Question about Apple For Iphone 1g 1st Gen Lcd Mirror Screen Protector
Iphone 1g won't reboot past the apple logo - Apple For Iphone 1g 1st Gen Lcd Mirror Screen Protector
  • 416 Answers
With the device off, hold the home button and power on the handset. continue to hold the button until the phone boots up completely
Good Luck and pls rate this post.
P.S. make sure you dont have it plugged in while doing this...
Posted on Jan 30, 2010
Iphone wont go past the apple logo it just keeps blinking the apple logo after i updated it help
was your iPhone Jailbreak before you update it? if so, you should not update directly as you have to back it to un-jaibreak and the update, else your iPhone will became a brick with white APPLE logo.
try to search this problem about this by google, there will be Solution step by step.
Apr 29, 2013 | Apple iPhone4 4G iPhone 4
Twitter app won't load on iPhone
try a hard reboot... hold sleep and power together until you see apple logo... then let go.. app work now????
if not, use a different app or call Apple at 1800myiphone
Feb 21, 2013 | Apple iPhone Cell Phones
Iphones stuck on reboot apple logo
If your iPhone is jailbroken (do not restore from iTunes) Instead try to restore using the jailbreak software used originally.
Please take note as to why I displayed the top message first. As for the iPhone through iTunes, you are stuck in what is known as a boot loop error. A restore from iTunes is required provided your iPhone is not jailbroken. The 5.1.0 release for the jailbreak is not yet out and you will not be able to downgrade back to 5.0.0 once you restore from iTunes.
May 07, 2012 | Apple iPhone 3GS Black (16 GB)
How to reboot iphone
Hold down the home button and power button simultaneously until the apple logo appears on the screen.
Once the Apple logo appears on the screen, release the buttons.
Apr 05, 2012 | Apple iPhone Smartphone
My iphone is hanged its shows apple logo only, hw can i solved this problem without loosing my all data,like my videos,contacts,pictures,pls help me out
Try pressing and holding both the POWER & the HOME button at the same time for around 3 to 10 seconds until it turns OFF. Then turn it back on again.
If it still won't go past the Apple logo, use tinyumbrella to Fix Recovery or to Exit out of Recovery. Download tinyumbrella using the links below: for Mac for PC (Windows)
Update tinyumbrella first if it tells you that there's newer version available.
NOTE: Your computer must be able to recognize your iPhone before you can use tinyumbrella to fix it. If your computer could not recognize your iPhone, you first need to put it to DFU mode. To learn more about DFU mode, CLICK HERE.
If those things still don't work, you'll have no other choice but to restore. Again, your computer must be able to recognize your iPhone before you can restore it using iTunes. Put it to DFU mode if your computer won't recognize it.
Read more tips for iPhone, iPad and iPod touch, CLICK HERE.
Apr 25, 2011 | Apple iPhone 3G
Iphone 3G wont reboot...stuck on apple logo...
What you can do is hold the power On/Off button + Home button at the same time. Your iphone will reboot. When you see the apple logo, quickly let go the power On/Off button. If you want to jailbreak your iphone, go to www.blackra1n.com and download the jailbreaking tool.
Follow these easy steps below...
- Turn off your iphone
- Run the jailbreaking tool
- Turn on your iphone
- The jailbreaking tool will everything by itself.
- If you want to unlock your iphone after it is jailbroken, hit the blackrain icon and select install Cydia and unlock with Blackrain.
Dec 23, 2009 | Apple iPhone 3G
IPhone stuck on Startup logo
Reset the iPhone by holding the sleep/wake button at the top right of the device and the home button at the bottom center of the face at the same time. Hold them both until you see the screen go black and the white Apple logo appear. When this happens, you can let go - the iPhone is rebooting.
Resetting the iPhone should not remove or delete any data or settings.
Aug 08, 2009 | Apple iPhone Smartphone
Iphone only see apple logo and itunes logo in a dark screen after
If it got wet, you can bring it to any Apple Store. Nine times out of ten they will replace it for $150 to $200 dollars. Unless they determine it is a manufacturers defect and you are still under warranty, then you want have to pay anything. they will usually just replace it for you.
Otherwise, you may have to pay up to $200 for a replacement.
Hope this helps...Let me know...
enov8
Mar 07, 2009 | Apple iPhone Smartphone
Ipod freeze how do I restart
This method is to restart your ipod without erasing any of your saved things.
1. Check that your hold switch is off by sliding the switch away from the headphone jack. The hold switch is located in the top corner of the iPod. If you see orange, then the iPod is locked. To unlock the iPod, slide the switch in the opposite position.
2. Press and hold the following combination of buttons buttons simultaneously for approximately 10 seconds to reset the iPod.
For iPod 1G to 3G (scroll & touch wheel iPods): "Menu" and "Play/Pause"
For iPod 4G+ (includes Photo, Nano, Video, and Mini): "Menu" and "Select Center Button"
For iPhone & iPod Touch: "Menu" and "Sleep Button"
For Shuffle: Turn it off. Turn it on. Done.
If you have an iPod Mini or 4th gen iPod or higher, then you need to press the Menu and Select buttons. The Select button is the center button in the middle of the wheel. For older iPods (1G - 3G) you'll need to press the Menu and Play buttons to restart.
Upon reset, your will see the iPod/iPhone name and the Apple logo. When this happens, you can let go - the iPhone/iPod is rebooting. If your battery is very low, you may have to attach your iPod/iPhone to a power source.
3. The iPod name and the Apple logo will briefly appear upon a successful restart before advancing to the Main Menu.
4. If you have your iPod/iPhone connected to your computer and iTunes open, then your iPod/iPhone should mount and show up under "Devices" in the left iTunes sidebar.
May 05, 2008 | Audio Players & Recorders
Apple For  Iphone 1g 1st Gen Lcd Mirror Screen Protector Logo
255 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
