Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Friction between the doors
It is a brand new fridge and the upper left hinge(freezer one) is installed little bit toward the fridge causing the freezer door moved toward the fridge and have a friction with it. Opening and closing is not as smooth,
  • 958 Answers
Look at the hinge on the top of the freezer door, unloosen the bolts that's holding the bracket, move the door a little bit to the left then tighten the bolts again. that should solve your problem.
Posted on Feb 18, 2008
My brand new fridge, one door style will not self close.
front raise 1 or 1 1/2 inches the side that is the door hinge side is 1/2 inch higher then the handle side. Tilt it on a slit angle towards the way that will force the door with the added weight of food on door shelf's. A perfectly level fridge is a useless fridge. If its only mission is for the doors to close from the maximum range its able to open.
Mar 16, 2017 | Refrigerators
Reverse doors freezer hinge
What is the model number of your unit?
Nov 28, 2012 | Refrigerators
Both the freezer and fridge doors hinge on the right, and the left hand side has sagged a little so neither neither door is sealing properly. How do I adjust the doors to raise the left side of the...
The lower hinge on each door may have a door closing cam. It raises the door up ¼ inch when opening and this assist in closing the door. If it's wore out and doesn't work the door may not seal and the gasket can be damaged. Watch the operation of the door to see if it rises up when opened.
Leave the door shut and let the magnetic gasket hold the door in place. Put something between the bottom of the door and the floor to hold it in case it slips.
Remove the bracket holding the pin and hinge assembly taking note of order of removal of parts. Slide new cams on. You probably need two.
May 04, 2011 | Refrigerators
Whenever fridge door is shut hard/ quickly it causes the freezer door to pop open a little...and meltdown the frozen stuff. The fridge door has dropped a bit but I don't think that is it. It seems there...
Nov 30, 2010 | Fisher and Paykel Active Smart E522B...
Frost build up shortly after defrosting it.
the frost buildup is entirely due to badly fitting seals,its also costing you a fortune to run it.A 5 sided cube is easily adjusted by using a spirit level and spacers under the feet/wheels(if fitted)once adjusted the lid should fit square.otherwise check the hinges for adjustment.
WHEN FITTED/INSTALLED CORRECTLY, THE LID SITS TIGHT ALL ROUND,NO AIR GAPS.....
Jul 10, 2010 | Kenmore 19.7 cu. ft. / 558 liter Chest...
Help . Change doors from right to left opening
first remove the door from the fridge, remove the hardware connected to the fridge, on the opposite side should be rubber or plastic caps covering some bolt holes. remove caps and install top of hinge transfer everything you see on the left to the right
Oct 21, 2009 | Bosch Classixx KGV28323 Bottom Freezer...
Amana SXD2252W Freezer Door does not close all the way.
Check for things on the freezer shelves sticking out and contacting one of the door shelves before it can close fully. Sometimes a maladjustment of the door can cause the gasket on the hinge side to stick from friction of the rubber on the metal case of the refrigerator. Try a tiny bit of cooking oil on a paper towel and then wipe down the vertical gasket strip on the hinge side. If friction is the cause this will cause it to close better.
Before performing the above check the condition of the hinge side vertical gasket strip to ensure it's not "bowed" inward from too much friction. That condition may necessitate replacing the freezer gasket.
Aug 21, 2009 | Amana Refrigerators
Top freezer door pops slightly open when frig door is closed
try to adjust hinges and check the door gaskets for pinching. Also I have seen that if the fridge is slightly pitched forward and not slightly towards the back gravity sometimes this causes the problem you describe.
Apr 26, 2009 | GE Refrigerators
My freezer door will not stay shut. Dometic Model RM2453. This is the model with the freezer compartment inside the unit. Springs in freezer door seem weak or broken.Can I safely remove the plastic spring...
yes you can.remove two screws from under one side pull it away slightly and it will come away.you will then have one housing on both sides left in the fridge wall,they will have a little pressure on them from the springs. just prise them away. you will need help to replace them, as you need pressure against the spring to keep the door closed. you can buy springs and housings seperately from camec there is left and right housings.give me a call if you need to ..
Apr 22, 2009 | Dometic RM2452 Refrigerator
I have a Baumatic American style fridge freezer. Problem is freezer door comes open when fridge door is shoot...
Re-level your unit and tilt it just a little toward the back. When you close the refrigerator door you in effect cause a compression affect which pushes the freezer door momentarily open. If it is leveled so that it is tilted toward the back the door would re-close under its own weight.
Jun 02, 2008 | Baumatic Refrigerators
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
59 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
