Question about HP Deskjet F340 All-In-One InkJet Printer
My HP f340 printer sometimes won't print. i either get an error or they just stay in pending mode. i have tried rebooting and cancelling the documents and tried again. same thing happens.
TimPiggott
  • 3 Answers
SOURCE: there is a document pending
This solution worked perfectly, although I did have to reboot between the run command:
Start>>Run>>net stop spooler>>OK
reboot
Start>>Run>>net start spooler>>OK
Posted on Mar 22, 2009
SOURCE: wont let me cancel a pending document
I used to have the same issue. It happened on five different occasions. I tired all kinds of steps to fix it and none worked. Finally, my daughter fixed it for me by accident. She tripped over the plug to the computer. After it restarted, I canceled the document, and it worked perfectly. After that, i knew what to do. Hope this helps@
Posted on Jun 01, 2009
md_ehsan_1
  • 255 Answers
SOURCE: Printer installed correctly however will not print.
1. uninstall your printer
2. restart your system
3. re install your printer
4. after installation take a test print
5. hope this will correct your problem..
6. otherwise, run Advance system care to fix your computer problems, such as registry errors etc., due to some registry problem are some other problem in your software makes like this problems.. download from the following link..its a freeware software..download it and install it, Press CARE to start the program.
Advance system care (registry cleaner)
http://download.cnet.com/Advanced-SystemCare-Free/3000-2086_4-10407614.html
Posted on Jun 22, 2009
SOURCE: Having problems deleting pending documents
@larryab:
Mate, thanks! I had exactly the same problem and your solution worked precisely as you say...
Thanks a million!
Posted on Jun 29, 2009
funkyagain
  • 24 Answers
SOURCE: says pc print pending how to cancel the pending
There should be a cancel job **** or a "cancel" button on the printer. Just click that a couple times to remove it.
You can also go into control panel - Printers and Faxes - select the specific printer - manually delete your last print job.
Hope this helps!
Posted on Apr 30, 2010
How do i get my printer from offline mode back to online mode
  • Make sure that the printer is powered on.
  • Pull up 'My Computer' then click on 'Control Panel'. From the Control Panel, click on 'Printers and Faxes'. You will then see a list of Printers connected to the PC.
  • Delete pending print jobs to make sure that the correct document will be printed later and for you not to waste paper. Double click on the printer that you want to use, and a window will appear showing you a list of pending print jobs. Simply click on 'Cancel All Documents' from the 'Printer Menu'.
  • After you have deleted all pending print jobs, right click again on the printer icon and choose 'Use Printer Online'.
  • Try printing a test file, if it doesn't work the first time, reboot the PC.
***If you need any technical help on printer then you can reach at here
Jan 02, 2013 | Office Equipment & Supplies
My printer won't print i got "E" on printer display color lamp blink check paper/check cartridge blink by the way i tried to change color cartridge as a solution but still got the same error
go to start then go to printer & fax right click on the printer look for pending job if you have pending job cancel all of it then wait till all job have removed
Aug 07, 2011 | Office Equipment & Supplies
It doesn't recognize the cartridge
It is important to note that some cartridges have a manufacturer's error even when purchased new. So replace them with a genuine, working one.
Also make sure to clear all the pending printing tasks in the printer queue
Dec 04, 2010 | HP Deskjet F340 All-In-One Printer
Hi, HP Deskjet 3745 Printer not printing-'documents pending'
cancel all printing and start all over . Make sure you have the righ printer selected, restart the computer
Oct 25, 2009 | HP DeskJet 3745 Printer
How can I cancel pending printing with my HP Deskjet D 1455?
You need to go to 'Printers' in Windows, and click on the document in the window to highlight it. Then one of the menu items gives you the option of deleting it.
Turning the machine off does not stop it because the print is held in Windows until the printer says 'thanks, done that', and if Windows senses that the print sequence has failed it simply tries again - and this happens, of course, when you turn the printer off and on again. Werry irritating.
Jun 27, 2009 | HP PSC 1315 All-In-One InkJet Printer
All of a sudden my printer will not print
If you see the printer icon at the systray (near the clock, at the right bottom of the screen)? double-click on it. You'll see how many and what files are pending for printing. On menu press "Printer", then "Cancell all documents". Be patient. Sometimes you should try to press "Cancell all documents" several times, till the printer does it's job. Sometimes it's necessary to press "Cancel" (red button) on your printer. Try to switch off printer and then restart the computer. Switch on the printer and do the procedure described above.
Jan 30, 2009 | HP PSC 1410 All-In-One InkJet Printer
Will not print Error message
Right click on the printer icon and look around for PRINT DIRECTLY TO PRINTER then select it.
Jan 10, 2009 | HP Photosmart C6280 Printer
Printer is pending
the print spooler is not letting it print cancel the pending jobs you will be able to print fine keep on cancelling the documents unless the icon shows 0 document pending ....
Dec 16, 2008 | HP Deskjet D2430 Printer
HP Deskjet F340 All-In-One InkJet Printer Logo
160 people viewed this question
Seeker5211
Seeker5211
