Question about Brother CS-6000
While sewing locks up and stops
Barely after starting to sew the machine makes a horrible noise and locks up. I have changed thread, needles, took face plate off and dustied. There were no trapped threads. It also makes a tapping sound before it locks up. Prior to this it sewed fine.
    Genius:
  • 1,116 Answers
Check the bobbin case to be sure it has not shifted - pages 57 & 58 of the manual.
Posted on Feb 19, 2010
How do I stop my singer prelude sewing machine from making so much noise?
Reset all dials. Straight stitch, 1 or 2 in length, ease the thread tension and see if it helps. The only area that makes noise is around the bobbin/needle part of sewing machines.
Feb 18, 2015 | Singer Sewing Machines
I have a Bernina Activa 130. I tried to sew over some leather, started fine, then the needle got stuck and I stopped right away. Now, the bottom threads keeps bunching. I have re-threaded the machine, new...
You need a fatter needle. The skinny needle will not open the leather enough for a smooth flow of thread and that's why the bobbin is bunching up when the top thread is sticking. Make it easier on your machine by using an appropriate size needle while sewing leather.
Nov 04, 2013 | Bernina Activa 130
I have a Husqvarna Opal 650 machine that was just purchase in July. I am hired to sew headbands, and we use Coats Transparent polyester thread. It's worked perfectly, until last Saturday it suddenly...
change the needle again, the needle could have a burr
check for burrs in the needle plate area and in the bobbin area
is the needle the right one for the fabric being sewed? was the needle inserted correctly into the needle holder?
is the tension correct for the fabric being sewed?
Oct 14, 2013 | Sewing Machines
Bobbin jumping like telltale heart
try changing the bobbin and see if the problem still happens
and if it does happen again then the machine needs to be checked
to see if their is something wrong with the hook and hook race.
Mar 26, 2013 | Sewing Machines
Bobbin case jumps out of place when free-motion quilting
Skipped stitches
1. The needle is not inserted correctly
Remove needle & reinsert needle( flat side towards the back of machine)
2. The needle is damaged
replace with new needle
3. The wrong size needle is being used
Choose a needle to suit the thread & fabric
4. The foot not attached correctly
Check & attach correctly
bird nesting problems
Try these suggestions
1. Change needle
2. Rethread the machine--top --make sure to use every thread guide
3. Take the bobbin out --make sure it is inserted correctly into the bobbin
Case, & make sure the bobbin is turned the correct way
4. make sure the thread has not come off the thread take up lever
5. Clean under the needle plate & in the bobbin area for lint or threads
The needle thread breaks
1. the needle thread is not threaded properly
2. The needle thread tension is to tight
3. The needle is bent or blunt
4. The needle is incorrectly inserted
5. The needle thread & the bobbin thread are not set under the presser foot when starting to sew
6. the threads were not drawn to the rear after sewing
7. The thread is either to heavy or to fine for the needle
Sep 12, 2012 | Sewing Machines
My Singer Futura sewing/embroidery CE-200 machine is malfunctioning. It will sew a few stitches and then make this horrible sound and doesn't move. Once stopped, the needle feels like it is boun
try changing the needle--make sure the needle is correct for the fabric
clean under the needle plate & in the bobbin area for lint or loose threads
if it keeps jamming up & making noises I suggest to have the machine
serviced
Apr 12, 2012 | Singer CE-200 Quantum Futura Computerized...
Sewing in reverse cuts top thread, help? Please!
the fabric & thread & needle may not be compatable
try changing the needle- it may be damaged
the horrible grinding noise needs to be check --the machine needs to be serviced
check for burrs on the needle plate & on the bobbin
some sewing machines don't do with strong material
Mar 18, 2012 | Sewing Machines
I think I've bent something!
when you have the foot down ready for sewing,the needle thread , pull on it slowly and make sure there is resistance through the top tension, if there isnt any then the tread will ball up underneath
May 03, 2010 | Janome Memory Craft 4900QC Mechanical...
Brother 270D Jams when sewing anything
You might have thread caught in the take-up lever linkage and it has soaked up all the oil my recommendation would be take it to your local dealer
Jun 24, 2009 | Brother SE-270D Computerized Sewing...
Tons of loops on bottom
Check your threading.
Berhaps your thread is not between the discs.
Mar 09, 2007 | Kenmore 15516 Mechanical Sewing Machine
Brother CS-6000 Logo
152 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
