Question about Nokia N70 Cellular Phone
I can't tranfer files from my N70 to my pc
I tried connecting my n70 to my pc but a message balloon popped saying that the usb connected is not recognized.
prior this problem, i didn't have any problems connecting my n70 to the pc.
it may be because i accidentally deleted the pc suite support from my phone.
one more problem is i also forgot the code i useed with my memory card.
can u please help me?
thanks
  • 4 more comments
  • Anonymous Mar 07, 2008
    i cant open my gallery
  • joanrichel Apr 30, 2008
    this is not the first time my phone got a problem but i didnt worry about it in the past. i cant transfer my photos from my phone to my computer. i have uninstalled and installed nokia pc suite alot of times but still, i cant transfer my photos. every time i paste the pictures to my computer, a folder appears. PB3B84B.tmp is the name of the folder. in the past, i cut the pictures and when i paste it, the pictures werent pasted, instead, they were just erased from myphone. my computer is VISTA and my frends think that this is the reason for these problems. hope you could help me.
  • ravi_xnlb Jul 12, 2008
    i have connected the phone to computer with usb cable
    but its not display on my computer
  • masong1983 Jul 12, 2008
    I can't transfer files over 5M from N70 to PC,either!
  • Anonymous Sep 05, 2008
    i can't transfer the images from my N70 to the pc
  • Anonymous Feb 06, 2009
    i have formated my phone so its askin for d sofware.wat to do
    President:
  • 1,017 Answers
Nokia PC Suite does give problems if you delete files, because some files are shared between applications.
The solution, if you haven't deleted anything from your PC.
Disconnect your USB cable.
Start Nokia PC Suite.
Check your version of PC Suite, it should be 6.85.14.1 (or the latest) if it's not, download it from Nokia (where you are, Philippines!)
Click Help/About Nokia PC Suite, at the top of the PC Suite window to see the version.
Then click next to Help, Settings/Manage connections.
Click on both bottom check boxes, USB and Serial.
Click Configure/OK.
Then do a Synchronise.
Click Select phone, and follow the instructions from there. Connect the cable to the USB when prompted and the phone to the cable.
After you've done all that, restart your PC.
Connect your phone to the PC, wait until the icon on the PC turns green, click on the icon to open Nokia PC Suite.
Posted on Feb 18, 2008
Garmin foreruuner 305 ' device not found"
Download the Garmin usb drivers from the Garmin website.
Apr 15, 2017 | Garmin Forerunner 305 GPS Receiver
My computer doesn't recognize my Acomdata 250 Gb Hard drive (HD). The computer pops a balloon saying that it could run faster with a hi-speed 2.0 port. I own a dell Xps m1210, the installation cd that...
First make sure usb cable connected to harddrive is working fine. try it in different usb ports. Press windows key +R key so you can see run then type in run "devmgmt.msc" then press ok so you can see device manager uninstall all usb drivers then it automatic install usb drivers. then check. Also you need to change registry for that type in run "regedit" then press ok then you can see registry editor then locate below key. HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11 CE-BFC1-08002BE10318} And remove upper filter and lower filter.Then restart computer then check. Try your harddrive in different computer if it is not recognized on another computer too then your harddrive has internal issue. Also locate the below key and make sure it's value is 3 not 4. HKLM\system\currentcontrolset\services\usbstor make sure start value is 3 not 4. Let me know if you need further assistance. Thanks for using FixYa
Nov 27, 2010 | Acomdata 250GB External Firewire HD 250 GB...
Camedia software does not recognize connection to C-770 via usb cable what could be the cause of this? the cable is connected to the pc and camera and the camera is on. When the menu comes up on the...
Did you install all software that came with your camera? If so, you should've seen a balloon on the bottom right corner of the computer screen saying the software was "successfully installed and ready to use" at the time of installation. Try this, then turn on the camera and connect it to the computer. The message doesn't go away because it's constantly looking for a connection to your computer, which your computer isn't detecting and is most likely that the proper drivers (which are in the CD) were not installed.
Jun 30, 2010 | Olympus Camedia C-770 Digital Camera
Cell phone is not connecting to the laptop via usb
what happens when u connect ur phone via usb?
what kind of usb cable are u using? it should be wrriten on top of the cable.
have u downloaded a pc suite for n70?
Jan 05, 2010 | Nokia N70 Cellular Phone
Computer not recognizing samsung juke?
pls install the usb 2.0 to the pc and try it
Jul 09, 2009 | Cell Phones
USB DEvice not recognized
Turn off the CPU unplug the power cable and all usb cables, let it sit for about 15-20 minutes. Plug power cable back in, turn on CPU, plug in your usb devices.
Mar 06, 2009 | Canon PowerShot SD790 IS Digital Camera
PC Does not recognize HDD
there is a complict device driver in the device manager. .. configure device manager and remove an auknown device driver especially the usb device and restart the computer
Mar 08, 2008 | Beyond Micro Mobile 80 GB USB 2.0 Hard...
Nokia N70 Cellular Phone Logo
188 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
