Question about HP Compaq Presario 2135US Notebook
Presario 2135us dying mother board
The mouse touchpad and IO indicator lights have gone dead on my 2135us notebook. I can get a 319449-001 compaq main board and have the skills to swap it out. Got an associate degree in electronic systems tech just before hybrid surface mount technology caught hold. Dated but still useful. My question is this: are there any special jumper settings or (shudder) bios burnings required to have this board (pulled from another machine) recoginze and run with the Celeron 1.8 Ghz processor in the recipient laptop?
Thanks in advance!
Patrick.
  • HP Master
  • 13,433 Answers
Hello
Aslong as the mainboards bios supports the cpu, then no, if it doesn't support the cpu, then there is noting you can do.
I believe that the 1.8 will run on the 319449-001 board.
Posted on Jan 30, 2010
  • Ekse Jan 30, 2010
    Forgot to mention, somewhere after 2000, the makers of motherboards stopped placing jumpers for the cpu on the board In todays computers, all the cpu settings are done by or from the bios. I haven't heard anyone soldering a laptop motherboard to make a cpu work with it.
    As far as I know such jumpers don't exist on the board (aside from bios / cmos / password reset jumper which is well hidden in most laptop motherboards), in rare cases there might be a few switches that you can switch with your fingernail.
I can not disable the touchpad in my Compag Presarioa CQ42
To disable the touchpad, do the following steps.
  1. Click Start , type mouse in the search field, and select mouse from the listing.
  2. In the Mouse Properties window, select the Device Settings tab.
  3. Click the Disable to turn off, or disable the touchpad.
Sep 29, 2010 | HP Compaq Presario V2000 Notebook
Compaq Presario CQ50 + over sensitive touch pad CONTINUED
try SYNAPTICS pointing device in mouse settings
Please rate my help++++Thanks for using FIXYA
Jul 31, 2010 | Compaq Presario Notebook
How can disable touchpad of my COMPAQ Presario CQ42 laptop
On most Compaq's of the CQ42 model type, there should be a little light on the top right hand corner of the touchpad, not much bigger than a pinhead. When the touchpad is active the light is out so you shouldn't see the lamp. Quickly double tap the area on the lamp and it should light up. This is an indication that the touchpad is now not active.
Jul 22, 2010 | HP Compaq Presario V2000 Notebook
HP Compaq Presario CQ60-249US PC Notebook, my trackpad and mouse buttons have stopped responding. I am trying to check the cable connections and possible install a new one. Anyone tell me how to remove...
To access the mouse cable remove the battery - remove the screws securing the keyboard - carefully lift the keyboard out and check the security of the cable BUT in your instance look at the small on / off button in front of the mouse pad and ensure it is turned on ( blue light ) for on yellow off -- if it is blue go to Started - all programs - recovery manager - activate recovery manager - select advanced options - select reinstall a selected driver - select the touch pad driver - reinstall - reboot if that fails go to http://h10025.www1.hp.com/ewfrf/wc/softwareCategory?os=2093&lc=en&cc=us&dlc=en&sw_lang=&product=3872064#N1238 & download & install the latest touch pad driver. If still no go your up for a new top cover assy
498410-001 Chassis top cover assembly - With touchpad (Presario)
Also it maybe the on / off cct board assy that failed
502907-001 Touchpad on/off circuit board
Jul 06, 2010 | HP Compaq Presario CQ60-249US Notebook
Compaq presario cq60 labtop- the touchpad mouse goes crazy!
os? vista, 7, x64??? ok lets get to a base point. you had a different mouse, is it still installed? Is the dongle still plugged in? are the drivers loaded? uninstall drivers in control panel. remove all traces of every other mouse, pad, pointers, etc from your cq60. in device manager you should show Synaptics PS/2 Port TouchPad under MICE AND OTHER POINTING DEVICES. if after reboot the touchpad is still not working then right clock the Synaptics PS/2 Port TouchPad in the device manager and select uninstall. reboot. let me know when you get to that point.
May 21, 2010 | Compaq Presario CQ60-212US Notebook
Describe your compaq presario cq60 touchpad not
after rebooting my Compaq Presario CQ60 laptop the touch pad does not work and I have to use a plugged in a mouse
Mar 09, 2010 | HP Compaq Presario CQ60-249US Notebook
Presario C700 won't start and plug in light won't come on
most probably .. any hardwares might have gone dead .. i once had the same probs with my frnd ... its mother board was dead and got it replaced. .since it was under warranty ..
thnx
Nov 04, 2008 | Compaq Presario 700 470024-192 Notebook
My touchpad mouse and didn't working(presario v2000)
it could be the touchpad connector/cable get defect....
mouse drive barely have problem as it given by Windows ,
can try and order a touchpad set from ebay,and if that dont work,
guess you'll have to get a USB mouse for that.......
Jul 18, 2008 | HP Compaq Presario V2000 Notebook
How to take an acer apire 9410-2028
You'll have to remove the mother board to fix this. Basically, remove the keyboard & touchpad. You will see the mother board at that time. Remove whatever else is necessary to get down to the mother board. Hint! Keep track of what screw comes out of what hole. You'll need to know that for reassembly.
Ron-
Nov 11, 2007 | Compaq Presario Notebook
"sticky" mouse on compaq laptop
Unless your left mouse button has been severely damaged, it is unlikely that a loose button is the cause of your problem. More likely, it is your touchpad. Chances are your touchpad is set to click when tapped. Oversensitive touchpads can click randomly when you're dragging your finger across the touchpad.
To test this, position your cursor over a link (or other button) but don't press the left mouse button. Instead, lightly tap the touchpad itself. If the link or button is clicked, go to your Control Panel and adjust the Mouse options so your touchpad no longer clicks when tapped. It's usually a setting titled "tap to click" or something along those lines.
Regards,
Javabytes
Nov 07, 2007 | HP Compaq Presario V2000 Notebook
HP Compaq Presario 2135US Notebook Logo
63 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
