Question about Goodman GMS90703BXA Heater
HEater is heating outside but not blowing warm air thru the vents inside the house. May blow air for 10 mins but then stops. I have the temp. set at 76 degrees but it is 48 degrees in my house right now.
  • 111 Answers
Sounds like you may have some restriction in the heater or overtemp sensor is kicking out to soon, clean everything thourghly, check fan and oil bearing, check safety circuits in furnace wiring, refer to owners manual trouble shooting guide
Posted on Jan 31, 2010
Heater temp on high only bows luke warm air after driving. A/C works just fine.Plenty of cold air from it
heater blows cold air idle chrysler 300 Questions & Answers ...
www.fixya.com > Forum > Tags
Find solutions to your heater blows cold air idle chrysler 300 question. ... blow warmair for a few mins then back to luke warm. i replaced thermostat ... HEAT BLOWSCOLD AIR WHEN IDLING ONLY GETS HOT WHEN START DRIVING ... About 15 minutes after driving the diver side vents start blowing straight cold air but the ...
Heater only works when pressing the gas? - DoItYourself.com ...
www.doityourself.com/...repairs.../459521-heater-only-works-when-pres...
Nov 3, 2011 - When I press the gas, the air from the vents is nice and hot. .... So am Idriving a car with a ton of problems, or could the power steering ... Just anotherquestion, when warmed up does the engine temperature ... When the heater is on and I'm not pressing the gas pedal, luke warm air blows from the vents.
Heater blows cool air when stopped and warm air while ...
https://www.reddit.com/.../heater_blows_cool_air_when_stopped_...
RedditFeb 12, 2014 - Heater blows cool air when stopped and warm air while driving 2008 Kia Spectra (self. ... just fine but appears to blow cool air when I was stopped at a stoplight. ... My temp gauge would also be pegged high when at idle / low RPM. ...thermostat only blocks coolant going to the radiator, and the heater core, ...Missing: 300m ‎luke
Why is My Car AC Blowing Hot Air? - BlueDevil Products
gobdp.com/blog/car-ac-blowing-hot-air/
Jan 27, 2016 | 2000 Chrysler 300M
2002 FORD EXPLORER FAN BLOWS HEAT FOR 20 MIN THEN STOPS BLOWER IS BLOWING BUT NOT THRU VENTS
Sounds llike vaccum problem with the heater 'doors' which switch directon of air flow.
Nov 24, 2015 | 2002 Ford Explorer
Why is my new system with heat pump not blowing
Contact Gemaire Distributors in Jacksonville...contact information below. They can obtain the documentation you are looking for.
Gemaire Distributors www.gemairegroup.com2899 Powers Avenue
Jacksonville, FL 32207-8039
(904) 733-2415
Mar 02, 2010 | Heating & Cooling
Heater doesn't work?
Your thermostat may not be working properly. Coolant flows thru your heater core where the blower motor blows that heat from the coolant thru your vents. If the coolant is not warm enough wich is a sign that your thermostat may be stuck open or opening too soo, your air may be colder than normal.
Oct 05, 2009 | 2000 Hyundai Elantra
Ducted heating unit blows cold air and fan is always on..
that s correct the control is done by the thermostat stop the heating up to your set point and restart if the medium temp is under the set point
if this sequence fail means
- no power to the control element or is defective
thanks
Apr 27, 2009 | Heating & Cooling
2001 Suzuki XL-7. Heater blows hot one side, cold the other.
No ductwork [to the lower vents] under the dash. They are part of the heater core / blower housing is integrated (all one piece).
After reviewing shop manual, we suspect that one of the three damper flaps is not positioning correctly; or debris has blocked one side (which makes more sense given the symptoms).
We're waiting for the temperatures to get back in the plus numbers to check out the physical arrangement.
Jan 19, 2009 | 2001 Suzuki Xl 7
Fully warmed up; blowing hot and cold; Suzuki XL-7
Its just a vent damper plate not operating, it's like a gate which controls the flow of air,,usually they are operated by vacuum, or cables.
Service center time, unless you are handy with your own repairs.
Jan 19, 2009 | 2004 Suzuki Verona
Defroster blowing snow inside car
Not really a solution but, check that blend door in heater box is operating and that a/c drain hose is not plugged. (if there is ice in there, it may take a while to clear it out)
Jan 16, 2009 | 2005 Jeep Liberty
Won't go past 68...
Be sure the filter is new and clean
Check Chimney/vent to be sure it is not plugged or iced up.
Also if it has a drain be sure it is not kinked or plugged and draining correctly
Dec 22, 2008 | Dayton Gas Furnace Heater
Goodman GMS90703BXA Heater Logo
117 people viewed this question
Top Goodman Heating & Cooling Experts
Dan Webster
Dan Webster
Paul Carew
Tim Whalen
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
