new bias thermostat hoping this would help. It did not. I have some other things to try. Any ideas?
  • Whirlpool Master
  • 2,605 Answers
To answer the question regarding access to servicing your model of dryer, it is done from the front. You'll want to re-install any screws/fastener's removed from the back before you proceed. Some dryer's can be serviced from the back...not your's.
**Turn off the power by way of shutting off the breaker at the service panel or unplugging from the wall**
Starting with removing the "kick plate" or "toe panel". The top can also be removed from the front, that requires unscrewing the two screws at either side of the control panel and "flipping" it back to reveal the screw's which hold the top in place. (move the unit out from the wall a few inches for clearance of the wall so you don't damage the control panel or the wall)
If you look closely to the seam where the kick and main front panel meet you'll see clip's at either end. With the aid of a flat screwdriver or puddy knife, push in slightly on these clip's (one at a time) as you pull the kick forward gently. The panel should pull forward on both sides and is then held in place by way of hinge bracket's/clip's at the bottom and will pull off easily.
With the top and front "kick plate" removed you can now remove the entire front panel if necessary. To do this...Undo the spring's from the door hinges. Loosen the screw's at either side supporting the panel (don't remove them, just back them out slightly) then move up to the top of the panel. On the inside of the cabinet facing the front panel will be a screw on either side you must remove completely. While you are removing these upper screws, lean into the panel or have someone support it as it will fall forward when the screws are removed as well it put's less stress on the screws allowing them to be removed with less effort.
**Before pulling the panel off completely take a picture or make a drawing of the location of the door switch wires, you will then need to remove the wires and the panel should be free to remove.**
Hope that explain's the procedure enough for you to move forward. Let me know if I can assist you further.
Good luck and thank's for visiting "fixya" today for your repair tips.
Please take a second and rate or comment on the repair help you received here or the expert assistance.
macmarkus :)
Posted on Jan 30, 2010
Testimonial: "Thank you so much!!! I figured it out after a while."
How to fix a broken belt of motor of whirpool wash ultimate care 2
  • Replacing the Belt in a Whirlpool Ultimate Care II ' Home ... homeguides.sfgate.com > ... > Mortgage-Backed Securities Replacing the Belt in a Whirlpool Ultimate Care II by Rogue Parrish. Email; ... The Ultimate Care II washer, ... it may have a broken belt.
  • Whirlpool Washer: Ulitimate Care II - YouTube www.youtube.com/watch?v=bVmjmSzMXHE
    • BY CHERRY HILL
    • 3 MIN
    • 36K VIEWS
    2012-05-30 · Video embedded · Whirlpool Ultimate Care II: ... This is fully funcational washer. Direct Motor Drive works perfectly through each ... Whirlpool Washer: Ulitimate Care II
  • How to replace a broken dryer belt. Whirlpool Ultimate ... www.youtube.com/watch?v=PU8QZeDRl_0
    • BY BAILSOFSTEEL
    • 5 MIN
    • 3.5K VIEWS
    2015-04-04 · Video embedded · This video shows me replacing a belt in a Whirlpool Ultimate Care II ... a broken dryer belt. ... Whirlpool ultimate care II clothes washing
  • http://www.bing.com/videos/search?q=broken+belt+of+motor+of+whirpool+wash+ultimate+care+2&FORM=HDRSC3
    Jul 15, 2016 | Washing Machines
    Whirlpool Ultimate Care II dryer trips breakers.
    No way to know unless you do some checking. This video shows how to get into the machine: HERE
    I have a repair manual that features the same basic style of dryer you may want to take a look through: HERE
    Feb 14, 2010 | Dryers
    Door switch tab is broken so dryer does not stay in the on position whirlpool gold ultimate care II the tab switch that lets the dryer know it is on is broken, I have to tape it down but it only stays...
    will need to replace actuator. door swich can be accessed through the top. Unplug first, pull screws under lint filter door and pull top toward you. top should release and flip back
    Jul 17, 2009 | Dryers
    How do brass (gold) clips go back into the slots when trying to put Whirlpool Ultimate Care II back panel back on after repairs are done?
    they can only go in one way it's a matter of figuring it out. Believe me I've taken more time trying to figure this out when I did not pay attention as to how they were before removing.
    Apr 03, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
    WHIRLPOOL DRYER GOLD GEQ9800PW1 HOW TO MAKE IT WORK WITH 220 VOLT
    ck frequency on tag if US will be 60 cycles ..most overseas areas are 50 cycles ..not gonna work without some sort of converter
    Nov 17, 2008 | Whirlpool GEQ9800P Electric Dryer
    ELCTRIC DRYER NO HEAT JUST COLD AIR
    There is a thermal fuse its location depends on the dryer if the filter is on the top then you have to take off the back panel and check the white fuse. If the filter is inside the dryer you have to take off the bottom panel. a flathead screw driver for the 2 clips the check the white fuse behind the lint trap (where the filter goes).
    Oct 29, 2008 | Whirlpool GGQ8831L Gas Dryer
    Ultimate care II Whirlpool dryer
    yes its located on the houseing where the heating element is and is a small round disc with two wires get a putty knife and push in between the top panel and body of the drier about 2-3inches of the edge lifting the top as you do remove the front panel by removing the two 5/16 in screws and pull the panel the locate the heating coil and check the thermal limiter
    May 24, 2008 | Dryers
    Whirlpool ultimate care II gold electric dryer
    the top and the front has to come off
    Feb 04, 2008 | LG DLG2524 Gas Dryer
    Water leaking from whirlpool washer
    facing the washer locate the two screws. They will either be in the front or rear of the control panel and back them out far as you can. Once you have done that pull the control panel slightly forward, and tilt it back on the hinges. Now unplug the lid switch wire but don't forget to plug it back when your done. Next locate at the rear of the washer body the two gold clips then push forward, and take careful note of how they fit. Then pop them out with a screw driver tilt the washer body forward at 45 degree angel and walk forward with the body, and set it down.
    Jan 12, 2008 | Whirlpool Ultimate Care II LSQ9549L Top...
    Whirlpool Gold Ultimate Care II: No heat
    didc, on a gas dryer, if the thermal fuse blows it will still rotate, but will not heat. Since this is a gas dryer, see if the ignitor is glowing. If it is, then you know the thermal fuse is good. If not, the thermal fuse may be blown or the ignitor itself and thus the reason for no heat. Catriver.7152136.jpg
    Jan 01, 2008 | Whirlpool GGQ8831L Gas Dryer
    Dryers Logo
    1,672 people viewed this question
    Top Whirlpool Dryers Experts
    Dan Webster
    Dan Webster
    Tim Whalen
    Sal DeAngelo
    Are you a Whirlpool Dryer Expert? Answer questions, earn points and help others
